I am running the diffusion problem below with a Newton solver, increasing time step over time (example 1). I am looking for a way to similarly adapt the time step for a linear solver (based on either number of iterations, or convergence, or tolerance… just some measure of time step suitability). I have implemented the linear problem (example 2) but cannot find a way to access solver information that would inform my time step decisions. Any suggestion as to how I could go about this?
Many thanks,
example 1:
L = 1
W = 0.2
diffusion_time_step=0.01
end_time=0.5
simu_start_time=0
max_dif_tstep=0.2
from dolfinx import mesh, fem, plot, io, nls
from dolfinx.fem import FunctionSpace,VectorFunctionSpace, Function,TensorFunctionSpace, Constant
from ufl import TestFunction, TrialFunction, dx, inner,grad, Measure,derivative,system
import time
startT = time.time()
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0,0,0]), np.array([L, W, W])],
[20,20,20], cell_type=mesh.CellType.hexahedron)
V=VectorFunctionSpace(domain, ("CG", 1), dim=3)
p = TestFunction(V)
prc_prev = Function(V)
prc = Function(V)
prc_mid = 0.5*(prc + prc_prev)
dt=Constant(domain, diffusion_time_step)
def set_time_step(dt,converged,n):
if converged and n<5:
new_dt=min(max_dif_tstep,2*dt)
else: new_dt=dt
return new_dt
D_p = Constant(domain,2.4e3) # Diffusion coefficient for PTHrP
D_pr = Constant(domain,2.4e-15) # Diffusion coefficient for PTHrP
kap = Constant(domain,1e5) # Binding association rate for PTHrP-receptor
kdp = Constant(domain,1.86e-3) # Disassociation rate for PTHrP-receptor
psi_p = Constant(domain,0.01) # Decay rate for PTHrP
psi_pr = Constant(domain,1e-50) # Decay rate for PTHrP receptor
psi_cp = Constant(domain,1e-15) # Decay rate for PTHrP-receptor Complex
xdmf = io.XDMFFile(domain.comm, "MiniExampleN.xdmf", "w")
xdmf.write_mesh(domain)
# Supply term
def sup_func(x):
return np.exp(-100*(x[0]%0.1+x[1]%0.1+x[2]%0.1))
p_i = Function(V.sub(0).collapse()[0])
p_i.interpolate(sup_func)
p_sup = p_i
# PTHrP receptor presentation
def rec_func(x):
return np.exp(-10*(x[0]%0.15+x[1]%0.15+x[2]%0.15))
rp_i = Function(V.sub(0).collapse()[0])
rp_i.interpolate(rec_func)
subspace,submap=V.sub(1).collapse()
prc.x.array[submap]=rp_i.x.array
prc_prev.x.array[submap]=rp_i.x.array
# Variational problem
F = (
(- (prc[0] - prc_prev[0])*p[0]
- (prc[1] - prc_prev[1])*p[1]
- (prc[2] - prc_prev[2])*p[2])*dx()
+ (- dt*inner(D_p*grad(prc_mid[0]), grad(p[0])))*dx()
+ (+ dt*p_sup*p[0])*dx()
+ (+ dt*(- kap*prc_prev[0]*prc_mid[1]*p[0]
- kap*prc_mid[0]*prc_prev[1]*p[1]
+ kap*prc_prev[0]*prc_prev[1]*p[2]
+ kdp*prc_prev[2]*p[0]
+ kdp*prc_prev[2]*p[1]
- kdp*prc_mid[2]*p[2]))*dx()
+ (+ dt*(- psi_p*prc_mid[0]*p[0]
- psi_pr*prc_mid[1]*p[1]
- psi_cp*prc_mid[2]*p[2]))*dx()
# Create boundary condition
tdim = V.mesh.topology.dim
fdim = tdim - 1
boundary_facets = mesh.exterior_facet_indices(V.mesh.topology)
fixed_dofs_0 = fem.locate_dofs_topological(V.sub(0), fdim, boundary_facets)
fixed_dofs_1 = fem.locate_dofs_topological(V.sub(1), fdim, boundary_facets)
fixed_dofs_2 = fem.locate_dofs_topological(V.sub(2), fdim, boundary_facets)
bc0 = fem.dirichletbc(PETSc.ScalarType(0), fixed_dofs_0, V.sub(0))
bc1 = fem.dirichletbc(PETSc.ScalarType(0), fixed_dofs_1, V.sub(1))
bc2 = fem.dirichletbc(PETSc.ScalarType(0), fixed_dofs_2, V.sub(2))
# Define problem
problem=fem.petsc.NonlinearProblem(F, prc, bcs=[bc0,bc1,bc2])
solver = nls.petsc.NewtonSolver(V.mesh.comm, problem)
solver.atol=1e-8
solver.rtol=1e-8
# solver.max_it=25
# solver.ksp_type='cg'
# solver.krylov_solver.atol=1e-4
# solver.krylov_solver.rtol=1e-5
# Solve problem
simu_time=simu_start_time+0.0001
while simu_time < end_time:
n, converged = solver.solve(prc)
prc.x.scatter_forward()
prc_prev.x.array[:]=prc.x.array
if(simu_time%0.2<0.0001):
xdmf.write_function(prc, simu_time)
dt.value=set_time_step(dt.value,converged,n)
print(dt.value,flush=True)
simu_time += dt.value
xdmf.close()
endT = time.time()
print("The time of execution of above program is :",(endT-startT),flush=True)
example 2:
L = 1
W = 0.2
diffusion_time_step=0.05
end_time=1
simu_start_time=0
max_dif_tstep=0.05
import time
xdmf = io.XDMFFile(domain.comm, "MiniExampleL.xdmf", "w")
p = TestFunction(V)
prc = TrialFunction(V)
prco = Function(V)
prc_uh= Function(V)
else: new_dt=dt
return new_dt
# Supply term
def sup_func(x):
p_sup = p_i
def rec_func(x):
prco.x.array[submap]=rp_i.x.array
F = (
fdim = tdim - 1
# Define problem
(a, L) = system(F)
problem=fem.petsc.LinearProblem(a, L, bcs=[bc0,bc1,bc2],petsc_options={"ksp_type": "cg","pc_type": "hypre","pc_hypre_type": "boomeramg", "ksp_rtol":1e-8, "ksp_atol":1e-8})
# Solve problem
prc = problem.solve()
prco.x.array[:]=prc.x.array
if(simu_time%0.2<0.01 or (0.2-simu_time%0.2)<0.01):
xdmf.write_function(prco, simu_time)
# print(simu_time%0.5,flush=True)
xdmf.close()
endT = time.time()
