Hi everyone,
I’m using FEniCS 2019.1.0 to solve the following reaction-diffusion system -
Now, I know that I can solve the associated linear system in each time step by creating the variational form F(u;v) = 0 and calling ‘solve(F == 0, u)’. However, to later add a point source to (1) and (2), I would like to explicitly create the matrix and right-hand side vector A and b, respectively, and apply a point source to the latter. However, when I try this, I get an error. Can I get around this error or do I have to fundamentally change the way I’m thinking about the problem?
Find attached a MWE -
T = 5.0
# final time
num_steps = 500
# number of time steps
eps = 0.01
# diffusion coefficient
K = 10.0
# reaction rate
# Create mesh
mesh = UnitSquareMesh(30,30)
# Define function space for system of concentrations
P1 = FiniteElement('P', triangle, 1)
element = MixedElement([P1, P1, P1])
# Define test functions
v_1, v_2, v_3 = TestFunctions(V)
# Define functions for velocity and concentrations
u_n = Function(V)
# Split system functions to access components
u_1, u_2, u_3 = split(u)
u_n1, u_n2, u_n3 = split(u_n)
# Define source terms
f_1 = Expression('pow(x[0]-0.1,2)+pow(x[1]-0.1,2)<0.05*0.05 ? 0.1 : 0',
degree=1)
f_2 = Expression('pow(x[0]-0.1,2)+pow(x[1]-0.3,2)<0.05*0.05 ? 0.1 : 0',
degree=1)
f_3 = Constant(0)
k = Constant(dt)
K = Constant(K)
eps = Constant(eps)
F = ((u_1 - u_n1) / k)*v_1*dx \
+ eps*dot(grad(u_1), grad(v_1))*dx + K*u_1*u_2*v_1*dx \
+ ((u_2 - u_n2) / k)*v_2*dx \
+ eps*dot(grad(u_2), grad(v_2))*dx + K*u_1*u_2*v_2*dx \
+ ((u_3 - u_n3) / k)*v_3*dx \
+ eps*dot(grad(u_3), grad(v_3))*dx - K*u_1*u_2*v_3*dx + K*u_3*v_3*dx \
- f_1*v_1*dx - f_2*v_2*dx - f_3*v_3*dx
a, L = lhs(F), rhs(F)
# Time-stepping
t = 0
for n in range(num_steps):
# Update current time
A = assemble(a)
b = assemble(L)
solve(A, u.vector(), b)
# Update previous solution
u_n.assign(u)
# Update progress bar
