Running two linear elastic simulations one with domain and another one after refining domain once
I was able to run two elastic simulations using the original domain, and then a subdivided domain using the following code:
#Make new domain with all elements subdivided once
tdim = domain.topology.dim
domain.topology.create_entities(1)            # edges
domain.topology.create_connectivity(1, tdim)  # edge → cell
# IMPORTANT: refine returns a tuple
domain2,_,_ = mesh.refine(domain)
tdim = domain2.topology.dim
domain2.topology.create_entities(1)            # edges
domain2.topology.create_connectivity(1, tdim)  # edge → cell
The code seems to be working, but I am not sure why create entities and connectivity needs to be called the second time. If refine needs it, but the solver doesn’t, why do I need to create entities and connectivity the second time?
Thank you,
Alex
A self-contained running code is shown below:
import time
from dolfinx import mesh, fem, io, default_scalar_type
import dolfinx.fem.petsc
r_loading = 2.0e-3
def in_sphere(x, point, r_range):
    return ((x[0]-point[0])**2 + (x[1]-point[1])**2 + (x[2]-point[2])**2) < r_range**2
def mark_boundaries(domain, facet_node,grasp_node,grasp_node_normal):
    fdim = dim - 1
    domain.topology.create_connectivity(fdim, dim)
    def left_facets(xq):
        return in_sphere(xq, facet_node, r_loading)
    def right_facets(xq):
        return in_sphere(xq, grasp_node, r_loading)
    facets_left  = mesh.locate_entities(domain, fdim, left_facets)
    facets_right = mesh.locate_entities(domain, fdim, right_facets)
    facet_indices = np.concatenate([facets_left, facets_right])
    facet_markers = np.concatenate([np.full_like(facets_left,  1, dtype=np.int32),
                                    np.full_like(facets_right, 2, dtype=np.int32)])
    # Sort by facet index
    sort_perm = np.argsort(facet_indices)
    facet_indices = facet_indices[sort_perm]
    facet_markers = facet_markers[sort_perm]
    mt = mesh.meshtags(domain, fdim, facet_indices, facet_markers)
    return mt
def elasticity_parameters(E=10.0e4, nu=0.20):
    """Lamé parameters from E, nu."""
    lambda_ = E * nu  / ((1.0 + nu) * (1.0 - 2.0 * nu))
    mu      = E * 0.5 /  (1.0 + nu)
    return lambda_, mu
    return ufl.sym(ufl.grad(u))
def sigma(u, lambda_, mu):
    return lambda_ * ufl.nabla_div(u) * ufl.Identity(len(u)) + 2.0 * mu * epsilon(u)
def build_primal_problem(domain, facet_tags, lambda_, mu, node_normal,
                         p_traction=1.0/(np.pi*r_loading**2), body_force=(0.0, 0.0, 0.0)):
    fdim = dim - 1
    ds = ufl.Measure("ds", domain=domain, subdomain_data=facet_tags)
    V = fem.functionspace(domain, ("Lagrange", 1, (domain.geometry.dim,)))
    u = ufl.TrialFunction(V)
    f_vec = fem.Constant(domain, default_scalar_type(body_force))
    # Traction direction: push along +x (change sign if needed)
    T = fem.Constant(domain, -p_traction * default_scalar_type((node_normal[0], node_normal[1], node_normal[2])))
    a = ufl.inner(sigma(u, lambda_, mu), epsilon(v)) * ufl.dx
    L = ufl.dot(f_vec, v) * ufl.dx + ufl.dot(T, v) * ds(2)
    # Dirichlet BC on left jaw (tag 1)
    left_facets = facet_tags.find(1)
    left_dofs = fem.locate_dofs_topological(V, fdim, left_facets)
    u_D = np.array((0.0, 0.0, 0.0), dtype=default_scalar_type)
    bc_left = fem.dirichletbc(u_D, left_dofs, V)
    return V, a, L, [bc_left]
def principal_stress(domain, uh, lambda_, mu):
    #Compute principal stresses via invariants (analytical eigenvalue solution)
    sigma_uh = sigma(uh, lambda_, mu)
    q = ufl.tr(sigma_uh) / 3                            # mean stress (I1/3)
    B = sigma_uh - q * ufl.Identity(3)                  # deviatoric stress tensor
    j = ufl.tr(B * B) / 2                               # J2 = 1/2 tr(B^2)
    b = ufl.tr(B * B * B) / 3                           # J3 = 1/3 tr(B^3)
    p = 2 / ufl.sqrt(3) * ufl.sqrt(j + 1e-14)           # p = 2/sqrt(3)*sqrt(J2) (small eps**2 added)
    r = 4 * b / (p**3)                                  # r = 4 J3 / p^3
