Shape optimization in complex dolfinx
I need to adapt a shape optimization example for my use case. The unknown solution field is complex and hence I need to work with the complex build. While porting to the recent version, I run into errors that I do not encounter in the real mode. I would appreciate if someone could point out the mistake.
Below is an MWE evaluated on complex build of 0.10 installed from conda:
import dolfinx, ufl, gmsh, mpi4py
gmsh.clear()
gmsh.option.setNumber("General.Terminal", 0)
occ = gmsh.model.occ
gdim = 2
b1 = occ.addRectangle(0, 0, 0, 1, 1)
occ.synchronize()
# add_sub physical tags
all_doms = occ.getEntities(gdim)
for j, dom in enumerate(all_doms):
    gmsh.model.addPhysicalGroup(dom[0], [dom[1]], j + 1)  # create the main group/node
# number all boundaries
all_edges = occ.getEntities(gdim-1)
for j, edge in enumerate(all_edges):
    gmsh.model.addPhysicalGroup(edge[0], [edge[1]], edge[1])  # create the main group/node
mpi_rank = 0
mesh_data = dolfinx.io.gmsh.model_to_mesh(gmsh.model, mpi4py.MPI.COMM_WORLD, mpi_rank, gdim)
mesh, ct, ft = mesh_data.mesh, mesh_data.cell_tags, mesh_data.facet_tags
fem_order = 2
Omega = dolfinx.fem.functionspace(mesh, ("CG", fem_order))
u = ufl.TrialFunction(Omega)
ut = ufl.TestFunction(Omega)
dx = ufl.Measure("dx", domain=mesh, subdomain_data=ct)
ds = ufl.Measure("ds", domain=mesh, subdomain_data=ft)
R = ufl.inner(ufl.grad(u), ufl.grad(ut))*dx
zero = dolfinx.fem.Constant(mesh, dolfinx.default_scalar_type(0.0))
R += ufl.inner(zero, ut)*dx
u_sol = dolfinx.fem.Function(Omega)
petsc_options = {"ksp_type": "preonly", "pc_type": "lu", "pc_factor_mat_solver_type": "mumps"}
import dolfinx.fem.petsc
dbc = []
fwd_solver = dolfinx.fem.petsc.LinearProblem(ufl.lhs(R), ufl.rhs(R), u=u_sol, bcs=dbc, petsc_options_prefix="fwd_",petsc_options=petsc_options)
fwd_solver.solve()
lmbda = dolfinx.fem.Function(Omega)
J = ufl.inner(u_sol, u_sol) * dx
L = ufl.replace(ufl.action(R, u_sol), {ut: lmbda}) + J
dRdu = ufl.derivative(ufl.action(R, u_sol), u_sol, u)
dRdu_adj = ufl.adjoint(dRdu)
dJdu = ufl.derivative(J, u_sol, ufl.conj(ut))
dbc_adj = []
# This gives error
adj_solver = dolfinx.fem.petsc.LinearProblem(ufl.replace(dRdu_adj, {u_sol: ut}), -dJdu, u=lmbda, bcs=dbc_adj,
                                              petsc_options_prefix="adj_", petsc_options=petsc_options)
adj_solver.solve()
X = ufl.SpatialCoordinate(mesh)
W = dolfinx.fem.functionspace(mesh, mesh.ufl_domain().ufl_coordinate_element())
dL = ufl.derivative(L, X, ufl.TestFunction(W))
dLf = dolfinx.fem.form(dL) # this gives error too in complex mode
You need to be really careful with usage of inner,dot, and conj when working in complex mode.
Here is a corrected code:
gmsh.clear()
gdim = 2
occ.synchronize()
all_edges = occ.getEntities(gdim - 1)
mpi_rank = 0
fem_order = 2
R = ufl.inner(ufl.grad(u), ufl.grad(ut)) * dx
R += ufl.inner(zero, ut) * dx
petsc_options = {
    "pc_type": "lu",
dbc = []
    ufl.lhs(R),
    ufl.rhs(R),
    u=u_sol,
    bcs=dbc,
    petsc_options=petsc_options,
fwd_solver.solve()
J = ufl.dot(u_sol, u_sol) * dx
dbc_adj = []
# This gives error
    -dJdu,
    u=lmbda,
    bcs=dbc_adj,
adj_solver.solve()
dL = ufl.derivative(L, X, ufl.conj(ufl.TestFunction(W)))
Note that I use ufl.dot for the J, and ufl.conj in the last derivative for the test function.
I’ve tried to highlight some of these things in: The Poisson problem with complex numbers — FEniCSx tutorial
Thanks a lot for the quick fix!
I might have guessed or seen the requirement on ufl.derivative, but to be forced to use J = u_sol**2*dx instead of J = ufl.inner(u_sol,u_sol)*dx is very unexpected. Luckily, I don’t need it for my current assignment. But quite often optimization based on the energy functional |u_sol|^2 will be necessary. How can we work with that?
Complex-valued optimization is not trivial.
UFL enforces some strict (yet reasonable) rules on what it can allow to compile.
