I fear my question was not clear, so I have tried to reformulate it in a simpler setting, independent from any previous notebook or application.
I attach a MWE below, at least showing concretely what I am trying to do.
In essence I define a problem = fem.petsc.LinearProblem(a, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"}) and necessary arguments a, L, bcs.
Now I need to solve it in a loop where one argument form, say a is changing, but cannot call fem.petsc.LinearProblem each iteration as it will crash.
So I would like to take the fem.petsc.LinearProblem defintion out of the loop, and modify said form “in place” this I do not know how to do (it is easy to achieve for fem.constant as in the Poisson tutorial, assigning a new value each loop with fem.constant.value, without need to recompile the problem).
In the example below I define a list of forms, and would like to iterate the linear problem solution over this list.
MWE
########## DOLFINX ##############
%matplotlib notebook
from dolfinx import *
from dolfinx.fem import FunctionSpace, Function
from dolfinx.fem import VectorFunctionSpace
from dolfinx.fem import petsc
from dolfinx import fem, io
from dolfinx import mesh
from dolfinx.mesh import CellType, create_rectangle
import pyvista
pyvista.set_jupyter_backend("trame")
L = 4
domain = create_rectangle(MPI.COMM_WORLD, np.array([[0,0],[L,1]]), [30,30], cell_type=CellType.triangle)
tdim = domain.topology.dim
fdim = tdim - 1
# Problem parameters
thetamoy = 0.4 # target average material density
E = fem.Constant(domain, ScalarType(1))
nu = fem.Constant(domain, ScalarType(0.3))
lamda = E*nu/(1+nu)/(1-2*nu)
mu = E/(2*(1+nu))
f = fem.Constant(domain, ScalarType([0,-1])) # vertical downwards force
# Function space for density field
V0 = fem.FunctionSpace(domain, ("DG", 0))
# Function space for displacement
V2 = fem.VectorFunctionSpace(domain, ("CG", 2))
def clamped_boundary(x):
return np.isclose(x[0], 0)
u_D = np.array([0,0], dtype=ScalarType)
bc = fem.dirichletbc(u_D, fem.locate_dofs_topological(V2, fdim, boundary_facets), V2)
def left(x):
def right(x):
return np.isclose(x[0], L)
fdim = domain.topology.dim -1
# Concatenate and sort the arrays based on facet indices. Left facets marked with 1, right facets with two
marked_values = np.hstack([np.full_like(left_facets, 1), np.full_like(right_facets, 2)])
facet_tag = mesh.meshtags(domain, fdim, marked_facets[sorted_facets], marked_values[sorted_facets])
ds = ufl.Measure('ds', domain=domain, subdomain_data=facet_tag, metadata=metadata)
def eps(v):
return ufl.sym(ufl.grad(v))
def sigma(v):
return (lamda*ufl.nabla_div(v)*ufl.Identity(2)+2*mu*eps(v))
# return lambda_ * ufl.nabla_div(u) * ufl.Identity(len(u)) + 2*mu*epsilon(u)
def energy_density(u, v):
return ufl.inner(sigma(u), eps(v))
# Inhomogeneous elastic variational problem
# u_ = ufl.TestFunction(V2)
# du = ufl.TrialFunction(V2)
# a = ufl.inner(sigma(u_), eps(du)) * ufl.dx
# L = ufl.dot(f, u_)*ds(2)
w = ufl.TestFunction(V2)
a = ufl.inner(sigma(w), eps(u)) * ufl.dx
L = ufl.dot(f, w)*ds(2)
uh= problem.solve()
form_list = [ k*ufl.inner(sigma(w), eps(u)) * ufl.dx for k in [1,2,3]]
for i in range(3):
#### modify a in place, e.g. a = form_list[i]
uh = problem.solve()
Getting into the documentation, I came up with this approach
from dolfinx.fem.forms import form as _create_form
for i in range(3):
#### modify a in place, e.g. a + form_list[i]
# The next line does not work
# problem._a = form_list[i]
## Tried
problem._a = _create_form(form_list[i])
print(uh.x.array[0])
seems create_form goes from ufl.forms to fem.forms.
Is this the way to do it? Thanks a lot
