Hello everyone, I have calculated the von Mises stress of a rectangular prism at 100°C (with x = 0 fixed), and validated the results using Ansys under the same conditions. The displacement results are quite accurate, but there is a significant difference in the von Mises stress results. Could anyone explain the reason for this? Here is my code:
from dolfinx import mesh, fem, io, default_scalar_type
L = 1
W = 0.2
E = 2e5
nu = 0.3
mu = E/2/(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
alpha = 1.2e-5
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0, 0, 0]), np.array([L, W, W])],[20, 6, 6], cell_type=mesh.CellType.hexahedron)
def clamped_boundary(x):
return np.isclose(x[0], 0)
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V, fdim, boundary_facets), V)
def eps(v):
return 0.5 * (ufl.grad(v) + ufl.grad(v).T)
def sigma(v, dT):
return (lmbda * ufl.tr(eps(v)) - alpha * (3 * lmbda + 2 * mu) * dT) * ufl.Identity(3) + 2.0 * mu * eps(v)
u = ufl.TrialFunction(V)
Wint = ufl.inner(sigma(u, 100), eps(v)) * ufl.dx
a = ufl.lhs(Wint)
L = ufl.rhs(Wint)
uh = problem.solve()
#Mises stress
s = sigma(uh, 100) - 1. / 3 * ufl.tr(sigma(uh, 100)) * ufl.Identity(3)
von_Mises = ufl.sqrt(3. / 2 * ufl.inner(s, s))
V_von_mises = fem.functionspace(domain, ("DG", 0))
stress_expr = fem.Expression(von_Mises, V_von_mises.element.interpolation_points())
stresses = fem.Function(V_von_mises)
stresses.interpolate(stress_expr)
#save results
with io.XDMFFile(domain.comm, "out_elasticity/u.xdmf", "w") as file:
file.write_mesh(domain)
file.write_function(uh)
with io.XDMFFile(domain.comm, "out_elasticity/von_mises_stress.xdmf", "w") as file:
file.write_function(stresses)
Followed by the successful displacement validation results:
and then the von Mises stress results:
