I’m trying to find the solution of displacements (u) and Lagrange multipliers (p) in 2D rectangle body with fixed left edge (u = 0) and traction specified on the right edge. All other edges are traction-free. I have never dealt with Lagrange multipliers and I’m struggling to set up the problem in Fenics.
Here’s the Euler-Lagrnage equations I’ve found:
∇∙σ=0 (1)
∇∙u=0 (2)
σ=2μϵ+pI (3)
and by definition of strain:
ϵ=1/2 (∇u+(∇u)^T ) (4)
To solve for u and p, I did the following:
Define function space
V1 = VectorFunctionSpace(mesh, ‘P’, 1)
V2 = FunctionSpace(mesh, ‘R’, 0)
Assign left/right boundaries
def left(x,on_boundary):
return near(x[0],0) and on_boundary
def right(x,on_boundary):
return near(x[0],3) and on_boundary
Mark the boundary on the right
boundary_subdomains = MeshFunction(“size_t”, mesh, mesh.topology().dim() - 1)
boundary_subdomains.set_all(0)
AutoSubDomain(left).mark(boundary_subdomains, 1)
AutoSubDomain(right).mark(boundary_subdomains, 2) # This is the boundary where the traction is applied
dss = ds(subdomain_data=boundary_subdomains)
BC: u_x = u_y = 0 at the left
bc = DirichletBC(V,Constant((0,0)),left)
Define strain
return 0.5*(grad(u) + grad(u).T)
Define stress
def sigma(u,p):
return 2muepsilon(u) + p*Identity(d)
Define variational problem
u = TrialFunction(V1)
p = TrialFunction(V2)
d = u.geometric_dimension() # space dimension of u
v = TestFunction(V1)
q = TestFunction(V2)
f = Constant((0,0)) # External force = 0
T = Constant((0,0)) # Traction free BC
I’m planning to add Petrov-Galerkin term in the weak form of the equation (Why I introduced Lagrange multiplier here). Am I going the right way so far? How should I derive the weak form to solve for u and p?
