Solution does not meet boundary conditions
Hi,everyone.
I am solving a nonlinear discontinuous finite element problem.
My speed field will gradually increase over time.I found during debugging that the solution of my first time step does not meet the boundary conditions.
In order for everyone to reproduce the problem, I am attaching my python code
from dolfinx import fem
from dolfinx.fem import (Constant, Function, FunctionSpace, dirichletbc,
                         extract_function_spaces, form,
                         locate_dofs_geometrical, locate_dofs_topological)
from dolfinx.mesh import (CellType, GhostMode, create_rectangle,
                          locate_entities_boundary,create_unit_cube)
from ufl import div, dx, grad, inner,dot,outer,ds,dS,avg,jump,rot,cross
# Create mesh
msh = create_unit_cube(MPI.COMM_WORLD,
                       8,8,8,
                       CellType.tetrahedron, GhostMode.none)
u_element=ufl.FiniteElement("RT", ufl.tetrahedron, 1)    # H(div)     Vh
A_element=ufl.FiniteElement("N1curl",ufl.tetrahedron,1)   # H(curl)     Ch
P_element=ufl.FiniteElement("DG",ufl.tetrahedron,0)       #                  Qh
TH= ufl.MixedElement([u_element, A_element,P_element])
W =fem.FunctionSpace(msh,TH)
W0,_=W.sub(0).collapse()
W1,_=W.sub(1).collapse()
W2,_=W.sub(2).collapse()
(un,An,Pn)=ufl.TrialFunctions(W)   #
(v,fai,q)=ufl.TestFunctions(W)     #
#Vh=fem.FunctionSpace(msh,u_element)
un_1=fem.Function(W0)
un_2=fem.Function(W0)
def initial_u(x):
    values=np.zeros((3,x.shape[1]))
    values[0,:]=x[1]    #y
    values[1,:]=x[2]    #z
    values[2,:]=x[0]    #x
    return values
un_1.interpolate(initial_u)
#Ch=fem.FunctionSpace(msh,A_element)
An_1=fem.Function(W1)
An_2=fem.Function(W1)
def initial_A(x):
    values[0,:]=x[2]      #z
    values[1,:]=x[0]*0    #0
    values[2,:]=x[1]      #y
    return values
An_1.interpolate(initial_A)
P=fem.Function(W2)
def initial_P(x):
    values=np.zeros((x.shape[1]))
    return values
P.interpolate(initial_P)
h = ufl.CellDiameter(msh)
n = ufl.FacetNormal(msh)
unv=(un+un_1)*0.5
uns=1.5*un_1-0.5*un_2
Anv=(An+An_1)*0.5
Ans=1.5*An_1-0.5*An_2
lmbda = ufl.conditional(ufl.gt(ufl.dot(uns, n), 0), 1, 0)
u_uw = lmbda("+") * unv("+") + lmbda("-") * unv("-")
tao_1=1000
k=1
Rm=1
alph=10
b = 2*tao_1*inner(unv,v)*dx
b -= inner(unv,div(outer(uns,v)))*dx
b += inner((dot(uns, n))("+") * u_uw, v("+")) * dS+inner((dot(uns, n))("-") * u_uw, v("-")) * dS     #
b += inner(dot(uns, n) * lmbda * unv, v) * ds
b += inner(grad(unv),grad(v))*dx +alph/h('+')*inner(jump(unv),jump(v))*dS
b -= inner(avg(dot(grad(unv),n)),jump(v))*dS-inner(avg(dot(grad(v),n)),jump(unv))*dS
b += 2*k*tao_1*inner(rot(Anv),rot(fai))*dx
b += k*inner(2*tao_1*Anv+cross(rot(Ans),unv),2*tao_1*fai+cross(rot(Ans),v))*dx
b += inner(2*tao_1*un_1,v)*dx+k*inner(2*tao_1*An_1,2*tao_1*fai+cross(rot(Ans),v))*dx
b += 2*tao_1*inner(div(unv),div(v))*dx+inner(div(unv),q)*dx-inner(div(v),Pn)*dx
a=ufl.lhs(b)
L=ufl.rhs(b)
a=fem.form(a)
L=fem.form(L)
def local_A(x):
    return np.isclose(x[1],0)  #mark y=1
def local_u(x):
    return np.logical_and(np.isclose(x[2],0),np.isclose(x[1],0))    #mark z=0  and y=0
def local_p(x):
    return np.logical_and(np.isclose(x[2],0),np.isclose(x[1],0),np.isclose(x[0],0))  #mark z=0  and x=0
def u_D(x):
    values[0,:]=0           #y
    values[1,:]=0           #z
    values[2,:]=x[0]        #x
    return values
def A_D(x):
    values[0,:]=x[2]      #z
    values[1,:]=0         #z
    values[2,:]=0         #x
    return values
def p_D(x):
    values=np.zeros((1,x.shape[1]))
    values[0,:]=0      #z
    return values
u_boundary = Function(W0)
u_boundary.interpolate(u_D)
facets = locate_entities_boundary(msh,2, local_u)
dofs = locate_dofs_topological((W.sub(0), W0), 2, facets)
bc0 = dirichletbc(u_boundary, dofs, W.sub(0))
