Pyvista with mixed elements in dolfinx
Hey there,
I am using a dolfinx script to simulate a port hamiltonian system. Based on example scripts from Mr. Dokken’s github page, I am trying to visualize my results of a beam (over time) using pyvista, where I copied from the example the function
def harry_plotter(t_input, u_input):
    Create a figure of the concentration u_input warped visualized in 3D at timet step t.
    plotter = pyvista.Plotter()
    # Create grid defined by the function space for visualization of the function
    topology, cells, geometry = dlf.plot.create_vtk_mesh(u_input.function_space)
    function_grid = pyvista.UnstructuredGrid(topology, cells, geometry)
    var_name = f"u({t_input})"
    values = np.zeros((geometry.shape[0], 3))
    values[:, :len(u_input)] = u_input.x.array.reshape(geometry.shape[0], len(u_input))
    function_grid[var_name] = values
    function_grid.set_active_vectors(var_name)
    # Warp mesh by deformation
    warped = function_grid.warp_by_vector(var_name, factor=1)
    # Add mesh to plotter and visualize
    actor = plotter.add_mesh(warped)
    plotter.show_axes()
    if not pyvista.OFF_SCREEN:
       plotter.show()
        pyvista.start_xvfb()
        figure_as_array = plotter.screenshot(f"diffusion_{t_input:.2f}.png")
        # Clear plotter for next plot
        plotter.remove_actor(actor)
I just renamed some of the variables due to their names already existing in my script.
Since I defined my elements as
P_elem = ufl.VectorElement("CG", gebiet.ufl_cell(), 1)
R_elem = ufl.TensorElement("DG", gebiet.ufl_cell(), 1)
P_wish = ufl.VectorElement("CG", gebiet.ufl_cell(), 1)
R_wish = ufl.TensorElement("DG", gebiet.ufl_cell(), 1)
P_wish_2 = ufl.VectorElement("CG", gebiet.ufl_cell(), 1)
mel = ufl.MixedElement([P_elem, R_elem, P_wish, R_wish, P_wish_2])
U = dlf.fem.FunctionSpace(gebiet, mel)
u = dlf.fem.Function(U)
(p, F, v, P, pos) = ufl.split(u)
(dv, dP, dp, dF, dpos) = ufl.TestFunctions(U)
u_n = dlf.fem.Function(U)
(p_n, F_n, v_n, P_n, pos_n) = ufl.split(u_n),
where gebiet is the domain and pos is the position of the elements in space, I call the plotting function with harry_plotter(t_temp, u.sub(0)). The full script, if necessary for helping me, is below this post. Some of the variables are in German to avoid accidentally using a name already in use.
This unfortunately does not work, as I am getting the error:
/usr/bin/python3 hyperelasticity2.py
Zeit:  0.0
  File "/home/marco/Schreibtisch/Code
/Kernproblem/hyperelasticity2.py", line 178, in <module>
/Kernproblem/hyperelasticity2.py", line 121, in harry_plotter
  File "/usr/lib/python3.10/functools.py", line 889, in wrapper
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfinx/plot.py", line 105, in _
    dofmap_ = dofmap.list.array.reshape(dofmap.list.num_nodes, num_dofs_per_cell)
ValueError: cannot reshape array of size 51840 into shape (4320,4)
I am really confused. Inputting u in total doesn’t work, as expected, but all the u.sub(...) do not work either, where I would have expected to work at least the vector elements, especially the position, u.sub(4).
Do you have any idea how to make this plotting work?
Thank you so much in advance.
Best regards
Marco
Full script:
## import stuff
import dolfinx as dlf
import scipy.io
import pyvista
## define constants
L = 1
W = 0.2
mu = 1
rho = 1
delta = W/L
gamma = 0.4*delta**2
beta = 1.25
lmbda = beta
g = gamma
rho_0=1
mu=1
lamb=1
nu=np.array([1,1,1])
delta_t = 1/16
t_gesamt = 1/4 # +delta_t/2 # s
N_t = round(t_gesamt / delta_t)
k_w = 3.0
rho_w = 2.0
## define mesh
gebiet = dlf.mesh.create_box(MPI.COMM_WORLD, [np.array([0,0,0]), np.array([L, W, W])],[20,6,6])
# gebiet = dlf.mesh.create_box(MPI.COMM_WORLD, [np.array([0,0,0]), np.array([L, W, W])],[20,6,6], cell_type=dlf.mesh.CellType.hexahedron)
Normalenvektor = ufl.FacetNormal(gebiet)
## define function spaces
V_tau = dlf.fem.FunctionSpace(gebiet,P_elem)
tau_0 = dlf.fem.Function(V_tau) # Spannungsvektor
## define initial conditions
def einervektor(x):
