Scaling of condition number in 1D, 2D, and 3D
My understanding is that the condition number (for stiffness matrix of poisson) should scale like
h^-2. Here is a MWE, more or less from the demos, where I run this for a few levels of refinement using nx = [10,20,40,80,…]. I do this for a 1D, 2D, and 3D unit mesh. The 1D and 2D scale no problem (by a factor of 4 for each halving of h), however in 3D it scales by a factor of 8… or h^-3. The smallest eigenvalue is shrinking faster than h^2 in 3D.
What am I missing? (I hope it is very obvious)
from slepc4py import SLEPc
nx=10
#mesh = UnitIntervalMesh(nx)
#mesh = UnitSquareMesh(nx,nx)
mesh = UnitCubeMesh(nx,nx,nx)
a = inner(grad(v), grad(u)) * dx
bc = DirichletBC(V, Constant(1), "on_boundary")
A = PETScMatrix()
assemble(a, tensor=A)
bc.apply(A)
eigenSolver = SLEPcEigenSolver(A)
eigenSolver.parameters["spectrum"] = "smallest magnitude"
eigenSolver.solve(0)   # compute one eigenvalue
min_eig = eigenSolver.get_eigenvalue(0)[0]
eigenSolver.parameters["spectrum"] = "largest magnitude"
max_eig = eigenSolver.get_eigenvalue(0)[0]
print(max_eig/min_eig)
Results from code:
#1D
39.86345818905796
161.44763876950535
647.7890115674564
2593.155660451755
#2D
39.86345818898851
161.44763880102045
647.7890114777815
2593.155660273267
#3D
39.863458189052565
270.74606466283205
2162.6300382580944
17294.371068624547
For anyone who comes across this after me.
This is a consequence of strong boundary enforcement. For some reason it is apparent in 3D, your largest eigenvalue doesn’t scale like it should because of how your system is modified with bc.apply(A). Either perform the eigenvalue computation on a reduced system (remove row/columns of strong Dirichlet dofs) or apply Dirichlet conditions weakly.
It would likely benefit you to use assemble_system which preserves symmetry of the underlying operator when applying boundary conditions. Particularly for the efficient computation of eigenvalue approximations.
This ambiguity (unless you read the documentation in detail) is a “feature” of legacy DOLFIN, and one of many reasons I highly recommend using DOLFINx instead of legacy DOLFIN.
See, e.g.,
Good catch
The issue lies here; (strong) BC enforcement in FEM zeros-out rows and columns in the stiffness matrix and sets a 1 at that spot in the diagonal. Consequently, there will be repeating eigenvalues of 1 in your spectrum.
While the condition number of the stiffness matrix does not depend on spatial dimension, the value of the smallest and largest eigenvalues do. (Not entirely sure at which rate, but they decrease with d). By the time you moved to 3D, the largest eigenvalue becomes so small, that the 1 dominates ..
A ‘fix’ in dolfinx is to alter the value set on the diagonal through A = assemble_matrix(fem.form(a), bcs=[bc], diag=some_value). To do that properly you’d have to scale that similarly to how the largest and smallers eigenvalues scale. Or you set it to zero, and use look for the smallest nonzero eigenvalue (see Exercise 7: Use of Deflation Subspaces — SLEPc 3.24.1 documentation)
Here is a dolfinx translated code snippet to play with:
from dolfinx import fem, mesh
from dolfinx.fem.petsc import assemble_matrix
d = 2
nx = 10
diag = 0.1
match d:
    case 1:
        domain = mesh.create_unit_interval(MPI.COMM_WORLD, nx)
    case 2:
        domain = mesh.create_unit_square(MPI.COMM_WORLD, nx, nx)
    case 3:
        domain = mesh.create_unit_cube(MPI.COMM_WORLD, nx, nx, nx)
V = fem.functionspace(domain, ("Lagrange", 1))
u = ufl.TrialFunction(V)
a = ufl.inner(ufl.grad(v), ufl.grad(u)) * ufl.dx
# Define boundary condition
domain.topology.create_connectivity(domain.topology.dim-1, domain.topology.dim)
boundary_dofs = fem.locate_dofs_topological(V, domain.topology.dim - 1, boundary_facets)
bc = fem.dirichletbc(PETSc.ScalarType(0), boundary_dofs, V)
# Assemble matrix
A = assemble_matrix(fem.form(a), bcs=[bc], diag=diag)
# Solve for eigenvalues
E = SLEPc.EPS().create(MPI.COMM_WORLD)
E.setOperators(A)
# Find smallest magnitude eigenvalue
E.setWhichEigenpairs(SLEPc.EPS.Which.SMALLEST_MAGNITUDE)
E.solve()
min_eig = E.getEigenpair(0).real
# Find largest magnitude eigenvalue
E.setWhichEigenpairs(SLEPc.EPS.Which.LARGEST_MAGNITUDE)
E.solve()
max_eig = E.getEigenpair(0).real
print(max_eig/min_eig, max_eig, min_eig)
To further supply on top of @Stein’s code and comments, you can also extract a sub-matrix from your PETSc matrix, and use that as input to your eigenvalue problem.
