RuntimeError: Use 'Function.copy(deepcopy=True)' for copying
i am trying to compute a program to identify the orientation of fibers at any time in tensor form of form 3x3 on a cubic mesh.
So am trying to define a TensorFunctionSpace for the fiber orientation and a VectorFunctionSpace one for the Matrix (Material). I have the following beginning of my code:
T = 5.0            # final time
num_steps = 100    # number of time steps
eps = 0.01         # diffusion coefficient
# Read mesh
mesh = UnitSquareMesh(8, 8, "left/right")
# Define function spaces
W = VectorFunctionSpace(mesh, 'P', 2)
V = Function(TensorFunctionSpace(mesh, "Lagrange", 1, shape = (3,3)))
#Define boundaries
inflow  = 'near(x[0], 0)'
walls   = 'near(x[1], 0) || near(x[1], 1)'
#Define boundary conditions
bco_inflow = DirichletBC(W, Constant((0,0)), inflow)
bco_noslip = DirichletBC(W, Constant((0, 0)), walls)
bco = [bco_noslip]
#Define Test-function
v = TestFunction(W)
# Define functions for velocity and orientations
u = Function(W)    #velocity
o = Function(V)   #orientation
o_n = Function(V)  #orientation at next time step
I get following Error Message:
What does that mean? I am in advance sorry for bad coding, really a newbie to FEniCs and programming.
Thanks in advance.
If you remove the function-wrapper here, everything should work nicely.
Thanks, it worked out.
