I have a problem with the implementation of an implicit adaptive time stepping controller. As a first test, I wanted to advance the solution by 1/2 dt, then by dt, and subsequently calculate the relative L2_error resulting from the solutions at these two “trial steps”. The optimal time step is then calculated as dt *= 1e-8 / L2_error. If I run this model it reaches the final time T = 1e-3 s after only 7 steps (starting from t = 1e-11 s). However, if I use a constant time step (e.g. by simply removing dt *= 1e-8 / L2_error) I see that the solution changes quite heavily on small time steps, i.e. the low L2_error and the corresponding large optimum time steps are somehow wrong. I attached the following working example:
from cmath import pi
from ufl import (SpatialCoordinate, FiniteElement, MixedElement, split, TestFunctions, ds, dx, grad, inner, ln, exp)
from dolfinx.fem import FunctionSpace, Function, petsc
from scipy.constants import elementary_charge as e
from scipy.constants import (epsilon_0, m_p, m_e, k)
# General parameters
t = 0.0
T = 1e-3
dt = 1e-11
n_n = 1e21 # density neutrals in units of m**-3
T_n = 300 # temperature neutrals in units of K
T_i = 300 # temperature ions in units of K
m_i = 40 * m_p
# Initial conditions
def V_0(x):
values = np.zeros((1, x.shape[1]))
values[0] = 0.0
return values
def ni_0(x):
values[0] = 1e15
return values
def ne_0(x):
values[0] = 1e15
return values
def Ee_0(x):
values[0] = 1.5 * 1e15 * e * 3
return values
def generate_mesh(x_left, x_right):
# uniform mesh
NumberOfCells = int(1e3)
h = (x_right - x_left) / NumberOfCells # cell size for equidistant mesh
msh = mesh.create_interval(MPI.COMM_WORLD, NumberOfCells, points=(x_left, x_right))
return msh
# domain boundaries
x_left = -0.1
x_right = +0.1
msh = generate_mesh(x_left, x_right)
x = SpatialCoordinate(msh)
CG1_elem = FiniteElement("CG", msh.ufl_cell(), 1)
ME_elem = MixedElement([CG1_elem, CG1_elem, CG1_elem, CG1_elem])
ME = FunctionSpace(msh, ME_elem)
V_test, ni_test, ne_test, Ee_test = TestFunctions(ME)
# Function at time t_i
u = Function(ME)
# Function at time t_(i-1)
u_ = Function(ME)
# Apply initial conditions
u.sub(0).interpolate(V_0)
u.sub(1).interpolate(ni_0)
u.sub(2).interpolate(ne_0)
u.sub(3).interpolate(Ee_0)
u_.sub(0).interpolate(V_0)
u_.sub(1).interpolate(ni_0)
u_.sub(2).interpolate(ne_0)
u_.sub(3).interpolate(Ee_0)
V, ni, ne, Ee = split(u)
V_, ni_, ne_, Ee_ = split(u_)
Te = 2*Ee / (3*ne*e)
Te_ = 2*Ee_ / (3*ne_*e)
# Left boundary
facet_l_bdry = mesh.locate_entities_boundary(msh, dim=0, marker=lambda x: np.isclose(x[0], x_left))
dof_l_bdry = fem.locate_dofs_topological(V=ME.sub(0), entity_dim=0, entities=facet_l_bdry)
# Right boundary
facet_r_bdry = mesh.locate_entities_boundary(msh, dim=0, marker=lambda x: np.isclose(x[0], x_right))
dof_r_bdry = fem.locate_dofs_topological(V=ME.sub(0), entity_dim=0, entities=facet_r_bdry)
# rate coefficients for elastic collisions
X_en = 1e-6*exp(-15.70627755836476+-0.00436884406897324*ln(Te)**1+-0.1135732340628103*ln(Te)**2+-0.0011873155516964292*ln(Te)**3)
X_in = 1e-15
# rate coefficients for ionization
X_ion = 10*1e-6*exp(-35.3071744514+16.9033721249*ln(Te)**1+-7.81316801032*ln(Te)**2+2.47737696605*ln(Te)**3+-0.62396194653*ln(Te)**4+0.145044251711*ln(Te)**5+-0.0286523207942*ln(Te)**6+0.00352120706732*ln(Te)**7+-0.000181868246303*ln(Te)**8)
# Weak expression of Poisson equation
RHS_PoissonEq = -e * ( ni - ne ) / epsilon_0
F = ( -inner(grad(V), grad(V_test)) - V_test * RHS_PoissonEq ) * dx
# Boundary conditions for Poisson equation
PoissonEq_dirichlet_bc_l = fem.dirichletbc(value=ScalarType(0), dofs=dof_l_bdry, V=ME.sub(0))
PoissonEq_dirichlet_bc_r = fem.dirichletbc(value=ScalarType(0), dofs=dof_r_bdry, V=ME.sub(0))
# Weak expression of particle transport equation for ni
Ri = X_ion*n_n*ne
mui = e/(m_i*(0.5*X_in*n_n))
ui = mui*(-V.dx(0) - k/e*T_i*ni.dx(0)/ni)
F += ni_test*(ni-ni_) * dx
F += -dt* ni_test*Ri * dx
F += -dt* ni_test.dx(0)*(ni*ui) * dx
# Non-homogeneous Neumann BCs
F += dt* ni_test*(ni*abs(ui)) * ds
# Weak expression of particle transport equation for ne
Re = X_ion*n_n*ne
nuelen = X_en * n_n
mue = e/(m_e*nuelen)
ue = mue*(+V.dx(0) - Te*ne.dx(0)/ne - Te.dx(0))
F += ne_test*(ne-ne_) * dx
F += -dt* ne_test*Re * dx
F += -dt* ne_test.dx(0)*(ne*ue) * dx
vthe = (8*e*Te/pi/m_e)**0.5
F += dt* ne_test*(0.25*ne*vthe) * ds
# Weak expression of energy transport equation for electrons
mobe = e/(m_e*X_en*n_n)
kappae = 2.5*mobe*ne*Te
qex = -kappae*e*Te.dx(0)
Qex = 2.5*e*Te*ne*ue + qex
elastic_losses = ne*m_e/m_p * ( 1.5*X_en*n_n*(e*Te-k*T_n) )
Pext = 1e7
F += Ee_test*(Ee-Ee_) * dx
F += -dt* Ee_test*Pext * dx
F += -dt* Ee_test*(-e*inner(ue,-V)) * dx
F += -dt* Ee_test.dx(0)*Qex * dx
# # Non-homogeneous Neumann BCs
F += dt* Ee_test*(1/3*Ee*vthe) * ds
with io.XDMFFile(MPI.COMM_WORLD, "output/output.xdmf", "w") as file:
file.write_mesh(msh)
while (t < T):
# calculate with dt/2
dt *= 0.5
problem = petsc.NonlinearProblem(F, u, bcs=[PoissonEq_dirichlet_bc_l, PoissonEq_dirichlet_bc_r])
solver.rtol = 1e-6
n, converged = solver.solve(u)
assert(converged)
est_sol_dt_half = u.x.array.copy()
# recalculate using dt
dt *= 2
assert(converged)
est_sol_dt = u.x.array.copy()
# determine optimal time step
L2_error = np.linalg.norm(est_sol_dt - est_sol_dt_half) / np.linalg.norm(est_sol_dt_half)
# # calculate solution again using optimal time step
u.x.array[:] = u_.x.array
assert(converged)
u_.x.array[:] = u.x.array
#print(t)
print(L2_error)
V_plot = u.sub(0).collapse()
file.write_function(V_plot, t)
Any help is highly appreciated.
