Solve Method with TensorFunctionSpace
Hi, everyone!
I’ve been working with FEniCS for some time, and I’m trying to implement a modified version of the IPCS scheme, related to the Navier-Stokes equations, to a continuum model for active nematics.
Having said that, my problem is the following, I’ve a dynamical equation for a symmetric and traceless 2x2 tensor. But when I use the method SOLVE I get the following error:
solve(): incompatible function arguments. The following argument types are supported:
1. (A: dolfin.cpp.la.GenericLinearOperator, x: dolfin.cpp.la.GenericVector, b: dolfin.cpp.la.GenericVector, method: str = ‘lu’, preconditioner: str = ‘none’) → int
Invoked with: <dolfin.cpp.la.Matrix object at 0x7f487ba38f90>, Coefficient(FunctionSpace(Mesh(VectorElement(FiniteElement(‘Lagrange’, triangle, 1), dim=2), 7), TensorElement(FiniteElement(‘Lagrange’, triangle, 2), shape=(2, 2), symmetry={(1, 0): (0, 1)})), 17), <dolfin.cpp.la.Vector object at 0x7f487ad19a90>, ‘bicgstab’, ‘hypre_amg’
Here I provide some parts of my code:
Vector = VectorElement(‘Lagrange’, mesh.ufl_cell(), 2);
T = TensorFunctionSpace(mesh, ‘Lagrange’, 2, symmetry = True);
V = FunctionSpace(mesh, Vector)
#—Define strain rate tensor symmetric gradient
return sym(nabla_grad(u))
#—Define vorticity tensor
def omega(u):
return skew(nabla_grad(u))
#—Define L_ij tensor
def L(epsilon, omega):
L1 = 1./3 * (dot(lamb * epsilon + omega, Identity(len(u))))
L2 = 1./3 * (dot(Identity(len(u)), lamb * epsilon + omega))
return L1 + L2
#—Define N_ij tensor
def N(epsilon, omega, Q):
N1 = dot(lamb * epsilon + omega, Q)
N2 = 1/3. *dot(lamb * epsilon - omega, Q)
N3 = -2/3. * inner(Q, nabla_grad(u)) * lamb * (Q + Identity(len(u)))
return N1 + N2 #+ N3
#—Define variational problem for step 1
F1 = inner((Q - Q_n) / k, psi)*dx + inner(dot(u_n, nabla_grad(Q_n)), psi)*dx \
  • inner(nabla_grad(Q_n), nabla_grad(psi))*dx \
  • inner(L(epsilon(u_n), omega(u_n)), psi)*dx \
  • inner(N(epsilon(u_n), omega(u_n), Q_n), psi)*dx
a1 = lhs(F1)
L1 = rhs(F1)
A1 = assemble(a1)
Time-stepping
t = 0
for n in range(ns):
# Update current time
b1 = assemble(L1)
solve(A1, Q_, b1, 'bicgstab', 'hypre_amg')
Hope you can help me.
Thanks!
Make sure that the code is formatted with markdown syntax, ie.
```python
# add code here
Also make sure that the code can reproduce the issue,
I cant spot what Q_ is.
If it is a function, could you try to send in Q_.vector() instead?
Yep, sorry with the syntax, I’ll fix it in the following discussions.
Here’s some context:
#---Define mesh and functions spaces
mesh = UnitSquareMesh(8,8)
Vector = VectorElement('Lagrange', mesh.ufl_cell(), 2);
T = TensorFunctionSpace(mesh, 'Lagrange', 2, symmetry = True);
Then I define the trial and test functions over the functions spaces
#---Define trial and test functions
Q   = TrialFunction(T)
psi = TestFunction(T)
u   = TrialFunction(V)
v   = TestFunction(V)
#---Define functions for sulutions at previous and current time steps
Q_n = Function(T)
Q_   = Function(T)
u_n  = Function(V)
u_    = Function(V)
#---Define expressions used in variational forms
lamb = Constant(lamb)
xi   = Constant(xi)
eta  = Constant(eta)
k  = Constant(dt)
#---Define strain rate tensor symmetric gradient
#---Define vorticity tensor
def omega(u):
#---Define L_ij tensor
    return L1 + L2
#---Define N_ij tensor
#---Define variational problem for step 1
   + inner(nabla_grad(Q_n), nabla_grad(psi))*dx  \
   - inner(L(epsilon(u_n), omega(u_n)), psi)*dx   \
   + inner(N(epsilon(u_n), omega(u_n), Q_n), psi)*dx
a1 = lhs(F1)
L1 = rhs(F1)
A1 = assemble(a1)
# Time-stepping
t = 0
for n in range(ns):
    # Step 1: First variational problem
    b1 = assemble(G1)
And in relation with your question, I’m not sure of what the method vector() does to the equation, but I could try with that.
.vector() accesses the GenericVector that contains the degrees of freedom (unknowns) that you solve for.
This would make it match the input
That fix the output, but now I’ve a different problem; the output it’s just the null vector, for every step in time. Here’s the code fixed (with the new problem), sorry for the basic questions
# Sub domain for Periodic boundary condition
    # Left boundary is "target domain" G
        return bool(x[0] < DOLFIN_EPS and x[0] > -DOLFIN_EPS and on_boundary)
    # Map right boundary (H) to left boundary (G)
    def map(self, x, y):
        y[0] = x[0] - 1.0
        y[1] = x[1]
pbc = PeriodicBoundary()
#---Tensor-Vector elemet
#---Define the mesh
#Tensor = TensorElement('Lagrange', mesh.ufl_cell(), 2, symmetry = True)
T = TensorFunctionSpace(mesh, 'Lagrange', 2, symmetry = True, constrained_domain=pbc);
V = FunctionSpace(mesh, Vector, constrained_domain=pbc)
#---Declare constants of the model
#alpha = ; alpha = 1 / Pe
#beta = ; beta = 1 / Chi
eta  = 0.1      #---viscosity
xi   = 0.1      #---activity parameter
lamb = 0.1      #---tumbling parameter
T    = 1.0      #---final time
ns   = 1000     #---number of time steps
dt   = T / ns   #---time step size
v   = TestFunction(V)
Q_n = Function(T)
Q_  = Function(T)
u_n = Function(V)
u_  = Function(V)
xi   = Constant(xi)
eta  = Constant(eta)
k  = Constant(dt)
def omega(u):
    return L1 + L2
a1 = lhs(F1)
L1 = rhs(F1)
A1 = assemble(a1)
# Time-stepping
t = 0
for n in range(ns):
    b1 = assemble(L1)
    #[bc.apply(b1) for bc in bcu]
    solve(A1, Q_.vector(), b1, 'bicgstab', 'hypre_amg')
    # Update previous solution
    Q_n.assign(Q_)
    u_n.assign(u_)
    # Update progress bar
    set_log_level(LogLevel.ERROR)
    print('Q max:', Q_.vector().get_local().max())
And the output is:
Q max: 0.0
Q max: 0.0
Q max: 0.0
Q max: 0.0
Q max: 0.0
Q max: 0.0
Q max: 0.0
Q max: 0.0
Im not really sure what you expect. The initial u_n and Q_n are Zero, so all terms with those are Zero in F1
Thus you are only left with inner(Q/k,psi)*dx, with no Dirichlet conditions, Which has the solution 0.
Oh, I see, then I should work with the Dirichlet conditions.
And finally, is there a way in which I start with u_n and Q_n different from zero?
In Navier-Stokes you have an input flow which makes sure those values are not zero, but in my problem, I’m not sure how to implement that.
Thanks a lot!
You can interpolate or project any function into u_n and Q_n.
