Solving Schrodinger using complex support
Hi everyone,
I am trying to implement some code able to solve the following Schrodinger equation
schrodinger_page-0001
Do you have some advice on how to treat the variational formulation, since both the test function and the wave function psi are complex? I have read that dolfinx should be able to handle this task.
Thanks in advance
Have you considered the demo: dolfinx/demo_helmholtz.py at main · FEniCS/dolfinx · GitHub
Yes, I have checked it, even though I keep getting the following error on this part of the code:
a = ( ufl.inner( psi1 , v) - j * hbar * dt / 2.0 * ufl.inner(ufl.grad(psi1), ufl.grad(v) ) ) * ufl.dx
L = ufl.inner( psi1_old, v) * ufl.dx
problem = LinearProblem(a, L, psi1, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
problem.solve()
variationak_page-0001
The error is:
NotImplementedError                       Traceback (most recent call last)
Input In [4], in <cell line: 8>()
      6 from dolfinx.fem.petsc import LinearProblem
      7 problem = LinearProblem(a, L, psi1, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
----> 8 problem.solve()
File /usr/local/dolfinx-complex/lib/python3.8/dist-packages/dolfinx/fem/petsc.py:560, in LinearProblem.solve(self)
    558 # Assemble lhs
    559 self._A.zeroEntries()
--> 560 assemble_matrix(self._A, self._a, bcs=self.bcs)
    561 self._A.assemble()
    563 # Assemble rhs
File /usr/lib/python3.9/functools.py:877, in singledispatch.<locals>.wrapper(*args, **kw)
    873 if not args:
    874     raise TypeError(f'{funcname} requires at least '
    875                     '1 positional argument')
--> 877 return dispatch(args[0].__class__)(*args, **kw)
File /usr/local/dolfinx-complex/lib/python3.8/dist-packages/dolfinx/fem/petsc.py:338, in _(A, a, bcs, diagonal, constants, coeffs)
    336 constants = _pack_constants(a) if constants is None else constants
    337 coeffs = _pack_coefficients(a) if coeffs is None else coeffs
--> 338 _cpp.fem.petsc.assemble_matrix(A, a, constants, coeffs, bcs)
    339 if a.function_spaces[0] is a.function_spaces[1]:
    340     A.assemblyBegin(PETSc.Mat.AssemblyType.FLUSH)
File /usr/local/lib/python3.9/dist-packages/ufl/core/expr.py:390, in Expr.__len__(self)
    388 if len(s) == 1:
    389     return s[0]
--> 390 raise NotImplementedError("Cannot take length of non-vector expression.")
NotImplementedError: Cannot take length of non-vector expression.
Could you supply the full code to reproduce the error message?
Yes, of course
# Geometry generation
from dolfinx import mesh, fem, plot, io
# Scaled variable
L = 20
W = 0.5
H = 8
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([0,0,0]), np.array([L, W, H])],
                  [512,12,208], cell_type=mesh.CellType.hexahedron)
n = ufl.FacetNormal(domain)
from dolfinx import io
with io.XDMFFile(domain.comm, "mesh.xdmf", "w") as xdmf:
    xdmf.write_mesh(domain)
print('Mesh Generated')
# Parameters
dt = 1/48
T = 20
radius = 0.3
uD = np.array([1, 0, 0]);
hbar = 0.03
c = 0.01
xcylinder = 2
zcylinder = 4
V = fem.FunctionSpace(domain, ("Lagrange",1))
psi1 = ufl.TrialFunction(V)
psi2 = ufl.TrialFunction(V)
# Psi initialization
j = PETSc.ScalarType(0 + 1j)
psi1_old = fem.Function(V)
