Hi dear Dooken,
Thank you for your help so far.
I just now want to study the problem in 1D and then visualize the solution using pyvista.
Following the discussions in https://fenicsproject.discourse.group/t/pyvista-with-mixed-elements-in-dolfinx/9082, I have done so:
import os
from dolfinx.io import VTXWriter
from dolfinx.fem import (Constant, dirichletbc, Function, FunctionSpace, assemble_scalar,
form, locate_dofs_geometrical, locate_dofs_topological, set_bc)
from dolfinx import log, plot
#from dolfinx.plot import vtk_mesh
from dolfinx.fem import Function, FunctionSpace
from dolfinx.fem.petsc import NonlinearProblem, LinearProblem
from dolfinx.io import XDMFFile, VTXWriter
from dolfinx.mesh import CellType, create_rectangle, locate_entities_boundary
from dolfinx.nls.petsc import NewtonSolver
from ufl import dx, grad, inner, TrialFunction, derivative
from dolfinx import fem, io, mesh, plot
from petsc4py.PETSc import ScalarType
try:
import pyvista as pv
import pyvistaqt as pvqt
have_pyvista = True
if pv.OFF_SCREEN:
pv.start_xvfb(wait=0.5)
except ModuleNotFoundError:
print("pyvista and pyvistaqt are required to visualise the solution")
have_pyvista = False
# Save all logging to file
log.set_output_file("log.txt")
print(f"DOLFINx version: {dolfinx.__version__} based on GIT commit: {dolfinx.git_commit_hash} of https://github.com/FEniCS/dolfinx/")
lx = 1.0 #length of x-axis
# parmeters
r_0 = 0.0
r_b = 1.0 # the coordinate of right boundary
msh = mesh.create_interval(MPI.COMM_WORLD, 10, points=(0, 1))
# Define ME function space
m1 = ufl.FiniteElement("Lagrange", msh.ufl_cell(), 1)
T1 = ufl.FiniteElement("Lagrange", msh.ufl_cell(), 1)
ME = FunctionSpace(msh, m1 * T1)
Q = FunctionSpace(msh, m1) #ME.sub(0)
V = FunctionSpace(msh, T1) #ME.sub(1)
# Defining our problem
am = fem.Constant(msh, ScalarType(3.e-06 ))
k = fem.Constant(msh, ScalarType(0.12))
c = fem.Constant(msh, ScalarType(1.)) #c = fem.Constant(msh, ScalarType(1284.))
rho_0 = fem.Constant(msh, ScalarType(1.)) #rho_0 = fem.Constant(msh, ScalarType(500.))
R = fem.Constant(msh, ScalarType(1.)) #R = fem.Constant(msh, ScalarType(2400.))
epsilon = fem.Constant(msh, ScalarType(0.1))
nu = fem.Constant(msh, ScalarType(1.e-02))
dt = 0.001 #5.0e-06 # 0.001 #0.02 #5.0e-06 # time step
#We create four python functions for determining the facets to apply boundary conditions to
def left(x):
return np.isclose(x[0], r_0) #left (x = 0)
def right(x):
return np.isclose(x[0], r_b) #right (x = 1)
boundary_facets_right = locate_entities_boundary(msh, msh.topology.dim - 1, right)
boundary_dofs_right = locate_dofs_topological(ME.sub(0), msh.topology.dim - 1, boundary_facets_right)
bc_m_right = dirichletbc(PETSc.ScalarType(0.12), boundary_dofs_right, ME.sub(0))
boundary_facets_left = locate_entities_boundary(msh, msh.topology.dim - 1, left)
boundary_dofs_left = locate_dofs_topological(ME.sub(0), msh.topology.dim - 1, boundary_facets_left)
bc_m_left = dirichletbc(PETSc.ScalarType(0.12), boundary_dofs_left, ME.sub(0))
boundary_dofs_right = locate_dofs_topological(ME.sub(1), msh.topology.dim - 1, boundary_facets_right)
bc_T_right = dirichletbc(PETSc.ScalarType(30.), boundary_dofs_right, ME.sub(1))
boundary_dofs_left = locate_dofs_topological(ME.sub(1), msh.topology.dim - 1, boundary_facets_left)