I here illustrate this with standard PETSc KSP, but that is just to show the procedure:
# # Extract a sub matrix without boundary condition dofs and use it with PETSc
# Author: Jørgen S. Dokken
# SPDX License identifier: MIT
import dolfinx.fem.petsc
M = 30
mesh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, M, M)
u, v= ufl.TrialFunction(V), ufl.TestFunction(V)
a = dolfinx.fem.form(ufl.inner(u, v) * ufl.dx)
exterior_facets = dolfinx.mesh.exterior_facet_indices(mesh.topology)
exterior_dofs = dolfinx.fem.locate_dofs_topological(V, mesh.topology.dim-1, exterior_facets)
bcs = [dolfinx.fem.dirichletbc(0., exterior_dofs, V)]
A = dolfinx.fem.petsc.assemble_matrix(a, bcs, diag=0.0)
num_dofs_local = V.dofmap.index_map.size_local*V.dofmap.index_map_bs
num_ghosts = V.dofmap.index_map.num_ghosts*V.dofmap.index_map_bs
not_dirichlet = np.full(num_dofs_local+num_ghosts, 1, dtype=np.int32)
not_dirichlet[exterior_dofs] = 0
idx_set = np.flatnonzero(not_dirichlet).astype(np.int32)
idx_set_row = idx_set[idx_set<num_dofs_local]
idx_set_col = idx_set[idx_set<num_dofs_local]
isx_row = PETSc.IS(A.getComm()).createGeneral(idx_set_row)
isx_col = PETSc.IS(A.getComm()).createGeneral(idx_set_col)
lgm_row = A.getLGMap()[0].applyIS(isx_row)
lgm_col = A.getLGMap()[1].applyIS(isx_col)
A_sub = A.createSubMatrix(lgm_row, lgm_col)
A_sub.assemble()
assert np.isclose(A.norm(0), A_sub.norm(0))
assert np.isclose(A.norm(2), A_sub.norm(2))
assert np.isclose(A.norm(3), A_sub.norm(3))
L = dolfinx.fem.form(ufl.inner(x[0]+2*x[1], v)*ufl.dx)
b = dolfinx.fem.petsc.assemble_vector(L)
b_sub = b.getSubVector(lgm_row)
ksp = PETSc.KSP().create(mesh.comm)
ksp.setOperators(A_sub)
ksp.setType("preonly")
ksp.setErrorIfNotConverged(True)
ksp.getPC().setType("lu")
ksp.getPC().setFactorSolverType("mumps")
ksp.getPC().getFactorMatrix().setMumpsIcntl(14, 1000)
x= b.duplicate()
x_sub = x.getSubVector(lgm_row)
ksp.solve(b_sub, x_sub)
x.restoreSubVector(lgm_row, x_sub)
uh = dolfinx.fem.Function(V)
x.copy(uh.x.petsc_vec)
uh.x.scatter_forward()
with dolfinx.io.VTXWriter(uh.function_space.mesh.comm, "u_sub.bp", [uh]) as bp:
    bp.write(0.0)
Thanks everyone for the informative feedback.
I’m stuck with legacy fenics for this problem. I will look for a lifting procedure using slepc in parallel.
As I am using the PETSc interface to extract the matrix, you could always achieve this in legacy fenics as well.
The symmetric approach of applying bcs in legacy happens through assemble_system.
This would give you an equivalent matrix to A in my post above (except for the diagonal values).
Then, you would have to create the not_dirichlet marker for the index set, i.e along the lines of:
mesh = UnitSquareMesh(10, 10)
L = inner(Constant((0,0)), v)*dx
bc = DirichletBC(V, (0.0, 0.0), "on_boundary")
exterior_dofs = np.array(list(bc.get_boundary_values().keys()))
im = V.dofmap().index_map()
num_dofs_local = im.size(im.MapSize.OWNED)
num_ghosts = im.size(im.MapSize.UNOWNED)
print(mesh.mpi_comm().rank, idx_set)
The rest should follow by assembling A, and getting the PETSc matrix with:
A_petsc = as_backend_type(A).mat()
