Hello all,
After doing research about simulating shells using fenics-shell, I found that shells should be defined with analytic expression especially the midplane, this expression we cannot have when we import complex shapes, is there any method to simulate shells without having their analytic expression?
Thank you in advance.
You might take a look at @bleyerjās example here: Linear shell model ā Numerical tours of continuum mechanics using FEniCS master documentation
