Dear @dokken
Thank you very much! For now I received an error (see below), but at least this is a good starting point. I expect that I just need to specify an older version of UFL?
Step 26/33 : RUN git clone https://github.com/FEniCS/fiat.git && git clone https://bitbucket.com/fenics-project/ffc.git && git clone https://github.com/FEniCS/ufl.git && git clone https://bitbucket.com/fenics-project/dolfin.git && git clone https://bitbucket.com/fenics-project/dijitso.git
---> Running in 8055e2f2b915
Cloning into 'fiat'...
Cloning into 'ffc'...
warning: redirecting to https://bitbucket.org/fenics-project/ffc.git/
Cloning into 'ufl'...
Cloning into 'dolfin'...
warning: redirecting to https://bitbucket.org/fenics-project/dolfin.git/
Cloning into 'dijitso'...
warning: redirecting to https://bitbucket.org/fenics-project/dijitso.git/
Removing intermediate container 8055e2f2b915
---> d0aaf02c7659
Step 27/33 : RUN cd fiat && pip3 install --no-cache-dir . && cd ../ufl && pip3 install --no-cache-dir . && cd ../dijitso && pip3 install --no-cache-dir . && cd ../ffc && pip3 install --no-cache-dir . && cd ../ && pip3 install --no-cache-dir ipython
---> Running in 3cb43140b9a2
Processing /src/fiat
Requirement already satisfied: numpy in /usr/local/lib/python3.8/dist-packages (from fenics-fiat==2019.2.0.dev0) (1.21.5)
Collecting sympy
Downloading sympy-1.9-py3-none-any.whl (6.2 MB)
Collecting mpmath>=0.19
Downloading mpmath-1.2.1-py3-none-any.whl (532 kB)
Building wheels for collected packages: fenics-fiat
Building wheel for fenics-fiat (setup.py): started
Building wheel for fenics-fiat (setup.py): finished with status 'done'
Created wheel for fenics-fiat: filename=fenics_fiat-2019.2.0.dev0-py3-none-any.whl size=125565 sha256=bd3035eaf34f7f99b2d041ecb7446a376973b8a63c4832a40a0e58517f5a2060
Stored in directory: /tmp/pip-ephem-wheel-cache-tjcrnng5/wheels/0e/a4/58/b60a9f631a851d2e5e598f319bd944d6fdb90a08f52843fbb7
Successfully built fenics-fiat
Installing collected packages: mpmath, sympy, fenics-fiat
Successfully installed fenics-fiat-2019.2.0.dev0 mpmath-1.2.1 sympy-1.9
Processing /src/ufl
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Preparing wheel metadata: started
Preparing wheel metadata: finished with status 'done'
Requirement already satisfied: numpy in /usr/local/lib/python3.8/dist-packages (from fenics-ufl==2021.2.0.dev0) (1.21.5)
Building wheels for collected packages: fenics-ufl
Building wheel for fenics-ufl (PEP 517): started
Building wheel for fenics-ufl (PEP 517): finished with status 'done'
Created wheel for fenics-ufl: filename=fenics_ufl-2021.2.0.dev0-py3-none-any.whl size=258220 sha256=d210c9f2e488d43ca62ca6eaf3471fb8a71549e0e97a1303392d7a6ed68e2237
Stored in directory: /tmp/pip-ephem-wheel-cache-rx30jmt1/wheels/64/e0/64/0f85376f52a232f1b2507dc4fb041bd35465f4c4c4838a77ee
Successfully built fenics-ufl
Installing collected packages: fenics-ufl
Successfully installed fenics-ufl-2021.2.0.dev0
Processing /src/dijitso
