Second order meshes interpolation error
Good to know this improved way to fastly assign the whole function with the use of mesh.entities_to_geometry and contrain interpolation region with cells0 in xyz.interpolate.
Thanks for confirming this. I believe this is the reason to cause the negative interpolated node in my application above. The following validation code shows a simple test, which maybe useful for the prospective people: a mesh with only one single triangle cell is made and a P2 function with all greater than 0 values is built on it. Several points inside the mesh are evaluated to be negative values as interpolated points on the new mesh:
# P2_eval.py
# $ python P2_eval.py
# Test on DOLFINx v0.9.0
from dolfinx import fem, mesh, io, geometry
import basix.ufl
def evaluate_at_points(_mesh, f, points):
    if points.shape[1] == 2:
        z_coords = np.zeros((points.shape[0], 1))
        points = np.hstack([points, z_coords])
    bb_tree = geometry.bb_tree(_mesh, _mesh.topology.dim)
    cell_candidates = geometry.compute_collisions_points(bb_tree, points)
    colliding_cells = geometry.compute_colliding_cells(_mesh, cell_candidates, points)
    cells = []
    points_on_proc = []
    for i, point in enumerate(points):
        if len(colliding_cells.links(i)) > 0:
            cells.append(colliding_cells.links(i)[0])
            points_on_proc.append(point)
    values = f.eval(np.array(points_on_proc), np.array(cells))
    return values, np.array(points_on_proc)
comm = MPI.COMM_WORLD
nodes = np.array(
    [[0,   0  ],
     [1,   1  ],
     [0,   2  ],
     [0.5, 1.5],
     [0,   1  ],
     [0.5, 0.5],
    dtype=np.float64,
connectivity = np.array([[0, 1, 2, 3, 4, 5]], dtype=np.int64)
c_el = ufl.Mesh(basix.ufl.element("Lagrange", "triangle", 2, shape=(nodes.shape[1],)))
_mesh = dolfinx.mesh.create_mesh(MPI.COMM_SELF, cells=connectivity, x=nodes, e=c_el)
Q = fem.functionspace(_mesh, ("Lagrange", 2))
f = fem.Function(Q)
def x_tip(x):
    return x[0] > 0.9
corner_point = mesh.locate_entities_boundary(_mesh, 0, x_tip)
dof = fem.locate_dofs_topological(Q, 0, corner_point)
f.x.array[dof] = 1
n = 100
points = np.ones((n, 2))
points[:, 0] = np.linspace(0, 1, n)
vals, _ = evaluate_at_points(_mesh, f, points)
fig = plt.figure()
plt.plot(points[:, 0], vals, "o-")
plt.xlabel("x")
plt.ylabel("value")
plt.legend("y = 1 probe")
plt.grid("on")
plt.savefig("evals.png", dpi = 300)
with io.XDMFFile(comm, "f.xdmf", "w") as xdmf:
    xdmf.write_mesh(_mesh)
    xdmf.write_function(f)
Yielding
