Hello all.
Fenicsx finds the slepc module at import time, but when
eigs = slepc.EPS().create(mesh.comm)
is encountered, the program crashes with the following error:
File "/home/bill/Cluster/Fenics2020/Helix/HelicalSection2.py", line 127, in <module>
AttributeError: module 'slepc4py' has no attribute 'EPS'
This is the code I used.
# Generate unit cell of helical structure (no periodic boundary in this case).
import sys
from mpi4py import MPI as nMPI
import slepc4py as slepc
from dolfinx.mesh import locate_entities_boundary, meshtags
from dolfinx.io import gmshio
from dolfinx import fem
from dolfinx import io
l = 6.0 # Cell length
r = 6.0 # Cell radius
rh = 2.0 # Helix radius
rw = 0.2 # wire radius
npts = 100 # number of points of spline curve
eps = 1.0e-5
Gamma = 0 + 6.283j
comm = nMPI.COMM_WORLD
mpiRank = comm.rank
modelRank = 0 # process where GMSG runs
if mpiRank == modelRank:
gmsh.option.setNumber('General.Terminal', 1)
gmsh.model.add("Helix Cell")
c = gmsh.model.occ.addCylinder(0, 0, 0, 0, 0, l, r, 1, 2*np.pi)
dt = 2 * np.pi / npts
p = []
for n in range(npts+3):
theta = 2 * np.pi * (n-1) / npts
kk = gmsh.model.occ.addCircle(rh * np.cos(theta), rh * np.sin(theta), (n -1) * l / npts, rw)
p.append(gmsh.model.occ.addCurveLoop([kk], tag=-1))
print(p)
s = gmsh.model.occ.addThruSections(p, tag=-1)
print(s)
v = gmsh.model.occ.cut([(3,c)], s, tag=100, removeObject=True, removeTool=True)
print("v={}".format(v))
gmsh.model.occ.remove([(1,p[n])], recursive=True)
gmsh.model.occ.synchronize()
bb = gmsh.model.getEntities(dim=3)
pt = gmsh.model.getBoundary(bb, combined=True, oriented=False, recursive=False)
print(pt)
# Boundary conditions
Bot = []
Top = []
PEC = []
for bb in pt:
CoM = gmsh.model.occ.getCenterOfMass(bb[0], bb[1])
print(CoM)
if(np.abs(CoM[2]) < eps):
Bot.append(bb[1])
elif(np.abs(CoM[2]-l) < eps):
Top.append(bb[1])
PEC.append(bb[1])
print(Bot, Top, PEC)
gmsh.model.mesh.setPeriodic(2, Top, Bot, [1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, l, 0, 0, 0, 1])
gmsh.model.addPhysicalGroup(3, [100], 1) # Helix volume
gmsh.model.setPhysicalName(3, 1, "HelixVolume")
gmsh.model.addPhysicalGroup(2, Top, 1) # Top BC (slave periodic BC)
gmsh.model.addPhysicalGroup(2, Bot, 2) # Bottom BC (master periodic BC)
gmsh.model.addPhysicalGroup(2, PEC, 3) # PEC boundary
gmsh.model.setPhysicalName(2, 1, "TopPBC")
gmsh.model.setPhysicalName(2, 2, "BotPBC")
gmsh.model.setPhysicalName(2, 3, "PEC")
gmsh.model.mesh.setSize([(0,108),(0,109)], 0.05)
gmsh.option.setNumber('Mesh.MeshSizeMin', 0.001)
gmsh.option.setNumber('Mesh.MeshSizeMax', 1.2)
gmsh.option.setNumber('Mesh.Algorithm', 6) #1=Mesh Adapt, 2=Auto, 3=Initial mesh only, 5=Delaunay, 6=Frontal-Delaunay
gmsh.option.setNumber('Mesh.MshFileVersion', 2.2)
gmsh.option.setNumber('Mesh.Format', 1)
gmsh.option.setNumber('Mesh.MinimumCirclePoints', 50)
gmsh.option.setNumber('Mesh.CharacteristicLengthFromCurvature', 1)
gmsh.model.mesh.generate(3)
#gmsh.fltk.run()
# mesh = 3d topology
# ct = volume tags
# fm = surface tags
mesh, ct, fm = gmshio.model_to_mesh(gmsh.model, comm, modelRank, gdim=3)
if modelRank == mpiRank:
gmsh.finalize()
elem = ufl.FiniteElement('Nedelec 1st kind H(curl)', mesh.ufl_cell(), degree=2)
V = fem.FunctionSpace(mesh, elem)
u = ufl.TrialFunction(V)
# Print out BC tags
with io.XDMFFile(mesh.comm, "BCs.xdmf", "w") as xx:
xx.write_mesh(mesh)
xx.write_meshtags(fm)
n = ufl.FacetNormal(mesh)
# Dirichlet BCs
facets = fm.find(3) # PEC facets
ubc = fem.Function(V)
ubc.x.set(0+0j)
dofs = fem.locate_dofs_topological(V, mesh.topology.dim-1, facets)
bc = fem.dirichletbc(ubc, dofs)
# Set up forms for eigenvalue problem Ax -k0^2*Bx = 0
a = fem.form(ufl.inner(ufl.curl(u), ufl.curl(v)) * ufl.dx)
b = fem.form(ufl.inner(u, v) * ufl.dx)
A = fem.petsc.assemble_matrix(a, bcs=[bc])
B = fem.petsc.assemble_matrix(b, bcs=[bc])
B.assemble()
eigs.setOperators(A, B)
eigs.setProblemType(slepc.EPS.ProblemType.GHEP) # General hermitian
eigs.setTolerances(1.0e-8)
eigs.setType(slepc.EPS.Type.KRYLOVSCHUR)
st = eigs.getST() # Invoke spectral transformation
st.setType(slepc.ST.Type.SINVERT)
eigs.setWhichEigenpairs(slepc.EPS.Which.TARGET_REAL) # target real part of eigenvalue
eigs.setTarget(-1.0)
eigs.setDimensions(nev=5) # Number of eigenvalues
eigs.solve()
eigs.view()
eigs.errorView()
sys.exit(0)