Requirement already satisfied: numpy in /usr/local/lib/python3.8/dist-packages (from fenics-dijitso==2019.2.0.dev0) (1.21.5)
Building wheels for collected packages: fenics-dijitso
Building wheel for fenics-dijitso (setup.py): started
Building wheel for fenics-dijitso (setup.py): finished with status 'done'
Created wheel for fenics-dijitso: filename=fenics_dijitso-2019.2.0.dev0-py3-none-any.whl size=46773 sha256=981cc45cf0326f6c4302ec37811aa7cb88bcba24cc6886e414781e40b7b2a971
Stored in directory: /tmp/pip-ephem-wheel-cache-0v_d9p2z/wheels/3b/07/be/4f674135a1eb5a5fd8495e76d4aa65337f282a6dbefa34e06d
Successfully built fenics-dijitso
Installing collected packages: fenics-dijitso
Successfully installed fenics-dijitso-2019.2.0.dev0
Processing /src/ffc
Requirement already satisfied: fenics-dijitso<2019.3,>=2019.2.0.dev0 in /usr/local/lib/python3.8/dist-packages (from fenics-ffc==2019.2.0.dev0) (2019.2.0.dev0)
Requirement already satisfied: fenics-fiat<2019.3,>=2019.2.0.dev0 in /usr/local/lib/python3.8/dist-packages (from fenics-ffc==2019.2.0.dev0) (2019.2.0.dev0)
Requirement already satisfied: fenics-ufl>=2021.1.0 in /usr/local/lib/python3.8/dist-packages (from fenics-ffc==2019.2.0.dev0) (2021.2.0.dev0)
Requirement already satisfied: numpy in /usr/local/lib/python3.8/dist-packages (from fenics-ffc==2019.2.0.dev0) (1.21.5)
Requirement already satisfied: sympy in /usr/local/lib/python3.8/dist-packages (from fenics-fiat<2019.3,>=2019.2.0.dev0->fenics-ffc==2019.2.0.dev0) (1.9)
Requirement already satisfied: mpmath>=0.19 in /usr/local/lib/python3.8/dist-packages (from sympy->fenics-fiat<2019.3,>=2019.2.0.dev0->fenics-ffc==2019.2.0.dev0) (1.2.1)
Building wheels for collected packages: fenics-ffc
Building wheel for fenics-ffc (setup.py): started
Building wheel for fenics-ffc (setup.py): finished with status 'done'
Created wheel for fenics-ffc: filename=fenics_ffc-2019.2.0.dev0-py3-none-any.whl size=363381 sha256=70289384030187795c17488de42a086ad9bae2767db91975f9d8f44933f1ba73
Stored in directory: /tmp/pip-ephem-wheel-cache-nk9tkk4r/wheels/92/85/95/ae76957910a5f39a8c2cd460f1d81d3647623cecea65c73f27
Successfully built fenics-ffc
Installing collected packages: fenics-ffc
Successfully installed fenics-ffc-2019.2.0.dev0
Collecting ipython
Downloading ipython-8.1.1-py3-none-any.whl (750 kB)
Requirement already satisfied: setuptools>=18.5 in /usr/lib/python3/dist-packages (from ipython) (45.2.0)
Collecting pexpect>4.3; sys_platform != "win32"
Downloading pexpect-4.8.0-py2.py3-none-any.whl (59 kB)
Collecting matplotlib-inline
Downloading matplotlib_inline-0.1.3-py3-none-any.whl (8.2 kB)
Collecting pygments>=2.4.0
Downloading Pygments-2.11.2-py3-none-any.whl (1.1 MB)
Collecting pickleshare
Downloading pickleshare-0.7.5-py2.py3-none-any.whl (6.9 kB)
Collecting stack-data
Downloading stack_data-0.2.0-py3-none-any.whl (21 kB)
Requirement already satisfied: decorator in /usr/lib/python3/dist-packages (from ipython) (4.4.2)
Collecting backcall
