Hi all,
I am trying to deal with very interesting problem. I solve the heat equation and I want to stop my solution once I reach some threshold value of temperature for the specified point at the domain. Using this demo and this demo, I managed to get this following MWE:
import matplotlib as mpl
from dolfinx import geometry
from dolfinx import fem, mesh, io, plot
from dolfinx.fem.petsc import assemble_vector, assemble_matrix, create_vector, apply_lifting, set_bc
# Define temporal parameters
t = 0 # Start time
T = 1.0 # Final time
num_steps = 50
# Define mesh
nx, ny = 50, 50
domain = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([-2, -2]), np.array([2, 2])],
[nx, ny], mesh.CellType.triangle)
V = fem.functionspace(domain, ("Lagrange", 1))
def initial_condition(x, a=5):
return np.exp(-a * (x[0]**2 + x[1]**2))
u_n = fem.Function(V)
u_n.name = "u_n"
u_n.interpolate(initial_condition)
# Create boundary condition
boundary_facets = mesh.locate_entities_boundary(
domain, fdim, lambda x: np.full(x.shape[1], True, dtype=bool))
bc = fem.dirichletbc(PETSc.ScalarType(0), fem.locate_dofs_topological(V, fdim, boundary_facets), V)
xdmf = io.XDMFFile(domain.comm, "diffusion.xdmf", "w")
xdmf.write_mesh(domain)
# Define solution variable, and interpolate initial solution for visualization in Paraview
uh = fem.Function(V)
uh.name = "uh"
uh.interpolate(initial_condition)
xdmf.write_function(uh, t)
# ## Variational problem and solver
# As in the previous example, we prepare objects for time dependent problems, such that we do not have to recreate data-structures.
f = fem.Constant(domain, PETSc.ScalarType(0))
a = u * v * ufl.dx + dt * ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = (u_n + dt * f) * v * ufl.dx
# ## Preparing linear algebra structures for time dependent problems
# We note that even if `u_n` is time dependent, we will reuse the same function for `f` and `u_n` at every time step. We therefore call `dolfinx.fem.form` to generate assembly kernels for the matrix and vector.
bilinear_form = fem.form(a)
linear_form = fem.form(L)
# We observe that the left hand side of the system, the matrix $A$ does not change from one time step to another, thus we only need to assemble it once. However, the right hand side, which is dependent on the previous time step `u_n`, we have to assemble it every time step. Therefore, we only create a vector `b` based on `L`, which we will reuse at every time step.
A = assemble_matrix(bilinear_form, bcs=[bc])
b = create_vector(linear_form)
# ## Using petsc4py to create a linear solver
# As we have already assembled `a` into the matrix `A`, we can no longer use the `dolfinx.fem.petsc.LinearProblem` class to solve the problem. Therefore, we create a linear algebra solver using PETSc, assign the matrix `A` to the solver, and choose the solution strategy.
solver.setOperators(A)
p_center = np.array([0.,0.,0.])
threshold = 0.5
bb_tree = geometry.bb_tree(domain, domain.topology.dim)
cell = []
points_on_proc = []
cell_candidates = geometry.compute_collisions_points(bb_tree, p_center.T)
colliding_cells = geometry.compute_colliding_cells(domain, cell_candidates, p_center.T)
if len(colliding_cells.links(0)) > 0:
points_on_proc.append(p_center)
cell.append(colliding_cells.links(0)[0])
points_on_proc = np.array(points_on_proc, dtype=np.float64)
while uh.eval(points_on_proc, cell) < threshold:
with b.localForm() as loc_b:
loc_b.set(0)
assemble_vector(b, linear_form)
apply_lifting(b, [bilinear_form], [[bc]])
set_bc(b, [bc])
# Solve linear problem
solver.solve(b, uh.x.petsc_vec)
uh.x.scatter_forward()
u_n.x.array[:] = uh.x.array
# Write solution to file
xdmf.close()
I am trying to make this code parallel but obviously I fail to handle the values near the while condition. Surprisingly, it runs fine for 2 procs (I think the point just falls into the region where two domains linked) but 3 or more procs give:
ValueError: The truth value of an empty array is ambiguous. Use `array.size > 0` to check that an array is not empty.
Error is very clear indeed. I have tried broadcasting the point and cell data over the processes but it did not work. It seems like there is something going on with eval function which I miss to see.
How should I approach this problem? Any comments would be very appreciated.