If you have your functional as
J = \frac{1}{2}\int_\Omega u \cdot \bar{u}~\mathrm{d}x
You will get something a bit strange when computing \frac{\partial J}{\partial u}[v]:
\frac{\partial J}{\partial u}[v]= \frac{1}{2}\left(\int_{\Omega} v \cdot \bar{u} + u \cdot \bar{v}~\mathrm{d}x\right)
which UFL wouldn’t like, as illustrated below (only using DOLFINx to get the finite element spaces, everything is really on the symbolic analysis level)
u = ufl.TrialFunction(V)
a0 =u * ufl.conj(v) * ufl.dx
a1 = v * ufl.conj(u) * ufl.dx
a = a0 + a1
for ai in [a0, a1, a]:
    pulled_back_ai = ufl.algorithms.compute_form_data(
        ai,
        do_apply_function_pullbacks=True,
        do_apply_integral_scaling=True,
        do_apply_geometry_lowering=True,
        preserve_geometry_types=(ufl.classes.Jacobian,),
        complex_mode=True
    print(pulled_back_ai.integral_data[0])
yielding:
IntegralData over domain(cell, ('otherwise',)) with integrals:
weight * |(J[0, 0] * J[1, 1] + -1 * J[0, 1] * J[1, 0])| * (conj((reference_value(v_0)))) * (reference_value(v_1)) * dx(<Mesh #0>[('otherwise',)], {'estimated_polynomial_degree': 2}, {})
and metadata:
{metadata}
  File "/root/shared/mwe.py", line 14, in <module>
  File "/dolfinx-env/lib/python3.12/site-packages/ufl/algorithms/compute_form_data.py", line 520, in compute_form_data
    check_form_arity(preprocessed_form, self.original_form.arguments(), complex_mode)
  File "/dolfinx-env/lib/python3.12/site-packages/ufl/algorithms/check_arities.py", line 213, in check_form_arity
    check_integrand_arity(itg.integrand(), arguments, complex_mode)
  File "/dolfinx-env/lib/python3.12/site-packages/ufl/algorithms/check_arities.py", line 205, in check_integrand_arity
    raise ArityMismatch("Failure to conjugate test function in complex Form")
ufl.algorithms.check_arities.ArityMismatch: Failure to conjugate test function in complex Form
The most appropriate place to raise issues regarding complex optimization with UFL would be in the UFL issue tracker.
I am facing another issue while adapting the original shape optimization problem. I notice that volume (or area) derivative is always zero in the complex mode. What is the right way of getting it to work? The MWE below calculates the derivative correctly when evaluated with the real build (0.10, conda) but gives zero with complex.
import dolfinx, ufl, mpi4py, gmsh
gmsh.finalize()
gdim = 2
box = occ.addRectangle(0, 0, 0, 1, 1)
occ.synchronize()
mpi_rank = 0
mesh = mesh_data.mesh
volume = dolfinx.fem.Constant(mesh, dolfinx.default_scalar_type(1.0))*ufl.dx
volume_form = dolfinx.fem.form(volume)
target_volume = mesh.comm.allreduce(
    dolfinx.fem.assemble_scalar(volume_form), op=mpi4py.MPI.SUM)
dvol = dolfinx.fem.form(ufl.derivative(volume, X, ufl.conj(ufl.TestFunction(W))))
dvol_func = dolfinx.fem.Function(W)
dolfinx.fem.petsc.assemble_vector(dvol_func.x.petsc_vec, dvol)
print("Current volume: ", target_volume)
print("min, max of dvol:", dvol_func.x.array.min(), dvol_func.x.array.max())
This seems to be a bug in UFL, as the following, ā€œpureā€ UFL example does not give the right result:
from utils import LagrangeElement
scalar_type=np.float64
mesh = ufl.Mesh(LagrangeElement(ufl.triangle, 1, shape=(2, )))
W = ufl.FunctionSpace(mesh, mesh.ufl_coordinate_element())
volume = ufl.Constant(mesh)*ufl.dx
#volume_form = dolfinx.fem.form(volume)
#target_volume = mesh.comm.allreduce(
#    dolfinx.fem.assemble_scalar(volume_form), op=mpi4py.MPI.SUM)
ddvol = ufl.derivative(volume, X, ufl.conj(ufl.TestFunction(W)))
complex_mode = np.issubdtype(scalar_type, np.complexfloating)
fd = ufl.algorithms.compute_form_data(ddvol,
                                        do_apply_restrictions=True,
                                        do_append_everywhere_integrals=False,
        complex_mode=complex_mode)
print(complex_mode, str(fd.preprocessed_form))
scalar_type=np.complex64
Issue created at:
Edit
Attempt at fixing this has been pushed to: Extend shape derivative to complex mode by jorgensd Ā· Pull Request #462 Ā· FEniCS/ufl Ā· GitHub
Thanks for the clarification.
Could you share your opinion on how far this bug might be affecting complex mode shape derivatives in UFL/dolfinx? I am planning to do some experiments in frequency domain electromagnetics. If the issue likely goes beyond what I chanced upon then I will happily pause the activity until the problem is sorted out.
I think the fix above should resolve the issue. However, I’d have to cook up some tests to verify it
