Hello everyone! I try to use scipy minimization package to solve a minimization problems, where I will use some fenics programs to define an object function and its gradient function. The code is like this:
def objective_and_gradient(ks_flat):
k_s.x.array[:] = ks_flat
u_now, data_error_norm = heat_solver(ks_flat)
r_delta, ks_delta, k0_delta = D_adjoint(ks_flat)
grad = ks_delta
return data_error_norm, grad
result = minimize(
fun=objective_and_gradient,
x0=ks_initial,
method='L-BFGS-B',
jac=True,
options={'maxiter': N_k, 'disp': True}
Here heat_solver and D_adjoint are two solvers using fenics to solve heat equations. If I run these two functions on the server, it will utilize all available CPUs, but when I use the aforementioned program during SciPy optimization, it only uses one thread.
A simplified code of heat_solver is
def heat_solver(ks):
dt = (T - t) / num_steps
u_sol=np.zeros((num_steps, (k*nx+1)*(k*ny+1)))
domain=create_rectangle(MPI.COMM_WORLD, [np.array([0, 0]), np.array([Lx, Ly])],
[nx, ny], mesh.CellType.triangle)
V = fem.functionspace(domain, ("Lagrange", k))
tdim = domain.topology.dim
fdim = tdim - 1
u_n = fem.Function(V)
kappa = fem.Function(V)
kappa.x.array[:] = ks
u_n.x.array[:] = u_ini
f = fem.Function(V)
solver.setType(PETSc.KSP.Type.GMRES)
solver.getPC().setType(PETSc.PC.Type.ILU)
uh = fem.Function(V)
error=0
integral_form=form((uh-u_n)*(uh-u_n)*dx)
for n in range(num_steps):
f.x.array[:] = f_source[n,:]
F = u * v * ufl.dx +dt *kappa * ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx - (u_n + dt * f) * v * ufl.dx
a = fem.form(ufl.lhs(F))
L = fem.form(ufl.rhs(F))
A = assemble_matrix(a)
b = create_vector(L)
solver.setOperators(A)
with b.localForm() as loc_b:
loc_b.set(0)
assemble_vector(b, L)
solver.solve(b, uh.vector)
uh.x.scatter_forward()
u_n.x.array[:] = uh.x.array
u_sol[n,:] = uh.x.array
uh.x.array[:] = u_data[n,:]
error += dt*domain.comm.allreduce(assemble_scalar(integral_form), op=MPI.SUM)
return u_sol, np.sqrt(error)
I hope that someone can tell me how to change my code such that it will still utilize all available CPUs when I use scipy minimization functions.
