After investigating, I figure this is an error linked with MUMPS : when I set the factorization solver using
eps = SLEPc.EPS().create(msh.comm)
st = eps.getST()
K = st.getKSP()
K.setType(PETSc.KSP.Type.PREONLY)
PC = K.getPC()
PC.setType("lu")
PC.setFactorSolverType("mumps")
PC.setFromOptions()
I get the same problem even when running the demo on just 1 proc with the complex build (that was working fine before as the default factorization solver is not mumps in serial) : it does not end or throws double free or corruption (out). Here is a MWE thats basically taken from the demo :
import sys
from dolfinx import default_scalar_type, fem, io, plot
from dolfinx.fem.petsc import assemble_matrix
from dolfinx.mesh import (CellType, create_rectangle, exterior_facet_indices,
locate_entities)
try:
import pyvista
have_pyvista = True
except ModuleNotFoundError:
print("pyvista and pyvistaqt are required to visualise the solution")
have_pyvista = False
try:
from slepc4py import SLEPc
print("slepc4py is required for this demo")
sys.exit(0)
w = 1
h = 0.45 * w
d = 0.5 * h
nx = 300
ny = int(0.4 * nx)
msh = create_rectangle(MPI.COMM_WORLD, np.array([[0, 0], [w, h]]), np.array([nx, ny]), CellType.quadrilateral)
msh.topology.create_connectivity(msh.topology.dim - 1, msh.topology.dim)
eps_v = 1
eps_d = 2.45
def Omega_d(x):
return x[1] <= d
def Omega_v(x):
return x[1] >= d
D = fem.functionspace(msh, ("DQ", 0))
eps = fem.Function(D)
cells_v = locate_entities(msh, msh.topology.dim, Omega_v)
cells_d = locate_entities(msh, msh.topology.dim, Omega_d)
eps.x.array[cells_d] = np.full_like(cells_d, eps_d, dtype=default_scalar_type)
eps.x.array[cells_v] = np.full_like(cells_v, eps_v, dtype=default_scalar_type)
degree = 1
RTCE = element("RTCE", msh.basix_cell(), degree)
Q = element("Lagrange", msh.basix_cell(), degree)
V = fem.functionspace(msh, mixed_element([RTCE, Q]))
lmbd0 = h / 0.2
k0 = 2 * np.pi / lmbd0
et, ez = ufl.TrialFunctions(V)
vt, vz = ufl.TestFunctions(V)
a_tt = (ufl.inner(ufl.curl(et), ufl.curl(vt)) - (k0**2) * eps * ufl.inner(et, vt)) * ufl.dx
b_tt = ufl.inner(et, vt) * ufl.dx
b_tz = ufl.inner(et, ufl.grad(vz)) * ufl.dx
b_zt = ufl.inner(ufl.grad(ez), vt) * ufl.dx
b_zz = (ufl.inner(ufl.grad(ez), ufl.grad(vz)) - (k0**2) * eps * ufl.inner(ez, vz)) * ufl.dx
a = fem.form(a_tt)
b = fem.form(b_tt + b_tz + b_zt + b_zz)
bc_facets = exterior_facet_indices(msh.topology)
bc_dofs = fem.locate_dofs_topological(V, msh.topology.dim - 1, bc_facets)
u_bc = fem.Function(V)
with u_bc.vector.localForm() as loc:
loc.set(0)
bc = fem.dirichletbc(u_bc, bc_dofs)
### Solve the problem in SLEPc
A = assemble_matrix(a, bcs=[bc])
B = assemble_matrix(b, bcs=[bc])
B.assemble()
eps.setOperators(A, B)
eps.setProblemType(SLEPc.EPS.ProblemType.GNHEP)
tol = 1e-9
eps.setTolerances(tol=tol)
eps.setType(SLEPc.EPS.Type.KRYLOVSCHUR)
# Get ST context from eps
st = eps.getST()
# Set shift-and-invert transformation
st.setType(SLEPc.ST.Type.SINVERT)
eps.setWhichEigenpairs(SLEPc.EPS.Which.TARGET_REAL)
eps.setTarget(-(0.5 * k0)**2)
eps.setDimensions(nev=1)
###ADDITIONAL PARAMETERS FOR EIGENSOLVER
K = st.getKSP()
PC = K.getPC()
PC.setType("lu")
PC.setFromOptions()
eps.solve()
eps.view()
eps.errorView()
vals = [(i, np.sqrt(-eps.getEigenvalue(i))) for i in range(eps.getConverged())]
vals.sort(key=lambda x: x[1].real)
eh = fem.Function(V)
kz_list = []
for i, kz in vals:
# Save eigenvector in eh
eps.getEigenpair(i, eh.vector)
# Compute error for i-th eigenvalue
error = eps.computeError(i, SLEPc.EPS.ErrorType.RELATIVE)
# Verify, save and visualize solution
if error < tol and np.isclose(kz.imag, 0, atol=tol):
kz_list.append(kz)
print(f"eigenvalue: {-kz**2}")
print(f"kz: {kz}")
print(f"kz/k0: {kz / k0}")
Can this be a problem with my installation of petsc/slepc or is anyone able to reproduce the problem ? Also, switching the type of preconditioner to cholesky gives the same problem.
Switching the factorization solver to superlu_dist seems to make the solver converge in parallel, but takes an unexpectedly long time ?
