I have implemented the lid-driven cavity with a unit square mesh. But I want to extend my mesh to be rectangle and then compute the same thing but only on the bottom half of my mesh. I have used subdomain and updated dx based on my subdomain, but when I call my solve function, it turns a C++ error. malloc(): invalid size (unsorted)
from numpy import newaxis
from dolfinx import mesh
import pyvista
import dolfinx.plot
from dolfinx.fem import FunctionSpace
from dolfinx import fem
from tqdm import tqdm
import time
TIME_STEP_LENGTH = 0.01
N_TIME_STEPS = 50
KINEMATIC_VICOSITY = 0.01
def Omega_0(x):
return np.logical_or(np.isclose(x[1], 1), np.isclose(x[1], 0))
def Omega_1(x):
return np.logical_and(x[1] <= 1, x[0] <= 1)
def main():
domain = mesh.create_rectangle(MPI.COMM_WORLD, [[0, 0], [2, 2]], [
40, 40], mesh.CellType.triangle)
# domain = mesh.create_unit_square(
# MPI.COMM_WORLD, 40, 40)
velocity_function_space = fem.VectorFunctionSpace(domain, ("CG", 2))
pressure_function_space = fem.FunctionSpace(domain, ("CG", 1))
u_trial = ufl.TrialFunction(velocity_function_space)
p_trial = ufl.TrialFunction(pressure_function_space)
v_test = ufl.TestFunction(velocity_function_space)
q_test = ufl.TestFunction(pressure_function_space)
# mf = dolfinx.MeshFunction("size_t", mesh, mesh.topology.dim, 0)
# top_facets = dolfinx.mesh.locate_entities_boundary(domain, 1, lambda x : np.isclose(x[1], 1))
# mt = dolfinx.mesh.meshtags(domain, 1, top_facets, 1)
# dx(1) = ufl.Measure("ds", subdomain_data=mt)
subdomain = mesh.locate_entities(
domain, dim=domain.topology.dim, marker=Omega_1)
subdomain_values = np.full_like(subdomain, 1)
facet_tags = dolfinx.mesh.meshtags(
domain, domain.topology.dim, subdomain, subdomain_values)
dx = ufl.Measure('dx', domain=domain, subdomain_data=facet_tags)
facets = mesh.locate_entities(domain, dim=(domain.topology.dim - 1),
marker=lambda x: np.logical_or(np.logical_or(np.isclose(x[0], 0.0), np.isclose(x[0], 1.0)),
np.isclose(x[1], 0.0)))
facets1 = mesh.locate_entities(domain, dim=(domain.topology.dim - 1),
marker=lambda x: np.isclose(x[1], 1))
# dx(1) = ufl.Measure("dx(1)", domain=domain, subdomain_data=facets)
dofs = fem.locate_dofs_topological(
V=velocity_function_space, entity_dim=1, entities=facets)
dofs1 = fem.locate_dofs_topological(
V=velocity_function_space, entity_dim=1, entities=facets1)
# u_zero = np.array((0,)*domain.geometry.dim, dtype=ScalarType)
bc = fem.dirichletbc(ScalarType((0, 0)), dofs=dofs,
V=velocity_function_space)
bc1 = fem.dirichletbc(ScalarType((1, 0)), dofs=dofs1,
velocity_boundry_condition = [bc, bc1]
u_prev = fem.Function(velocity_function_space)
u_tent = fem.Function(velocity_function_space)
u_next = fem.Function(velocity_function_space)
p_next = fem.Function(pressure_function_space)
momentum_weak_form_residuum = (
1.0 / TIME_STEP_LENGTH * ufl.inner(u_trial - u_prev, v_test) * dx(1)
ufl.inner(ufl.grad(u_prev) * u_prev, v_test) * dx(1)
KINEMATIC_VICOSITY *
ufl.inner(ufl.grad(u_trial), ufl.grad(v_test)) * dx(1)
momentum_weak_form_lhs = ufl.lhs(momentum_weak_form_residuum)
momentum_weak_form_rhs = ufl.rhs(momentum_weak_form_residuum)
momentum_weak_form_lhs = fem.form(momentum_weak_form_lhs)
momentum_weak_form_rhs = fem.form(momentum_weak_form_rhs)
momentum_weak_form_matrix = fem.petsc.assemble_matrix(
momentum_weak_form_lhs, bcs=velocity_boundry_condition)
momentum_weak_form_matrix.assemble()
momentum_weak_form_vector = fem.petsc.create_vector(momentum_weak_form_rhs)
# Weak form of the pressure
pressure_possion_weak_lhs = ufl.inner(
ufl.grad(p_trial), ufl.grad(q_test)) * dx(1)
pressure_possion_weak_rhs = -1.0 / TIME_STEP_LENGTH * \
ufl.div(u_tent) * q_test * dx(1)
pressure_possion_weak_lhs = fem.form(pressure_possion_weak_lhs)
pressure_possion_weak_rhs = fem.form(pressure_possion_weak_rhs)
