Solution nonconvergence
Hi, I’m currently solving the diffusion problem of a plate, but when I apply a boundary on both sides, I always get a non-convergent result,I hope you can give me some suggestions, here is an example of my code:
# 定义已知表达式
kB = Constant(8.6e-5)
r = Constant(0.3)
Sext = Constant(0.0)
fai = Constant(1e24)
f = 0.002
u_0 = Expression('0', degree=1)
t_total = 10
num_steps = 500
dt = t_total / num_steps
def D(T):
    return 4.17e-7*exp(-0.39/(kB*T))
def KrW(T):
    return 3.2e-15*exp(-1.16/(kB*T))
def KrCuCrZr(T):
    return 2.9e-14*exp(-1.92/(kB*T))
def S(T):
    return 9e-3*exp(-1.04/(kB*T))
mesh = Mesh('10_10_100s_slab/mesh.xml.gz')
W = FunctionSpace(mesh, 'P', 1)
class BoundaryX0(SubDomain):
        return on_boundary and abs(x[0] - 0.00) < DOLFIN_EPS
class BoundaryX1(SubDomain):
        return on_boundary and abs(x[0] - 0.01) < DOLFIN_EPS
class BoundaryY0(SubDomain):
        return on_boundary and abs(x[1] - 0.00) < DOLFIN_EPS
class BoundaryY1(SubDomain):
        return on_boundary and abs(x[1] - 0.01) < DOLFIN_EPS
bx0 = BoundaryX0()
bx1 = BoundaryX1()
by0 = BoundaryY0()
by1 = BoundaryY1()
boundary_markers = MeshFunction('size_t', mesh, mesh.topology().dim()-1)    # 创建网格函数
#boundary_markers.set_all(9999)
bx0.mark(boundary_markers, 0)
bx1.mark(boundary_markers, 1)
by0.mark(boundary_markers, 2)
by1.mark(boundary_markers, 3)
T = Function(W)
c1 = Function(V)
c_n = project(u_0, V)
K1 = KrW(T)*S(T)**2
F = c1*v*dx + dt*D(T)*dot(grad(c1),grad(v))*dx - c_n*v*dx - dt*Sext*v*dx - dt*((1-r)*fai-KrW(T)*c1**2)*v*ds(3) + dt*(KrCuCrZr(T)*c1**2)*v*ds(2) - dt*(KrW(T)*c1**2-K1*f)*v*ds(0)
timeseries_T = TimeSeries('10_10_100s_slab/temperature_series')
progress = Progress('Time-stepping', num_steps)
t = 0
bcs=[]
J = derivative(F, c1)
problem = NonlinearVariationalProblem(F, c1, bcs, J)
prm = solver.parameters
prm['nonlinear_solver'] = 'newton'
prm['newton_solver']['absolute_tolerance'] = 1e-8
prm['newton_solver']['relative_tolerance'] = 1e-5
prm['newton_solver']['maximum_iterations'] = 100
prm['newton_solver']['relaxation_parameter'] = 1.0
plt.figure(figsize=(12,8))
for n in range(num_steps):
    timeseries_T.retrieve(T.vector(), t)
    solver.solve()
    plot(c1)
    c_n.assign(c1)
    set_log_level(LogLevel.PROGRESS)
    progress += 1
    #set_log_level(LogLevel.ERROR)
Be grateful!
Hi, To reproduce the error I need 10_10_100s_slab/mesh.xml.gz and 10_10_100s_slab/temperature_series files.
Okay, I’m terribly sorry.
10_10_100s_slab.rar - Google Drive
I sent you an access request.
Sorry, I have agreed to share, you can try to download
Yeah, now I’m able to reproduce the error as -
RuntimeError:
*** Error:   Unable to solve nonlinear system with NewtonSolver.
*** Reason:  Newton solver did not converge because maximum number of iterations reached.
*** Where:   This error was encountered inside NewtonSolver.cpp.
*** Process: 0
*** Git changeset:  ubuntu
I tried couple of things like increasing maximum iterations and relax the tolerance requirements as done in this post How to increase maximum number of iterations? and I also tried easing the relaxing parameter as suggested here Default absolute tolerance and relative tolerance and also used CustomSolver() given here.
But none of them worked which led me to conclude that there might be a chance of malformed Jacobian therefore I suggest you to kindly read this post Default absolute tolerance and relative tolerance and check Jacobian once.
Thanks for your answer, I tried to solve the following Jacobian matrix, using the following code:
bcs=[]
J_mat = assemble(J)
J_array = J_mat.array()
print(J_array)
plt.spy(J_array)
Here are the results:
1689656621105
I don’t know how to analyze this result, can you continue to give me some help?
I don’t have time to read your code in detail. As @violetus states, rather than looking at numerical values of the matrix, you could consider slowly building up the ‘nonlinearity’ of your problem to see its effects on the Jacobian. Your material coefficients are very difficult to deal with, so a first step would be to set everything to a reasonable constant value. Then, step by step, introduce more complex models until you find the source of the problem. Getting highly nonlinear problems to converge can be quite challenging.
