How to increase maximum number of iterations?
I meet a problem that fenics show ‘Newton solver did not converge because maximum number of iterations reached.’ Can I increase this iteration number?
  File "/mnt/c/Users/Danie/OneDrive/桌面/ID1/PhaseFieldFracture.py", line 244, in <module>
    problem_u.solve(u.vector())
  File "/usr/local/lib/python3.6/site-packages/mgis/fenics/nonlinear_problem.py", line 486, in solve
    solv_out = self.solver.solve(self, x)
RuntimeError:
*** Error:   Unable to solve nonlinear system with NewtonSolver.
*** Reason:  Newton solver did not converge because maximum number of iterations reached.
*** Where:   This error was encountered inside NewtonSolver.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset:  unknown
See the following example:
# Set up some simple demonstration nonlinear problem:
mesh = UnitIntervalMesh(10)
V = FunctionSpace(mesh,"CG",1)
x = SpatialCoordinate(mesh)
F = (u+1)**2*dot(grad(u),grad(v))*dx + u*v*dx - sin(x[0])*v*dx
problem = NonlinearVariationalProblem(F,u,J=derivative(F,u),bcs=[])
# Create solver:
stype = 'newton'
solver.parameters['nonlinear_solver']=stype
sprms = solver.parameters[stype+'_solver']
# Set maximum iterations:
sprms['maximum_iterations'] = 100
# Force solver to reach maximum iterations for demonstration:
sprms['relative_tolerance'] = 0.0
sprms['absolute_tolerance'] = 0.0
# Print out other available options:
info(solver.parameters,True)
# Run solver:
solver.solve()
Thanks kamensky. After increasing the maximum number of iterations, error is eliminated.
Additionally, besides increasing the number of elements, which else ways can reduce newton iterations?
Other than the linear setting where you will converge in one iteration, Newton’s method converges optimally at least at a quadratic rate. If you aren’t achieving a quadratic convergence rate you likely have a malformed Jacobian, the update of the solution vector is not exact or your solution iterate is stuck in a saddle point and not an attractor region. Basic info available here.
Hii,
This code is not working for me, Same error is showing i.e maximum number of iteration is reached.
Thank You,
Debendra
Hi, as @kamensky states in the example, tolerances are set to 0.0 to reach maximum number of iterations for demonstration. However the solver converges if you relax the tolerance requirements:
# Create solver:
stype = 'newton'
sprms['relative_tolerance'] = 1e-14
# Run solver:
solver.solve()
Result:
Newton iteration 0: r (abs) = 1.596e-01 (tol = 0.000e+00) r (rel) = 1.000e+00 (tol = 1.000e-14)
Newton iteration 1: r (abs) = 7.413e-02 (tol = 0.000e+00) r (rel) = 4.646e-01 (tol = 1.000e-14)
Newton iteration 2: r (abs) = 1.576e-03 (tol = 0.000e+00) r (rel) = 9.876e-03 (tol = 1.000e-14)
Newton iteration 3: r (abs) = 1.785e-07 (tol = 0.000e+00) r (rel) = 1.119e-06 (tol = 1.000e-14)
Newton iteration 4: r (abs) = 1.538e-15 (tol = 0.000e+00) r (rel) = 9.639e-15 (tol = 1.000e-14)
Newton solver finished in 4 iterations and 4 linear solver iterations.
Out put is
(4, True)
It is working.
Thank You
