Hi all,
I would like to solve 1D Helmholtz equation with k>0. The analytic solution is \sin(kx)/k.
Following this tutorial, I supply the initial condition by applying Dirichlet and Neumann condition at the origin. Here is my attempt:
from dolfinx import mesh, fem
from dolfinx.fem import FunctionSpace
r_start = 1e-6
r_end = 20
nx = 1000
k = np.pi
# define mesh and function space
domain = mesh.create_interval(MPI.COMM_WORLD, nx, [r_start, r_end])
V = FunctionSpace(domain, ("CG", 1))
u = ufl.TrialFunction(V)
F = - ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx + k ** 2 * ufl.inner(u, v) * ufl.dx
# define boundary and labels
boundaries = {
1 : lambda x : np.isclose(x[0], r_start),
2 : lambda x : np.isclose(x[0], r_end),
for marker, locator in boundaries.items():
facets = mesh.locate_entities(domain, fdim, locator)
facet_indices.append(facets)
facet_tag = mesh.meshtags(domain, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = ufl.Measure('ds', domain=domain, subdomain_data=facet_tag)
class BoundaryCondition():
def __init__(self, type, marker, values):
self._type = type
if type == 'Dirichlet':
u_D = fem.Function(V)
u_D.interpolate(values)
facets = facet_tag.find(marker)
dofs = fem.locate_dofs_topological(V, fdim, facets)
self._bc = fem.dirichletbc(u_D, dofs)
elif type == 'Neumann':
self._bc = ufl.inner(values, v) * ds(marker)
elif type == 'Robin':
self._bc = values[0] * ufl.inner(u-values[1], v)* ds(marker)
raise TypeError("Unknown boundary condition: {0:s}".format(type))
@property
def bc(self):
return self._bc
@property
def type(self):
return self._type
# define boundary conditions
n = ufl.FacetNormal(domain)
uD = lambda x : np.sin(k * x[0]) / k
uN = - ufl.cos(k * x[0])
boundary_conditions = [
BoundaryCondition("Dirichlet", 1, uD),
BoundaryCondition("Neumann", 1, uN),
bcs = []
for condition in boundary_conditions:
if condition.type == "Dirichlet":
bcs.append(condition.bc)
F += condition.bc
# solve the problem
a = ufl.lhs(F)
L = ufl.rhs(F)
problem = fem.petsc.LinearProblem(a, L, bcs=bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh = problem.solve()
plt.plot(V.tabulate_dof_coordinates()[:, 0], uh.x.array)
Using this script I obtained the wrong answer. I wonder if there is a simpler approach to this type of problem? Thanks a lot !!
