Same a similar PDE multiple times
Hi, I have a problem where I need to solve a similar PDE a lot of times. Consider the following “minimal” example:
Let us say that we have solved the PDE problem of the general FEniCSx tutorial \begin{align} -\nabla^2 u(\mathbf{x}) &= f(\mathbf{x})&&\mathbf{x} \in \Omega\\ u(\mathbf{x}) &= u_D(\mathbf{x})&& \mathbf{x} \in \partial\Omega\\ f(\mathbf{x}) & = -6\\ u_D(\mathbf{x})&=1+x^2+2y^2 \\ \Omega&=[0,1]\times [0,1] \end{align}
Say now that I want to repeat the above calculation in the same geometry and with the same finite elements but with different source and different boundary conditions (still of the Dirichlet type though).
Now, since, if I am not terribly wrong, only the load vector L and the bc object change and not the inner product a is it possible to find the solution of the new problem without a full calculation, i.e. by the action of the inverse of the stiffness matrix that was calculate when the initial PDE was solved?
Also, is the same possible for more complex problems like the static Navier Stokes, for example?
The minimal code follows.
domain = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 10, 10, dolfinx.mesh.CellType.quadrilateral)
V = dolfinx.fem.FunctionSpace(domain, ("CG", 1))
uD = dolfinx.fem.Function(V)
uD.interpolate(lambda x: 1 + x[0]**2 + 2 * x[1]**2)
tdim = domain.topology.dim
fdim = tdim - 1
domain.topology.create_connectivity(domain.topology.dim-1, domain.topology.dim)
boundary_facets = dolfinx.mesh.exterior_facet_indices(domain.topology)
boundary_dofs = dolfinx.fem.locate_dofs_topological(V, domain.topology.dim-1, boundary_facets)
dof_coordinates = V.tabulate_dof_coordinates()[boundary_dofs]
bc = dolfinx.fem.dirichletbc(uD, boundary_dofs)
u = ufl.TrialFunction(V)
f = dolfinx.fem.Constant(domain, ScalarType(-6))
a = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = f * v * ufl.dx
problem = dolfinx.fem.petsc.LinearProblem(a, L, bcs=[bc])
uh = problem.solve()
I apologise for asking something that seems naive.
The source is available here: https://github.com/FEniCS/dolfinx/blob/main/python/dolfinx/fem/petsc.py#L549-L583
You could modify this for your own needs, only assembling the matrix once. Like you say, if feasible, it’s a good idea only to change the RHS vector and apply BCs. That way you can preserve the preconditioner/factorisation of the matrix. It makes things vastly cheaper solving a problem with the same LHS many times.
See also KSPSetReusePreconditioner — PETSc 3.19.3 documentation.
Thanks, I will try to see how to modify the source code accordingly to make my calculation cheaper.
Thanks again!
