Save velocity at outlet of 3D mesh
I have 3D pipe mesh and I am solving Navier-Stokes equation with projection method.
I would like to save velocity at the outlet over time as h5 file but I am not sure how to do it.
I have access to the velocity all over the domain but how can I save the velocity only at the outlet ?
I created the mesh with gmsh and marked outlet with physical group.
Any idea would be much appreciated.
Best,
Hello, you might be better off saving the whole velocity field and then extracting the outlet in Paraview or similar post-processing software. Is that unfeasible for any reason?
Thanks for the response ! I could save the entire velocity but I think it’s a waste of memory since I only need to save at the outlet.
Possibly a waste of memory, yes. In this case you might have a look at classes like SubMesh and BoundaryMesh. I’ve never used them so I don’t know if they do what you need.
I finally solved this problem by using a function from fenicstools called Interpolation nonmatching mesh, and I did use SubMesh and BoundaryMesh. One sad thing is that SubMesh does not support parallel computing.
Thank you for the answer anyway !
