Hi all,
I’m a bit new to Fenics and I’m trying to solve this system of two coupled 2D stationary PDE:
\large\frac{\partial a(x,y,t)}{\partial t} = D_{a}\nabla^{2}a + -ab^{2} + f(1-a)
\large\frac{\partial b(x,y,t)}{\partial t} = D_{b}\nabla^{2}b + ab^{2} - (f+k)b
with \frac{\partial a(x,y,t)}{\partial t}=\frac{\partial b(x,y,t)}{\partial t}=0.
I’ve implemented the resolution in Fenics considering the vector (a,b) using the Newton Solver:
k = 0.05
f = 0.04
mesh = RectangleMesh(Point(0, 0), Point(100,100), 30, 30)
X = Function(V)
Y = TestFunction(V)
#Initial Conditions
class IC(UserExpression):
def eval(self,values,x):
if (x[0]-50)**2+(x[1]-50)**2<=100: #Small perturbation in the middle
values[0] = 0.5 + 0.01*np.random.randn()
values[1] = 0.25 + 0.01*np.random.randn()
values[0] = 1.0
values[1] = 0.0
def value_shape(self):
return(2,)
X.interpolate(IC())
(a,b) = split(X)
(u,v) = split(Y)
F = -Da*dot(grad(a), grad(u))*dx - a*b*b*u*dx + f*(1-a)*u*dx -Db*dot(grad(b),grad(v))*dx + a*b*b*v*dx - (f+k)*b*v*dx
solve(F == 0, X, solver_parameters={"newton_solver":{"relative_tolerance":1e-3},"newton_solver":{"maximum_iterations":700}})
The thing is that I want to print in a few seconds those beautiful Turing’s patterns, but when I run this script, I usually got the error (sometime I can have a result btw):
<ipython-input-434-647364710ae2> in <module>
---> solve(F == 0, X, solver_parameters={"newton_solver":{"relative_tolerance":1e-2},"newton_solver":{"maximum_iterations":700}})
RuntimeError:
*** Error: Unable to solve nonlinear system with NewtonSolver.
*** Reason: Newton solver did not converge because maximum number of iterations reached.
*** Where: This error was encountered inside NewtonSolver.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: unknown
I’ve seen that many people got the same error, but by applying their solutions I couldn’t find mine (reducing the solver tolerance for example).
So I’m wondering if there are parameters to change or an other way to implement the problem that can be more efficient in this situation.
(I’m using the latest version of Fenics, and I’m running it on Windows 10 via WSL)
Thank you in advance for your precious help!
