Hello Dokken, I tried this but that gives me the wrong result. I will now share the full code and try to explain my approach. I have extracted Point Data from VTU file and mesh conversion via Meshio and then interpolated the Point Data into a Fenics function. Now I want to interpolate this function (called point_function in the code) into a seperate mesh and for this I created another function in this mesh (called T).
! pip3 install pandas
! pip3 install meshio
! pip3 install h5py
! pip install pyvista
! pip install panel
import pyvista
import panel
import dolfinx as dfx
from dolfinx import plot
from mpi4py.MPI import COMM_WORLD
# use meshio to read vtk mesh
filename = "new.vtu"
vtk_mesh = meshio.vtu.read(filename)
# cell data field as named in vtu (see paraview)
fieldname = "Temperature"
# use meshio to convert to and write a dolfinx mesh
dim = 3
ps=vtk_mesh.points[:,:dim]
cs = vtk_mesh.get_cells_type("tetra")
dolfinx_mesh = meshio.Mesh(points=ps, cells={"tetra": cs})
meshio.write("test.xdmf", dolfinx_mesh)
# read mesh with dolfinx
comm = COMM_WORLD
with XDMFFile(comm, "test.xdmf", "r") as file:
dolfinx_mesh = file.read_mesh(name="Grid")
# create the necessary grid functions
cell_element=ufl.FiniteElement("DG", dolfinx_mesh.ufl_cell(), 0)
point_element=ufl.FiniteElement("Lagrange", dolfinx_mesh.ufl_cell(), 1)
cell_function_space=dfx.fem.FunctionSpace(dolfinx_mesh, cell_element)
point_function_space=dfx.fem.FunctionSpace(dolfinx_mesh, point_element)
cell_function = dfx.fem.Function(cell_function_space)
point_function = dfx.fem.Function(point_function_space)
point_function.name = fieldname
# Global indexes owned locally
point_ids = dolfinx_mesh.geometry.input_global_indices
#cell_ids = dolfinx_mesh.geometry.input_cell_indices
# Map VTK data directy onto dolfinx vectors
#cell_function.x.array[:] = vtk_mesh.cell_data[fieldname][ids]
point_function.x.array[:] = vtk_mesh.point_data[fieldname][point_ids]
# create new mesh
test_mesh = dfx.mesh.create_box(COMM_WORLD, [np.array([0.4, -0.125, -0.3]), np.array([0.9, 0.125, 0.0])],
[50, 25, 25], cell_type=dfx.mesh.CellType.tetrahedron)
tdim = test_mesh.topology.dim
fdim = tdim - 1
test_mesh.topology.create_connectivity(fdim, tdim)
boundary_facets = dfx.mesh.exterior_facet_indices(test_mesh.topology)
pyvista.set_jupyter_backend("panel")
pyvista.start_xvfb()
topology, cell_types, geometry = plot.create_vtk_mesh(test_mesh, tdim)
grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
plotter = pyvista.Plotter()
plotter.view_xy()
if not pyvista.OFF_SCREEN:
plotter.show()
figure = plotter.screenshot("fundamentals_mesh.png")
#create new function in new mesh
V0 = ufl.FiniteElement("Lagrange", test_mesh.ufl_cell(), 1)
V = dfx.fem.FunctionSpace(test_mesh, V0)
T = dfx.fem.Function(V)
# this gives an error
from dolfinx.fem import create_nonmatching_meshes_interpolation_data
# this is what dokken suggests for interpolating function on old mesh in new mesh fo 0.6.0 dolfinx
T.interpolate(point_function)
T.x.scatter_forward()
u_topology, u_cell_types, u_geometry = plot.create_vtk_mesh(V)
u_grid = pyvista.UnstructuredGrid(u_topology, u_cell_types, u_geometry)
u_grid.point_data["T"] = T.x.array.real
u_grid.set_active_scalars("T")
u_plotter = pyvista.Plotter()
u_plotter.add_mesh(u_grid, show_edges=True, cmap="rainbow")
u_plotter.view_xy()
# result is not the same
u_plotter.show()
p_topology, p_cell_types, p_geometry = plot.create_vtk_mesh(point_function_space)
p_grid = pyvista.UnstructuredGrid(p_topology, p_cell_types, p_geometry)
p_grid.point_data["T"] = point_function.x.array.real
p_grid.set_active_scalars("T")
p_plotter = pyvista.Plotter()
p_plotter.add_mesh(p_grid, show_edges=True, cmap="rainbow")
p_plotter.view_xy()
# this is what it should look like
p_plotter.show()
Original Function:
Function (on new mesh) into which it should be interpolated - currently not being properly interpolated:
One thing I should have mentioned before is that the original mesh is unstructured and the new one is structured. Does that cause an issue?
