The Expression you’ve written encapsulates C/C++ code which has variables which have not been declared or provided to the constructor (specifically c). Furthermore ln is not in the standard library. I suspect you mean to use std::log.
It seems like you’re still mixing up the pythonic ufl symbolic formulation with C/C++ code, specifically in your variable c = variable(c).
I’m not sure why you want to use pure C/C++ code wrapped in an Expression since you could evaluate your terms with, e.g., ufl.ln(c). Furthermore this will allow ufl to automatically compute the directional derivative should you wish to use Newton’s iterative method.