    r = ufl.max_value(ufl.min_value(r,+1-1e-7),-1+1e-7) # clamp r to [-1+eps, 1-eps] to avoid acos domain error
    phi = ufl.acos(r) / 3
    lambda2 = q + p * ufl.cos(phi)                      # largest principal stress (max)
    V_dg = fem.functionspace(domain, ("DG", 0))
    pmax_expr = fem.Expression(lambda2, V_dg.element.interpolation_points)
    pmax = fem.Function(V_dg, name="PrincipalStress")
    pmax.interpolate(pmax_expr)
    return pmax, V_dg
def array_dist_squared(x, p):
    return (x[:,0]-p[0])**2 + (x[:,1]-p[1])**2 + (x[:,2]-p[2])**2
def fea_solve(domain, facet_node, grasp_node, grasp_node_normal):
    #lambda_, mu = elasticity_parameters2(domain, grasp_node, 4.0e-3)
    lambda_, mu = elasticity_parameters()
    facet_tags  = mark_boundaries(domain, facet_node,grasp_node,grasp_node_normal)
    Vp, a_p, L_p, bcs_p = build_primal_problem(domain, facet_tags, lambda_, mu, grasp_node_normal)
    problem = dolfinx.fem.petsc.LinearProblem(a_p, L_p, bcs=bcs_p,
                                              petsc_options_prefix="linear_problem",
                                              petsc_options={"ksp_type": "preonly", "pc_type": "lu", "pc_factor_mat_solver_type": "mumps"})
    uh = problem.solve()
    # Principal stress field
    pmax, V_dg = principal_stress(domain, uh, lambda_, mu)
    # MPS maximum value not considering low E area
    dof_coords = V_dg.tabulate_dof_coordinates()
    indices    = np.where(np.logical_and(array_dist_squared(dof_coords, facet_node) > 5.0e-3**2, \
                                         array_dist_squared(dof_coords, grasp_node) > 5.0e-3**2))[0]
    max_pmax   = np.sort(pmax.x.array[indices])[-1]
    # Get displacement at node where load is applied
    dof_coords = Vp.tabulate_dof_coordinates()
    distances  = np.linalg.norm(dof_coords - grasp_node, axis=1)
    dof_index  = np.argmin(distances)
    u_node     = np.sqrt(uh.x.array[3*dof_index]**2 + uh.x.array[3*dof_index+1]**2 + uh.x.array[3*dof_index+2]**2)
    return domain, uh, pmax, max_pmax, dof_coords[dof_index], u_node
# Part FEA
length = 20.0e-3
width  = 10.0e-3
grasp_facet_node   = np.array([0.0,    width/2, width/2])
grasp_node2        = np.array([length, width/2, width/2])
grasp_node_normals = np.array([1.0,    0.0,     0.0    ])
cell_size = 0.6e-3
n_l = int(length/cell_size)
n_w = int(width/cell_size )
domain = mesh.create_box(MPI.COMM_WORLD, ((0.0, 0.0, 0.0), (length,width,width)), (n_l,n_w,n_w), mesh.CellType.tetrahedron)
t_start = time.perf_counter()
domain_f, uh, pmax, max_stress, point, u_node = fea_solve(domain, grasp_facet_node, grasp_node2, grasp_node_normals)
t_end   = time.perf_counter()
print(f"FEA elapsed time: {t_end  - t_start:.6f} seconds")
with io.XDMFFile(domain_f.comm, f"max_p_stress_part_no_sub.xdmf", "w") as xdmf:
    xdmf.write_mesh(domain_f)
    uh.name   = "u"
    xdmf.write_function(uh)
    pmax.name = "PrincipalStress"
    xdmf.write_function(pmax)
domain_f, uh, pmax, max_stress2, _, _ = fea_solve(domain2, grasp_facet_node, grasp_node2, grasp_node_normals)
with io.XDMFFile(domain_f.comm, f"max_p_stress_part_one_sub.xdmf", "w") as xdmf:
    uh.name   = "u"
print('\n')
print((max_stress2-max_stress)/max_stress2)
print('\n')
When you call refine, a entirely new mesh is created.
A mesh in DOLFINx only store the cell to vertex connectivity, geometry dofmap and the vertices at initialization.
All other connectivities has to be created explicitly as they can be quite expensive to compute.
However, for your example, I see no reason why you would need to create edges a second time.
Could you please provide the error you get if you remove the lines:
as your code runs nicely on v0.9.0 and v0.11.0 without those lines for me.
I guess the problem that you are observing relates to 3D linear elasticity code with fixed facets and tranction facets not converging - #9 by dokken
I’m running it now with version 0.11 and it works without creating edges a second time like you’re reporting, thank you.