Dh=fem.FunctionSpace(msh,A_element)
A_boundary = Function(W1)
A_boundary.interpolate(A_D)
facets = locate_entities_boundary(msh,2, local_A)
dofs = locate_dofs_topological((W.sub(1), W1), 2, facets)
bc1 = dirichletbc(A_boundary, dofs, W.sub(1))
Ph=fem.FunctionSpace(msh,P_element)
p_boundary = Function(W2)
p_boundary.interpolate(p_D)
dofs = locate_dofs_topological((W.sub(2), W2), 2, facets)
bc2 = dirichletbc(p_boundary, dofs, W.sub(2))
bcs=[bc0,bc1,bc2]
                               create_vector, set_bc)
A=assemble_matrix(a,bcs=bcs)
b=create_vector(L)
'''solver = PETSc.KSP().create(msh.comm)
solver.setOperators(A)
solver.setType(PETSc.KSP.Type.BCGS)
pc1 = solver.getPC()
print(pc1)
pc1.setHYPREType("boomeramg")
solver.setFromOptions()'''
solver.setType("preonly")
solver.getPC().setType("lu")
solver.getPC().setFactorSolverType("superlu_dist")
opts = PETSc.Options()  # type: ignore
opts["ksp_error_if_not_converged"] = 1
def domain_average(msh, v):
    """Compute the average of a function over the domain"""
    vol = msh.comm.allreduce(fem.assemble_scalar(fem.form(fem.Constant(msh, 1.0) * dx)), op=MPI.SUM)
    return (1 / vol) * msh.comm.allreduce(fem.assemble_scalar(fem.form(v * dx)), op=MPI.SUM)
wn=Function(W)
t=0
for n in range(1):
    if n==0:
        t += 0.001
        un_2.x.array[::]=un_1.x.array[::]
        An_2.x.array[::]=An_1.x.array[::]
        fem.petsc.assemble_matrix(a,bcs=bcs)          # type: ignore
        assemble_vector(b, L)
        apply_lifting(b, [a], [bcs])
        set_bc(b, bcs)
        solver.solve(b, wn.vector)
        u = wn.sub(0).collapse()
        A = wn.sub(1).collapse()
        p = wn.sub(2).collapse()
        un_1.x.array[::]=u.x.array[::]
        An_1.x.array[::]=A.x.array[::]
        un_2.x.scatter_forward()
        un_1.x.scatter_forward()
        An_2.x.scatter_forward()
        An_1.x.scatter_forward()
        p.x.array[:] -= domain_average(msh, p)
        t += 0.001
        with b.localForm() as b_loc:
            b_loc.set(0)
        set_bc(b, bcs)
    print('t is',t)
with XDMFFile(MPI.COMM_WORLD, "out_WH/velocity.xdmf", "w") as ufile_xdmf:
    u.x.scatter_forward()
    ufile_xdmf.write_mesh(msh)
    ufile_xdmf.write_function(u)
with XDMFFile(MPI.COMM_WORLD, "out_WH/A.xdmf", "w") as pfile_xdmf:
    A.x.scatter_forward()
    pfile_xdmf.write_mesh(msh)
    pfile_xdmf.write_function(A)
with XDMFFile(MPI.COMM_WORLD, "out_WH/p.xdmf", "w") as pfile_xdmf:
    p.x.scatter_forward()
    pfile_xdmf.write_function(p)
The following are the node coordinates that match the boundary:
The rows are x, y, and z respectively.
The following are the corresponding velocity field values
The rows are u_x, u_y, and u_z respectively.
This question has been bothering me for a long time, and any answer will be appreciated :sob:
I’m not an expert in this topic but I had a similar problem on a simple advection case. I fixed this by imposing the boundary conditions through a weak formulation (i.e. by means of a numerical flux).
Best,
Lucas
Your problem is really lengthy. Could you first reduce the variational formulation to something straightforward, as a projection (for each sub dimension of your problem) with the same boundary conditions, and see if you get the expected results?
Thanks Lucas.I’m not sure I understand what you mean.
Do you mean to add a numerical flux to the weak formulation?
such as :b -= inner(u_boundary,dot(grad(v),n))*dS+alph/h*inner(u_boundary,v)*dS
where u_boundary is dirichlet boundary condition.
u_boundary = fem.Function(Vh)
Yes that is what I mean. So I’m not sure how it should look in your case but for sure ds should be used instead of dS.
Dear Lucas! Thanks very much !
I have seen this in many demos.
I think you pointed out the key to the problem, even though I haven’t solved it yet.
