I am trying to run code to perform some analysis of an elastic arch, in doing this I have to build a circular arch using PyGmsh. I have done this with the following code:
with pygmsh.geo.Geometry() as geom:
poly = geom.add_polygon(
[-100*np.sin(Theta),100*np.cos(Theta), -1/2],
[-100*np.sin(Theta),100*np.cos(Theta), 1/2],
[-101*np.sin(Theta),101*np.cos(Theta), 1/2],
[-101*np.sin(Theta),101*np.cos(Theta), -1/2],
mesh_size=1,
geom.revolve(poly,[0.0,0.0,-1/2],[0.0,0.0,1/2],angle=2*Theta)
mesh = geom.generate_mesh(dim=3)
This generates the shape I want, but with the two points at [0,0,1/2] and [0,0,-1/2] still there. This makes it very difficult to view in paraview, and I’m not sure if it will effect the later calculations?