    values = np.zeros((gebiet.geometry.dim, x.shape[1]), dtype=np.float64)
    values[0,:] = 1
    values[1,:] = 1
    values[2,:] = 1
    return values
tau_0.interpolate(einervektor)
def initial_cond(x):
    values = np.zeros((gebiet.geometry.dim*gebiet.geometry.dim, x.shape[1]), dtype=np.float64)
    values[0,:] = 1
    values[4,:] = 1
    values[8,:] = 1
    return values
u.sub(1).interpolate(initial_cond)
u_n.sub(1).interpolate(initial_cond)
## define functions
Psi_fun = lambda F: (mu / 2) * (ufl.tr(ufl.dot(F.T,F)) - 3) - mu * ufl.ln(ufl.sqrt(ufl.classes.Determinant(ufl.dot(F.T,F)))) + (lmbda / 2) * (ufl.ln(ufl.sqrt(ufl.classes.Determinant(ufl.dot(F.T,F)))))**2
P_fun = lambda F: ufl.dot(F,mu*(ufl.classes.Identity(F.ufl_shape[0])-ufl.inv(ufl.dot(F.T,F)))+lamb*ufl.ln(ufl.sqrt(ufl.classes.Determinant(ufl.dot(F.T,F))))*ufl.inv(ufl.dot(F.T,F)))
# psi = (mu / 2) * (Ic - 3) - mu * ufl.ln(J) + (lmbda / 2) * (ufl.ln(J))**2
# P = ufl.diff(psi, F)
## define BCs
boundaries = [(1, lambda x: np.isclose(x[0], 0)),
              (2, lambda x: np.isclose(x[0], L)),
              (3, lambda x: np.isclose(x[1], 0)),
              (4, lambda x: np.isclose(x[1], W)),
              (5, lambda x: np.isclose(x[2], 0)),
              (6, lambda x: np.isclose(x[2], W))] # 2 weitere Ränder für 3. Dimension, gleicher Index für selbes Randelement oder Elemente mit logischem Oder verknüpfen.
fdim = gebiet.topology.dim - 1
    facets = dlf.mesh.locate_entities(gebiet, fdim, locator)
    facet_indices.append(facets)
facet_indices = np.array(np.hstack(facet_indices), dtype=np.int32)
facet_markers = np.array(np.hstack(facet_markers), dtype=np.int32)
facet_tag = dlf.mesh.meshtags(gebiet, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = ufl.Measure("ds", domain=gebiet, subdomain_data=facet_tag)
ds_Dirichlet = ds(0)
ds_Neumann = ds(1)
dx=ufl.Measure('dx', domain=gebiet, metadata={'quadrature_degree': 4})
# fdim = domain.topology.dim -1
# left_facets = mesh.locate_entities_boundary(domain, fdim, left)
# right_facets = mesh.locate_entities_boundary(domain, fdim, right)
    plotter.show_axes()
       plotter.show()
## loop over time steps
time = np.zeros(N_t + 1)
Hamiltonian = np.zeros(N_t + 1)
for count, t_temp in enumerate(np.linspace(0, t_gesamt, N_t + 1)):
    print('Zeit: ',t_temp)
	## update load vector
	# skipped
	## define residuum
    F_FEM = ufl.dot(dv, (p-p_n) /  delta_t) * dx - ufl.inner(ufl.grad(dv), P) * dx - ufl.dot(dv, ufl.dot(P,Normalenvektor)) * ds_Neumann + ufl.dot(dv,tau_0) * ds_Neumann + \
        ufl.inner(dP, (F-F_n) /  delta_t) * dx + ufl.inner(dP, ufl.grad(v)) * dx - ufl.dot(ufl.dot(dP,Normalenvektor),v) * ds_Dirichlet + \
        ufl.dot(dp,v-p/rho_0) * ufl.dx + \
        ufl.inner(dF,P-P_fun(F)) * dx + \
        ufl.dot(dpos, (pos - pos_n)/ delta_t) * dx - ufl.dot(dpos, v) * ufl.dx # integration der Position, Zeitintegration noch auf implizite Mittelpunktsregel umstellen! #  nu+
	## solve problem
    problem = dlf.fem.petsc.NonlinearProblem(F_FEM, u)
    solver = dlf.nls.petsc.NewtonSolver(MPI.COMM_WORLD, problem)
    n, converged = solver.solve(u) # Wo ist der Lösungsoutput? u wird mit dem Ergebnis überschrieben.
	## Update old field
    u_n.x.array[:] = u.x.array[:]
	## update Hamiltonian
    test_konstant = dlf.fem.Constant(gebiet, 1/2)
    time[count] = t_temp
    # https://fenicsproject.discourse.group/t/incompatible-function-arguments-for-assemble-scalar/8194 -> https://github.com/FEniCS/dolfinx/blob/7b3e22e95f62f827a4e9d3eb5124f53c5e2148f3/python/test/unit/fem/test_assemble_submesh.py#L55
    Hamiltonian[count] = dlf.fem.assemble_scalar(dlf.fem.form(1 / 2 * ufl.dot(p_n, p_n) / rho_0 * dx + Psi_fun(F_n) * dx))
    ## Plot beam
## plot hamiltonian over time
plt.figure()
plt.title('Hamiltonian', fontsize=10)
plt.plot(time, Hamiltonian)
plt.xlabel("$t$")
plt.ylabel("$H$")
plt.grid(True)
#plt.savefig('results/Hamiltonian.pdf')
You need to collapse the the mixed function into its subspace, i.e.
u.sub(0).collapse().