pressure_possion_weak_form_matrix = fem.petsc.assemble_matrix(
pressure_possion_weak_form_matrix.assemble()
pressure_possion_weak_form_vector = fem.petsc.create_vector(
# Weak form of the velocity update equation
velocity_update_weak_form_lhs = ufl.inner(u_trial, v_test) * dx(1)
velocity_update_weak_form_rhs = ufl.inner(
u_tent, v_test) * dx(1) - TIME_STEP_LENGTH * ufl.inner(ufl.grad(p_next), v_test) * dx(1)
velocity_update_weak_form_lhs = fem.form(velocity_update_weak_form_lhs)
velocity_update_weak_form_rhs = fem.form(velocity_update_weak_form_rhs)
velocity_update_weak_form_matrix = fem.petsc.assemble_matrix(
velocity_update_weak_form_lhs, bcs=velocity_boundry_condition)
velocity_update_weak_form_matrix.assemble()
velocity_update_weak_form_vector = fem.petsc.create_vector(
# Solver for step 1
solver1 = PETSc.KSP().create(domain.comm)
solver1.setOperators(momentum_weak_form_matrix)
pc1 = solver1.getPC()
pc1.setHYPREType("boomeramg")
# Solver for step 2
solver2 = PETSc.KSP().create(domain.comm)
solver2.setOperators(pressure_possion_weak_form_matrix)
solver2.setType(PETSc.KSP.Type.BCGS)
pc2 = solver2.getPC()
pc2.setHYPREType("boomeramg")
# Solver for step 3
solver3 = PETSc.KSP().create(domain.comm)
solver3.setOperators(velocity_update_weak_form_matrix)
pc3 = solver3.getPC()
OFF_SCREEN = False
u_plotter = pyvista.Plotter(
window_size=[1024, 1024], off_screen=OFF_SCREEN)
u_plotter.open_gif("hassan.gif")
u_topology, u_cell_types, u_geometry = dolfinx.plot.create_vtk_mesh(domain)
mesh_grid = pyvista.UnstructuredGrid(u_topology, u_cell_types, u_geometry)
u_plotter.add_mesh(mesh_grid, show_edges=True)
u_grid = pyvista.UnstructuredGrid(u_topology, u_cell_types, u_geometry)
values = np.zeros((u_geometry.shape[0], 3), dtype=np.float64)
values[:, :len(u_next)] = u_next.x.array.real.reshape(
(u_geometry.shape[0], len(u_next)))
u_grid["u"] = values
glyphs = u_grid.glyph(orient="u", factor=0.1)
u_plotter.add_mesh(glyphs)
u_plotter.view_xy()
if not OFF_SCREEN:
u_plotter.show(interactive_update=True)
for t in tqdm(range(N_TIME_STEPS)):
# Step 1: Tentative veolcity step
with momentum_weak_form_vector.localForm() as loc_1:
loc_1.set(0)
fem.petsc.assemble_vector(
momentum_weak_form_vector, momentum_weak_form_rhs)
fem.petsc.apply_lifting(momentum_weak_form_vector, [
momentum_weak_form_lhs], [velocity_boundry_condition])
momentum_weak_form_vector.ghostUpdate(
addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE)
fem.petsc.set_bc(momentum_weak_form_vector, velocity_boundry_condition)
solver1.solve(momentum_weak_form_vector, u_tent.vector)
u_tent.x.scatter_forward()
# Step 2: Pressure corrrection step
with pressure_possion_weak_form_vector.localForm() as loc_2:
loc_2.set(0)
pressure_possion_weak_form_vector, pressure_possion_weak_rhs)
# fem.petsc.apply_lifting(pressure_possion_weak_form_vector, [pressure_possion_weak_lhs])
# pressure_possion_weak_form_vector.ghostUpdate(addv=PETSc.InsertMode.ADD_VALUES, mode=PETSc.ScatterMode.REVERSE)
# fem.petsc.set_bc(pressure_possion_weak_form_vector)
solver2.solve(pressure_possion_weak_form_vector, p_next.vector)
p_next.x.scatter_forward()
# # Step 3: Velocity correction step
with velocity_update_weak_form_vector.localForm() as loc_3:
loc_3.set(0)
velocity_update_weak_form_vector, velocity_update_weak_form_rhs)
velocity_update_weak_form_vector.ghostUpdate(
solver3.solve(velocity_update_weak_form_vector, u_next.vector)
u_next.x.scatter_forward()
u_prev.x.array[:] = u_next.x.array[:]
# p_.x.array[:] = p_.x.array[:]
# u_plotter.add_mesh(mesh_grid, show_edges=True, color="#222222")
updated_glyphs = u_grid.glyph(orient="u", factor=0.1)
glyphs.copy_from(updated_glyphs)
if not OFF_SCREEN:
u_plotter.write_frame()
u_plotter.close()
if __name__ == "__main__":
main()
can you please help me with it?
