You have non-matching brackets, which is indicated by the stack trace. You should include that for the next example.
I.e.
Expression("(sqrt(pow(x[0], 2) + pow(x[1], 2) + pow(x[2], 2))/sqrt( 1 + (pow(x[0], 2) + pow(x[1], 2) + pow(x[2], 2))/ pow(12.2, 2))", degree = 2)
returns
------------------ Start compiler output ------------------------
/tmp/tmputhn1tq1/dolfin_expression_c9f29955407837c29ad0faeaff629795.cpp: In member function ‘virtual void dolfin::dolfin_expression_c9f29955407837c29ad0faeaff629795::eval(Eigen::Ref<Eigen::Matrix<double, -1, 1> >, Eigen::Ref<const Eigen::Matrix<double, -1, 1> >) const’:
/tmp/tmputhn1tq1/dolfin_expression_c9f29955407837c29ad0faeaff629795.cpp:61:142: error: expected ‘)’ before ‘;’ token
61 | values[0] = (sqrt(pow(x[0], 2) + pow(x[1], 2) + pow(x[2], 2))/sqrt( 1 + (pow(x[0], 2) + pow(x[1], 2) + pow(x[2], 2))/ pow(12.2, 2));
/tmp/tmputhn1tq1/dolfin_expression_c9f29955407837c29ad0faeaff629795.cpp:61:23: note: to match this ‘(’
------------------- End compiler output ------------------------
Compilation failed! Sources, command, and errors have been written to: /root/shared/jitfailure-dolfin_expression_c9f29955407837c29ad0faeaff629795
File "/usr/lib/python3/dist-packages/dolfin/jit/jit.py", line 165, in compile_class
module, signature = dijitso_jit(cpp_data, module_name, params,
File "/usr/lib/python3/dist-packages/dolfin/jit/jit.py", line 47, in mpi_jit
File "/usr/lib/python3/dist-packages/dolfin/jit/jit.py", line 103, in dijitso_jit
return dijitso.jit(*args, **kwargs)
File "/usr/lib/python3/dist-packages/dijitso/jit.py", line 216, in jit
raise DijitsoError("Dijitso JIT compilation failed, see '%s' for details"
dijitso.jit.DijitsoError: Dijitso JIT compilation failed, see '/root/shared/jitfailure-dolfin_expression_c9f29955407837c29ad0faeaff629795' for details
while
Expression("sqrt(pow(x[0], 2) + pow(x[1], 2) + pow(x[2], 2))/sqrt( 1 + (pow(x[0], 2) + pow(x[1], 2) + pow(x[2], 2))/ pow(12.2, 2))", degree = 2)
works (removing the first left bracket).
