Hi dear all,
Thanks in advance.
I am trying to solve the time-dependent non-linear partial differential equations using complex Fenicsx.
The system reads:
\begin{equation}
\begin{cases}
\rho_{\alpha} \Bigl(C_{p \alpha} + C_{pv} {W} \Bigr) \Bigl( \dfrac{\partial {T_\alpha}}{\partial t} + V_x \dfrac{\partial {T_\alpha}}{\partial x} \Bigr)\ = \ \dfrac{\alpha \nu \ ({T_g} - {T_\alpha})}{\varepsilon} \vspace{0.5cm} \
\rho_g \Bigl(C_{pg} + C_{pw} {M} \Bigr) \ \dfrac{\partial {T_g}}{\partial t} \ = \ \dfrac{\nu \alpha}{1 - \varepsilon} ({T_\alpha} - {T_g}) \
\hspace{0.7cm} - \Bigl(H_v + C_{pv} \Bigl({T_\alpha} - {T_g} \Bigr) \Bigr) \ \dfrac{\rho_{\alpha} \varepsilon}{1 - \varepsilon} \ V_x \dfrac{\partial {W}}{\partial x} \vspace{0.5cm} \
\rho_{\alpha} \varepsilon \Bigl( \dfrac{\partial {W}}{\partial t} + V_x \dfrac{\partial {W}}{\partial x} \Bigr) \ = \ \Bigl(\varepsilon - 1 \Bigr) \rho_g \dfrac{\partial {M}}{\partial t} \vspace{0.5cm} \
\dfrac{\partial {M}}{\partial t} \ = \ - K\Bigl({M} - M_e\Bigr) ,\vspace{0.3cm} \
\end{cases}
\end{equation}
Except T_{alpha}, T_{g}, W and M which represent the unknown functions of our system, all others parameters are constant.
I am beginner in Fenics but not in solving PDEs with FEM. I have read the Fenics documentation and had a look on the implementation of Cahn-Hilliard (in Fenicsx) and Advection-Diffusion-Reaction equation (in Fenics).
However I get the following error in the weak form:
Shapes do not match: and .
ERROR:UFL:Shapes do not match: and .
File “/home/mamadou/fenicsx-code/meeting28.py”, line 200, in
F3 = inner(((W_k - W_k1) / dt), v_3) * dx + inner(V_x * grad(W_k), v_3) * ufl.dx
File “/home/mamadou/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ufl/operators.py”, line 159, in inner
return Inner(a, b)
File “/home/mamadou/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ufl/tensoralgebra.py”, line 147, in new
error(“Shapes do not match: %s and %s.” % (ufl_err_str(a), ufl_err_str(b)))
File “/home/mamadou/anaconda3/envs/fenicsx/lib/python3.10/site-packages/ufl/log.py”, line 135, in error
ufl.log.UFLException: Shapes do not match: and .
(fenicsx) mamadou@it-latitude5431:~/fenicsx-code$
Please find my implementation below:
import os
import matplotlib as plt
from dolfinx import log, plot
from dolfinx.fem import Function, FunctionSpace, Constant
from dolfinx.mesh import CellType, create_interval
from ufl import dx, grad, inner, SpatialCoordinate
import pyvista as pv
import pyvistaqt as pvqt
from pyvistaqt import BackgroundPlotter
#import pyvistaqt as pvqt
#from pyvistaqt import BackgroundPlotter
try:
have_pyvista = True
if pv.OFF_SCREEN:
pv.start_xvfb(wait=0.5)
except ModuleNotFoundError:
print(“pyvista and pyvistaqt are required to visualise the solution”)
have_pyvista = False
clears the terminal and prints dolfinx version
os.system(‘clear’)
print(f"DOLFINx version: {dolfinx.version}")
Save all logging to file
log.set_output_file(“log.txt”)
Set constants
alpha = 1.0 #grain surface area per volume
C_pa = 1.0 #specific heat of the air
C_pg = 1.0 #specific heat of the grain
C_pv = 1.0 #specific heat of the water vapour
C_pw = 1.0 #specific heat of the water
rho_g = 1.0 #specific mass of the grain
rho_a = 1.0 #specific mass of the air
V_x = 1.0 #air velocity
epsilon = 0.7 #porosity