psi1_old.interpolate(lambda x: 1/(1+c**2) + x[0] * 0 + x[1] * 0 + x[2] * 0 + j * 0)
psi2_old = fem.Function(V)
psi2_old.interpolate(lambda x: c/(1+c**2) + x[0] * 0 + x[1] * 0 + x[2] + j * 0)
# Schrodinger Solving
a = ( ufl.inner(psi1, v)  - j * hbar * dt / 2.0 * ufl.inner(ufl.grad(psi1), ufl.grad(v))) * ufl.dx
# a = ( ufl.inner(psi1, v)  - j * hbar * dt / 2.0 * ufl.inner(ufl.grad(psi1), ufl.grad(v))) * ufl.dx
problem.solve()
I’ll post the code in case someone needs it
from time import process_time
from dolfinx import plot
import pyvista
from dolfinx.fem import Function, FunctionSpace, assemble_scalar, form, locate_dofs_geometrical, dirichletbc, Expression
from dolfinx.mesh import create_rectangle, CellType
from ufl import dx, grad, inner, div, conj, real, imag, Index, Dx
if np.issubdtype(PETSc.ScalarType, np.complexfloating):
    imaginaryUnit = PETSc.ScalarType(0 + 1j)
    error('Complex Treatment is needed')
# Parameters
dt = 1/50;
hbar = 0.03;
inlet_velocity = np.array([1.0, 0.0]);
T = 50;
numsteps = 50/dt
# Mesh Discretization
dimensions = np.array([10,4]);
nx = 250;
ny = 100;
domain = create_rectangle(MPI.COMM_WORLD, [np.array([0, 0]), dimensions],
                                       [nx, ny], CellType.triangle)
tdim = domain.topology.dim;
# Definition of the functional space
deg = 1; # linear = 1, parabolic = 2 Lagrangian FE are used
V = FunctionSpace(domain, ("Lagrange", deg))
psi1 = Function(V)
psi2 = Function(V)
psi1.name = "psi1"
psi2.name = "psi2"
tmpPsi1 = Function(V)
tmpPsi2 = Function(V)
psi1old = Function(V)
psi2old = Function(V)
u = ufl.TrialFunction(V)
# Defining the inlet boundary condition
dofs_inlet = locate_dofs_geometrical(V, lambda x: np.isclose(x[0],0))
inletPlaneWave = Function(V)
kvec = inlet_velocity/hbar
inletPlaneWave.interpolate(lambda x: np.exp(imaginaryUnit * (kvec[0]*x[0] + kvec[1]*x[1])))
bc_Inlet = dirichletbc(inletPlaneWave, dofs_inlet)
# Initialization
def initial_condition1(x):
    return 1 + 0j + 0 * x[0] + 1 * x[1]
def initial_condition2(x, c = 0.01 ):
    return c + 0j + 0 * x[0] + 1 * x[1]
psi1old.interpolate(initial_condition1)
psi2old.interpolate(initial_condition2)
# Definition of the variational formulation
theta = 0.5 # Crank-Nicolson is used - theta method is implemented
a = inner(u, v) * dx - imaginaryUnit * dt * hbar / 2 * (1-theta) * inner(grad(u), grad(v)) * dx
L1 = inner(psi1old, v) * dx + imaginaryUnit * dt * hbar / 2 * theta * inner(grad(psi1old), grad(v)) * dx
L2 = inner(psi2old, v) * dx + imaginaryUnit * dt * hbar / 2 * theta * inner(grad(psi2old), grad(v)) * dx
problem1 = LinearProblem(a, L1, u = tmpPsi1, bcs = [bc_Inlet], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
problem2 = LinearProblem(a, L2, u = tmpPsi2, bcs = [bc_Inlet], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
cputime_start = process_time()
n = 0;
for n in range (0,int(numsteps)):
  t = float(n+1)*dt
  print("Time = %.2f" % t)
  # Schrodinger Evolution
  problem1.solve()
  problem2.solve()
  psi1old.interpolate(psi1)
  psi2old.interpolate(psi2)
The issue here is that you send in psi1, a trial function in the place where the boundary conditions are expected. You can simply change it to:
problem = LinearProblem(a, L,  petsc_options={
problem.solve()