Downloading backcall-0.2.0-py2.py3-none-any.whl (11 kB)
Collecting jedi>=0.16
Downloading jedi-0.18.1-py2.py3-none-any.whl (1.6 MB)
Collecting traitlets>=5
Downloading traitlets-5.1.1-py3-none-any.whl (102 kB)
Collecting prompt-toolkit!=3.0.0,!=3.0.1,<3.1.0,>=2.0.0
Downloading prompt_toolkit-3.0.28-py3-none-any.whl (380 kB)
Collecting ptyprocess>=0.5
Downloading ptyprocess-0.7.0-py2.py3-none-any.whl (13 kB)
Collecting pure-eval
Downloading pure_eval-0.2.2-py3-none-any.whl (11 kB)
Collecting asttokens
Downloading asttokens-2.0.5-py2.py3-none-any.whl (20 kB)
Collecting executing
Downloading executing-0.8.3-py2.py3-none-any.whl (16 kB)
Collecting parso<0.9.0,>=0.8.0
Downloading parso-0.8.3-py2.py3-none-any.whl (100 kB)
Collecting wcwidth
Downloading wcwidth-0.2.5-py2.py3-none-any.whl (30 kB)
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from asttokens->stack-data->ipython) (1.14.0)
Installing collected packages: ptyprocess, pexpect, traitlets, matplotlib-inline, pygments, pickleshare, pure-eval, asttokens, executing, stack-data, backcall, parso, jedi, wcwidth, prompt-toolkit, ipython
Attempting uninstall: pygments
Found existing installation: Pygments 2.3.1
Not uninstalling pygments at /usr/lib/python3/dist-packages, outside environment /usr
Can't uninstall 'Pygments'. No files were found to uninstall.
Successfully installed asttokens-2.0.5 backcall-0.2.0 executing-0.8.3 ipython-8.1.1 jedi-0.18.1 matplotlib-inline-0.1.3 parso-0.8.3 pexpect-4.8.0 pickleshare-0.7.5 prompt-toolkit-3.0.28 ptyprocess-0.7.0 pure-eval-0.2.2 pygments-2.11.2 stack-data-0.2.0 traitlets-5.1.1 wcwidth-0.2.5
Removing intermediate container 3cb43140b9a2
---> 25bddba855d7
Step 28/33 : RUN cd dolfin && mkdir build && cd build && PETSC_ARCH=linux-gnu-real-32 cmake -G Ninja -DCMAKE_INSTALL_PREFIX=/usr/local/dolfin -DCMAKE_BUILD_TYPE=${DOLFIN_CMAKE_BUILD_TYPE} -DCMAKE_CXX_FLAGS=${DOLFIN_CMAKE_CXX_FLAGS} .. && ninja ${MAKEFLAGS} install && cd ../python && PETSC_ARCH=linux-gnu-real-32 pip3 install --target /usr/local/dolfin/lib/python3.8/dist-packages --no-dependencies .
---> Running in 11db897fa7b8
-- The C compiler identification is GNU 9.3.0
-- The CXX compiler identification is GNU 9.3.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Performing Test HAVE_PIPE
-- Performing Test HAVE_PIPE - Success
-- Performing Test HAVE_PEDANTIC
-- Performing Test HAVE_PEDANTIC - Success
-- Performing Test HAVE_DEBUG
-- Performing Test HAVE_DEBUG - Success
-- Performing Test HAVE_O2_OPTIMISATION
-- Performing Test HAVE_O2_OPTIMISATION - Success
-- Found MPI_C: /usr/lib/x86_64-linux-gnu/libmpich.so
-- Found MPI_CXX: /usr/lib/x86_64-linux-gnu/libmpichcxx.so;/usr/lib/x86_64-linux-gnu/libmpich.so
-- Found Boost: /usr/include (found version "1.71.0") found components: timer filesystem program_options iostreams chrono regex
-- Found Eigen3: /usr/include/eigen3 (Required is at least version "3.2.90")
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.8.10", minimum required is "3")
