Saving to HDF5 doesn't work on docker image of dolfinadjoint on Linux
I’m using docker image of dolfinadjoint on Linux by
docker run --name parallel -ti -w /home/fenics/shared -v /home/Dockerpyadjoint:/home/fenics/shared quay.io/dolfinadjoint/pyadjoint:latest
and I’d like to save an expression to HDF5 file running the MWE below by python3 filename.py:
mesh = UnitSquareMesh(10,10)
V = FunctionSpace(mesh,"CG",1)
x = SpatialCoordinate(mesh)
f = project(x[0]*x[1],V)
fFile = HDF5File(MPI.comm_world,"f.h5","w")
fFile.write(f,"/f")
fFile.close()
But it throws an exception:
HDF5-DIAG: Error detected in HDF5 (1.10.0-patch1) MPI-process 0:
  #000: ../../../src/H5F.c line 491 in H5Fcreate(): unable to create file
    major: File accessibilty
    minor: Unable to open file
  #001: ../../../src/H5Fint.c line 1111 in H5F_open(): unable to open file: time = Wed Dec  2 14:56:03 2020
, name = 'f.h5', tent_flags = 13
  #002: ../../../src/H5FD.c line 812 in H5FD_open(): open failed
    major: Virtual File Layer
    minor: Unable to initialize object
  #003: ../../../src/H5FDsec2.c line 348 in H5FD_sec2_open(): unable to open file: name = 'f.h5', errno = 13, error message = 'Permission denied', flags = 13, o_flags = 242
  #000: ../../../src/H5L.c line 871 in H5Lexists(): not a location
    major: Invalid arguments to routine
    minor: Inappropriate type
  #001: ../../../src/H5Gloc.c line 253 in H5G_loc(): invalid object ID
    minor: Bad value
Running the same code on the same docker image on windows and jupyter it works fine.
Am I doing anything wrong?
Thanks in advance!
Cannot reproduce using the following on ubuntu 20.04:
docker run --rm -ti -w /home/fenics/shared -v $PWD:/home/fenics/shared quay.io/dolfinadjoint/pyadjoint:latest
python3 -c 'from fenics import *
fFile.write(f,"/f")
fFile.close()'
I would say this is an issue with the folder that you are sharing (I would bet somewhere in the error message it says permission denied.
You are completely right! Thank you!