H_v = 1.0
K = 4.13
M_e = 0.15
nu = 1.0
T = 1.0 # final time
num_steps = 5000 # number of time steps
L = 1.0 #total lengh
#NOTE: floats must be converted to dolfin constants on domain below
#Creating an interval mesh
NUM_ELEM = 10
domain = create_interval(MPI.COMM_WORLD, NUM_ELEM, [0, L])
print (“Creating an interval mesh”)
ENTER MATERIAL PARAMETERS AND CONSTITUTIVE MODEL
x = SpatialCoordinate(domain) # Coordinates of domain used for defining general functions
alpha = Constant(domain, alpha) #grain surface area
C_pa = Constant(domain, C_pa) #specific heat of the air
C_pg = Constant(domain, C_pg) #specific heat of the grain
C_pv = Constant(domain, C_pv)#specific heat of the water vapour
C_pw = Constant(domain, C_pw) #specific heat of the water
rho_g = Constant(domain, rho_g) #specific mass of the grain
rho_a = Constant(domain, rho_a) #specific mass of the air
V_x = Constant(domain, V_x) ##air velocity
epsilon = Constant(domain, epsilon) #porosity
H_v = Constant(domain, H_v)
K = Constant(domain, K)
M_e = Constant(domain, M_e)
nu = Constant(domain, nu)
dt = Constant(domain, dt)
#finite element function space on domain, with trial and test functions
el1 = ufl.FiniteElement(“CG”, domain.ufl_cell(), 1) #finite element function space on domain
el2 = ufl.FiniteElement(“CG”, domain.ufl_cell(), 1) #finite element function space on domain
el3 = ufl.FiniteElement(“CG”, domain.ufl_cell(), 1) #finite element function space on domain
el4 = ufl.FiniteElement(“CG”, domain.ufl_cell(), 1) #finite element function space on domain
mix = ufl.MixedElement([el1, el2, el3, el4])
Z = FunctionSpace(domain, mix) #mixed function space
print(“Number of DOFs: %d” % Z.dofmap.index_map.size_global)
print(“Number of elements (intervals): %d” % NUM_ELEM)
print(“Number of nodes: %d” % (NUM_ELEM+1))
#Once the space has been created, we need to define
#our test functions and finite element functions. Test functions for a mixed function space can
be created by replacing TestFunction by TestFunctions:
#(T_a, T_g, W, M) = ufl.TrialFunctions(Z) #finite element functions
v_1, v_2, v_3, v_4 = ufl.TestFunctions(Z) ##Test functions
s = ufl.TrialFunction(Z)
#These functions will be used to represent the unknowns T_a_k, T_g_k, W_k, and M_k at the new time
level k. The corresponding values at the previous time level k - 1 are denoted by T_a_k1,
T_g_k1, W_k1, M_k1 in our program.
#(T_a_k, T_g_k, W_k, M_k) = ufl.TrialFunctions(Z) #the unknowns T_a_k, T_g_k, W_k, and M_k at
#the new time level k.
#(T_a_k1, T_g_k1, W_k1, M_k1) = ufl.TrialFunctions(Z) #the unknowns T_a_k1, T_g_k1, W_k1, and M_k1 at
#the new time level k - 1.
u = Function(Z) # current solution
u0 = Function(Z) # solution from previous converged step
Split mixed functions
s1, s2, s3, s4 = ufl.split(s)
T_a_k, T_g_k, W_k, M_k = ufl.split(u)
T_a_k1, T_g_k1, W_k1, M_k1 = ufl.split(u0)
#T_a_k = ufl.TrialFunction(el1)
#v_1 = ufl.TestFunction(el1)
#print(grad(T_a_k).ufl_shape)
#print(v_1.ufl_shape)
Weak statement of the equations
#F0 = inner(c, q) * dx - inner(c0, q) * dx + dt * inner(grad(mu_mid), grad(q)) * dx
#F1 = inner(mu, v) * dx - inner(dfdc, v) * dx - lmbda * inner(grad(c), grad(v)) * dx
#F = F0 + F1
This is a statement of the time-discrete equations presented as part of
the problem statement, using UFL syntax.