File "<string>", line 1, in <module>
File "/usr/local/lib/python3.8/dist-packages/ffc/__init__.py", line 24, in <module>
from ffc.compiler import compile_form, compile_element
File "/usr/local/lib/python3.8/dist-packages/ffc/compiler.py", line 129, in <module>
from ffc.codegeneration import generate_code
File "/usr/local/lib/python3.8/dist-packages/ffc/codegeneration.py", line 37, in <module>
import ffc.uflacs.language.cnodes as L
File "/usr/local/lib/python3.8/dist-packages/ffc/uflacs/__init__.py", line 23, in <module>
from ffc.uflacs.uflacsrepresentation import compute_integral_ir
File "/usr/local/lib/python3.8/dist-packages/ffc/uflacs/uflacsrepresentation.py", line 26, in <module>
from ffc.representationutils import initialize_integral_ir
File "/usr/local/lib/python3.8/dist-packages/ffc/representationutils.py", line 28, in <module>
from ufl.cell import cellname2facetname
ImportError: cannot import name 'cellname2facetname' from 'ufl.cell' (/usr/local/lib/python3.8/dist-packages/ufl/cell.py)
-- UFC could not be found. (missing: UFC_INCLUDE_DIRS UFC_VERSION UFC_VERSION_OK UFC_SIGNATURE) (Required is at least version "2019.2")
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.1")
-- Checking for one of the modules 'craypetsc_real;PETSc'
-- Test PETSC_TEST_RUNS with shared library linking - Success
-- Looking for sys/types.h
CMake Warning (dev) at /usr/share/cmake-3.16/Modules/CheckIncludeFile.cmake:80 (message):
Policy CMP0075 is not set: Include file check macros honor
CMAKE_REQUIRED_LIBRARIES. Run "cmake --help-policy CMP0075" for policy
details. Use the cmake_policy command to set the policy and suppress this
warning.
CMAKE_REQUIRED_LIBRARIES is set to:
For compatibility with CMake 3.11 and below this check is ignoring it.
Call Stack (most recent call first):
/usr/share/cmake-3.16/Modules/CheckTypeSize.cmake:230 (check_include_file)
cmake/modules/FindPETSc.cmake:213 (check_type_size)
CMakeLists.txt:301 (find_package)
This warning is for project developers. Use -Wno-dev to suppress it.
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of PetscInt
-- Check size of PetscInt - done
-- Found PETSc: TRUE (found suitable version "3.13.3", minimum required is "3.7")
-- Checking for one of the modules 'crayslepc_real;SLEPc'
-- Test SLEPC_TEST_RUNS with shared library linking - Success
-- Found SLEPc: TRUE (found suitable version "3.13.3", minimum required is "3.7")
-- ParMETIS could not be found/configured. (missing: PARMETIS_TEST_RUNS PARMETIS_INCLUDE_DIRS PARMETIS_VERSION PARMETIS_VERSION_OK) (Required is at least version "4.0.2")
-- SUNDIALS could not be found/configured. (missing: SUNDIALS_LIBRARIES SUNDIALS_TEST_RUNS SUNDIALS_INCLUDE_DIRS SUNDIALS_VERSION SUNDIALS_VERSION_OK) (Required is at least version "3")
-- Checking for package 'SCOTCH-PT'
-- Found SCOTCH (version 6.0.9)
CMake Warning (dev) at cmake/modules/FindSCOTCH.cmake:202 (set):
implicitly converting 'TYPE' to 'STRING' type.