bc_T_left = dirichletbc(PETSc.ScalarType(30.), boundary_dofs_left, ME.sub(1))
#dirichlet boundary conditions
bcs = [bc_m_right, bc_m_left, bc_T_right, bc_T_left]
#Test Functions (q, v)
q, v = ufl.TestFunctions(ME)
u = Function(ME) # current solution
u_n = Function(ME) # solution from previous converged step
#du = TrialFunction(ME)
# Split mixed functions
m, T = ufl.split(u)
m_n, T_n = ufl.split(u_n)
# Weak statement of the equations
m_n = Function(Q)
m_n.name = "m_n"
T_n = Function(V)
T_n.name = "T_n"
# The initial conditions are interpolated into a finite element space:
# Zero u
u.x.array[:] = 0.0
# Interpolate initial condition
u.sub(0).interpolate(lambda x: np.full(x.shape[1], 0.25, dtype=np.float64)) #Initial condition for m
u.sub(1).interpolate(lambda x: np.full(x.shape[1], 10., dtype=np.float64)) #Initial condition for T
u.x.scatter_forward()
#Variational formulation of the system
F0 = inner(m, q) * dx - inner(m_n, q) * dx + dt*am * inner(grad(m), grad(q)) * dx + dt*am*nu * inner(grad(T), grad(q)) * dx
F1 = c*rho_0* inner(T, v) * dx - c*rho_0* inner(T_n, v) * dx + dt*k * inner(grad(T), grad(v)) * dx - R*epsilon * inner(m, v) * dx + R*epsilon * inner(m_n, v) * dx
F = F0 + F1
#Compute the jacobian
#Jac = derivative(F, u, du)
#Solve variational problem
# Create nonlinear problem and Newton solver
#problem = NonlinearProblem(F, u, bcs = bcs) #Replace
#problem = NonlinearProblem(F, u, bcs = bcs, J = Jac)
solver = NewtonSolver(MPI.COMM_WORLD, problem)
solver.convergence_criterion = "residual" #residual #incremental
solver.rtol = 1e-12 #0.0 #1e-14 #0.0 #1e-12
#solver.max_it = 70
solver.report = True
#solver.max_it = 100 #To increase the number of iterations
solver.error_on_nonconvergence = False
solver.max_it = 1
info = solver.solve(u)
print(info)
with io.XDMFFile(MPI.COMM_WORLD, "problem_interval_mesh.xdmf", "w") as xdmf:
xdmf.write_mesh(msh)
with dolfinx.io.VTXWriter(msh.comm, "moisture_solution1D.bp", [u.sub(0)], engine="BP4") as vtx:
vtx.write(0.0)
#with dolfinx.io.VTXWriter(msh.comm, "Temperature.bp", [u.sub(1).collapse()], engine="BP4") as vtx:
with dolfinx.io.VTXWriter(msh.comm, "Temperature_solution1D.bp", [u.sub(1)], engine="BP4") as vtx:
vtx.write(0.0)
pv.start_xvfb()
u0_h = u.sub(0).collapse() #m
u1_h = u.sub(1).collapse() #T
# Dummy function space for pyvista grid
W_dummy = FunctionSpace(msh, ("CG", 1))
#cells, types, x = plot.create_vtk_mesh(W_dummy) #dolfinx.plot.vtk_mesh
cells, types, x = dolfinx.plot.vtk_mesh(W_dummy) #dolfinx.plot.vtk_mesh
grid = pv.UnstructuredGrid(cells, types, x)
plotter = pv.Plotter()
plotter.open_gif("u0_htime.gif", fps=10)
grid.point_data["u0_h"] = u.sub(0).collapse().x.array.real
warped = grid.warp_by_scalar("u0_h", factor=1)
viridis = plt.colormaps.get_cmap("viridis").resampled(25)
sargs = dict(title_font_size=25, label_font_size=20, fmt="%.2e", color="black",
position_x=0.1, position_y=0.8, width=0.8, height=0.1)
renderer = plotter.add_mesh(warped, show_edges=True, lighting=False,
cmap=viridis, scalar_bar_args=sargs,
clim=[0, max(u.x.array)])
plotter.show_axes()
The code works but I don’t see any plot.
Please let me know what I am missing.
Thank you for your time and your patience.