```{index} single: Newton solver; (in Cahn-Hilliard demo)
The DOLFINx Newton solver requires a
{py:class}NonlinearProblem<dolfinx.fem.NonlinearProblem> object to
solve a system of nonlinear equations
#For the current example, we will set four different boundary conditions. We will set
T_a, T_g, W, M=0 at the walls of the channel; that is, at x=0 and x=1.
These boundary conditions may be defined as follows:
Define boundaries for wheat drying problem
#T_a_walls = ‘near(x[1], 0) || near(x[1], 1)’ #Air boundary
#T_g_walls = ‘near(x[1], 0) || near(x[1], 1)’ #Grain boundary
#W_walls = ‘near(x[1], 0) || near(x[1], 1)’ #Humidity boundary
#M_walls = ‘near(x[1], 0) || near(x[1], 1)’ #Moisture boundary
Define boundary conditions for wheat drying problem
#bcu_noslip1 = DirichletBC(V, Constant((0, 0)), T_a_walls)
#bcu_noslip2 = DirichletBC(V, Constant((0, 0)), T_g_walls )
#bcu_noslip3 = DirichletBC(V, Constant((0, 0)), W_walls)
#bcu_noslip4 = DirichletBC(V, Constant((0, 0)), M_walls )
#bcu = [bcu_noslip1, bcu_noslip2, bcu_noslip3, bcu_noslip4]
#When now all functions and test functions have been defined, we can express the nonlinear
variational grain drying problem :
print(grad(v_1).ufl_shape)
print(T_a_k.ufl_shape)
#T= dolfinx.fem.form([V_x*inner(grad(T_a_k), v_1) * dx])
#print(grad(v_1).ufl_shape)
#print(W_k.ufl_shape)
print(grad(W_k).ufl_shape)
print(v_3.ufl_shape)
#T= V_x*inner(grad(W_k), v_3) * dx
print(v_2.ufl_shape)
#print(grad(T_a_k)._ufl_shape)
#print(V_x.ufl_shape)
#print(V_x._ufl_shape)
#print(alpha.ufl_shape)
#print(alpha._ufl_shape)
F1 = inner(rho_a * (C_pa + C_pv * W_k) * ((T_a_k - T_a_k1) / dt), v_1 ) * dx #+ V_x * inner(grad(T_a_k), v_1) * dx
F2 = inner(rho_g * (C_pg + C_pw * M_k) * ((T_g_k - T_g_k1) / dt) ,v_2 ) * dx
F4 = inner(((M_k - M_k1) / dt), v_4) * dx
G1 = inner((((alpha * nu) * (T_g_k - T_a_k)) / epsilon), v_1) * dx - inner((((alpha * nu) * (T_a_k - T_g_k)) / (1 - epsilon)), v_2) * dx
G2 = inner(((H_v + C_pv * (T_a_k - T_g_k)) * (((rho_a * epsilon * V_x * grad(W_k))) / (1 - epsilon))), v_2) * dx
G3 =inner(((((epsilon - 1) * (rho_g * ((M_k - M_k1) / dt))) / (rho_a * epsilon))), v_3) * dx - inner(K * (M_e - M_k), v_4) * dx
F = F1 + F2 + F3 + F4 - G1 + G2 - G3
F = F1 + F2 + F3 + F4 - G1 - G3
Create nonlinear problem and Newton solver
problem = NonlinearProblem(F, u)
solver.convergence_criterion = “incremental”
solver.rtol = 1e-6
We can customize the linear solver used inside the NewtonSolver by
modifying the PETSc options
ksp = solver.krylov_solver
opts = PETSc.Options()
opts[f"{option_prefix}ksp_type"] = “preonly”
opts[f"{option_prefix}pc_type"] = “lu”
ksp.setFromOptions()
The setting of convergence_criterion to "incremental" specifies
that the Newton solver should compute a norm of the solution increment
to check for convergence (the other possibility is to use
"residual", or to provide a user-defined check). The tolerance for
convergence is specified by rtol.
To run the solver and save the output to a VTK file for later
visualization, the solver is advanced in time from t_{n} to
t_{n+1} until a terminal time T is reached:
Output file
file = XDMFFile(MPI.COMM_WORLD, “demo_ch/output.xdmf”, “w”)
file.write_mesh(domain)