CMakeLists.txt:335 (find_package)
-- Performing test SCOTCH_TEST_RUNS
-- Performing test SCOTCH_TEST_RUNS - Success
-- Found SCOTCH: /usr/local/petsc/linux-gnu-real-32/lib/libptscotch.a;/usr/local/petsc/linux-gnu-real-32/lib/libscotch.a;/usr/local/petsc/linux-gnu-real-32/lib/libptscotcherr.a
-- Checking for package 'AMD'
-- Looking for sgemm_
-- Looking for sgemm_ - found
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Checking for package 'UMFPACK'
-- Checking for package 'CHOLMOD'
-- Found BLAS: /usr/lib/x86_64-linux-gnu/libopenblas.so
-- Looking for cheev_
-- Looking for cheev_ - found
-- Performing test CHOLMOD_TEST_RUNS - Failed
-- Performing test UMFPACK_TEST_RUNS - Failed
-- Performing Test UMFPACK_TEST_RUNS
-- Performing Test UMFPACK_TEST_RUNS - Failed
-- UMFPACK could not be found. Be sure to set UMFPACK_DIR. (missing: UMFPACK_TEST_RUNS)
-- CHOLMOD could not be found. Be sure to set CHOLMOD_DIR. (missing: CHOLMOD_TEST_RUNS)
-- HDF5: Using hdf5 compiler wrapper to determine C configuration
-- Found HDF5: /usr/lib/x86_64-linux-gnu/hdf5/mpich/libhdf5.so;/usr/lib/x86_64-linux-gnu/libsz.so;/usr/lib/x86_64-linux-gnu/libz.so;/usr/lib/x86_64-linux-gnu/libdl.so;/usr/lib/x86_64-linux-gnu/libm.so (found version "1.10.4") found components: C
-- Checking for Trilinos
-- Unable to find Trilinos (>= 12.4.0)
-- Trilinos could not be found
-- Found ZLIB: /usr/lib/x86_64-linux-gnu/libz.so (found version "1.2.11")
-- The following features have been enabled:
* BUILD_SHARED_LIBS, Build DOLFIN with shared libraries.
* DOLFIN_AUTO_DETECT_MPI, Detect MPI automatically (turn this off to use the MPI compiler wrappers directly via setting CXX, CXX, FC).
* DOLFIN_WITH_LIBRARY_VERSION, Build with library version information.
* DOLFIN_ENABLE_DOCS, Enable generation of documentation.
* CMAKE_INSTALL_RPATH_USE_LINK_PATH, Add paths to linker search and installed rpath.
* DOLFIN_ENABLE_MPI, Compile with support for MPI.
* DOLFIN_ENABLE_PETSC, Compile with support for PETSc.
* DOLFIN_ENABLE_SLEPC, Compile with support for SLEPc.
* DOLFIN_ENABLE_TRILINOS, Compile with support for Trilinos.
* DOLFIN_ENABLE_UMFPACK, Compile with support for UMFPACK.
* DOLFIN_ENABLE_CHOLMOD, Compile with support for CHOLMOD.
* DOLFIN_ENABLE_SCOTCH, Compile with support for SCOTCH.
* DOLFIN_ENABLE_PARMETIS, Compile with support for ParMETIS.
* DOLFIN_ENABLE_SUNDIALS, Compile with support for SUNDIALS.
* DOLFIN_ENABLE_ZLIB, Compile with support for zlib.
* DOLFIN_ENABLE_HDF5, Compile with support for HDF5.
-- The following OPTIONAL packages have been found:
* MPI, Message Passing Interface (MPI)
Enables DOLFIN to run in parallel with MPI
* PETSc (required version >= 3.7), Portable, Extensible Toolkit for Scientific Computation, <https://www.mcs.anl.gov/petsc/>
Enables the PETSc linear algebra backend
* SLEPc (required version >= 3.7), Scalable Library for Eigenvalue Problem Computations, <http://slepc.upv.es/>
* SCOTCH, Programs and libraries for graph, mesh and hypergraph partitioning, <https://www.labri.fr/perso/pelegrin/scotch>
Enables parallel graph partitioning
* BLAS, Basic Linear Algebra Subprograms, <http://netlib.org/blas/>
* Threads
* HDF5, Hierarchical Data Format 5 (HDF5), <https://www.hdfgroup.org/HDF5>
* ZLIB, Compression library, <http://www.zlib.net>
-- The following REQUIRED packages have been found:
* Boost, Boost C++ libraries, <http://www.boost.org>
* Eigen3 (required version >= 3.2.90), Lightweight C++ template library for linear algebra, <http://eigen.tuxfamily.org>
* PythonInterp (required version >= 3), Interactive high-level object-oriented language, <http://www.python.org>
* PkgConfig
-- The following features have been disabled:
* CMAKE_USE_RELATIVE_PATHS, Use relative paths in makefiles and projects.
* DOLFIN_ENABLE_CODE_COVERAGE, Enable code coverage.
* DOLFIN_ENABLE_BENCHMARKS, Enable benchmark programs.
* DOLFIN_SKIP_BUILD_TESTS, Skip build tests for testing usability of dependency packages.
* DOLFIN_DEPRECATION_ERROR, Turn deprecation warnings into errors.
* DOLFIN_ENABLE_GEOMETRY_DEBUGGING, Enable geometry debugging.
-- The following OPTIONAL packages have not been found:
* SUNDIALS (required version >= 3), SUite of Nonlinear and DIfferential/ALgebraic Equation Solvers, <http://computation.llnl.gov/projects/sundials>
Provides robust time integrators and nonlinear solvers that can easily be incorporated into existing simulation codes.
* UMFPACK, Sparse LU factorization library, <http://faculty.cse.tamu.edu/davis/suitesparse.html>
* CHOLMOD, Sparse Cholesky factorization library for sparse matrices, <http://faculty.cse.tamu.edu/davis/suitesparse.html>
-- The following REQUIRED packages have not been found:
* UFC (required version >= 2019.2), Unified language for form-compilers (part of FFC), <https://bitbucket.org/fenics-project/ffc>
-- Generating demo source files from reStructuredText
extract written to /src/dolfin/demo/documented/auto-adaptive-poisson/cpp/AdaptivePoisson.ufl
extract written to /src/dolfin/demo/documented/auto-adaptive-poisson/cpp/main.cpp
extract written to /src/dolfin/demo/documented/biharmonic/cpp/Biharmonic.ufl
extract written to /src/dolfin/demo/documented/biharmonic/cpp/main.cpp
extract written to /src/dolfin/demo/documented/built-in-meshes/cpp/main.cpp
extract written to /src/dolfin/demo/documented/eigenvalue/cpp/StiffnessMatrix.ufl
extract written to /src/dolfin/demo/documented/eigenvalue/cpp/main.cpp
extract written to /src/dolfin/demo/documented/hyperelasticity/cpp/HyperElasticity.ufl
extract written to /src/dolfin/demo/documented/hyperelasticity/cpp/main.cpp
extract written to /src/dolfin/demo/documented/mixed-poisson/cpp/MixedPoisson.ufl
extract written to /src/dolfin/demo/documented/mixed-poisson/cpp/main.cpp
extract written to /src/dolfin/demo/documented/nonmatching-interpolation/cpp/P1.ufl
extract written to /src/dolfin/demo/documented/nonmatching-interpolation/cpp/P3.ufl
extract written to /src/dolfin/demo/documented/nonmatching-interpolation/cpp/main.cpp
extract written to /src/dolfin/demo/documented/poisson/cpp/Poisson.ufl
extract written to /src/dolfin/demo/documented/poisson/cpp/main.cpp
-- Generating form files in demo, test and bench directories. May take some time...
CMake Error at CMakeLists.txt:626 (message):
Generation of form files failed:
File "/src/dolfin/cmake/scripts/generate-form-files.py", line 22, in <module>
import ffc
-- Configuring incomplete, errors occurred!
See also "/src/dolfin/build/CMakeFiles/CMakeOutput.log".
See also "/src/dolfin/build/CMakeFiles/CMakeError.log".
Dear @dparsons
thank you for the clarification! Now I understand why the number of threads is set to 1 by default. Perhaps I could just locally re-build these images and set OPENBLAS_NUM_THREADS and OMP_NUM_THREADS to the desired value?
