I have studied the N-S equation cylinder example in fenics tutorial . Now i want to rewrite the example using mixed element , but the result is false (no turbulence). there is my code `
T = 5.0 # final time
num_steps = 5000 # number of time steps
mu = 0.001 # dynamic viscosity
rho = 1 # density
# Create mesh
channel = Rectangle(Point(0, 0), Point(2.2, 0.41))
cylinder = Circle(Point(0.2, 0.2), 0.05)
domain = channel - cylinder
mesh = generate_mesh(domain, 64)
# Define function spaces
elem_u = VectorElement('P', mesh.ufl_cell(), 2)
elem_p = FiniteElement('P', mesh.ufl_cell(), 2)
elem_up = MixedElement([elem_u, elem_p])
V = FunctionSpace(mesh, elem_up)
# Define boundaries
inflow = 'near(x[0], 0)'
outflow = 'near(x[0], 2.2)'
walls = 'near(x[1], 0) || near(x[1], 0.41)'
cylinder = 'on_boundary && x[0]>0.1 && x[0]<0.3 && x[1]>0.1 && x[1]<0.3'
# Define inflow profile
inflow_profile = ('4.0*1.5*x[1]*(0.41 - x[1]) / pow(0.41, 2)', '0')
# Define boundary conditions
bcu_inflow = DirichletBC(V.sub(0), Expression(inflow_profile, degree=2), inflow)
bcu_walls = DirichletBC(V.sub(0), Constant((0, 0)), walls)
bcu_cylinder = DirichletBC(V.sub(0), Constant((0, 0)), cylinder)
bcp_outflow = DirichletBC(V.sub(1), Constant(0), outflow)
bcup = [bcu_inflow, bcu_walls, bcu_cylinder, bcp_outflow]
u, p = TrialFunctions(V)
v, q = TestFunctions(V)
# Define functions for solutions at previous and current time steps
up_old = Function(V)
u_old, p_old = split(up_old)
up_fem = Function(V)
f = Constant((0, 0))
k = Constant(dt)
mu = Constant(mu)
rho_f = Constant(rho)
# Define symmetric gradient
return sym(nabla_grad(u))
# Define stress tensor
def sigma(u, p):
return 2*mu*epsilon(u) - p*Identity(len(u))
# Define variational problem for step 1
F_ns = rho_f*dot((u - u_old) / k, v)*dx + \
rho_f*dot(dot(u_old, nabla_grad(u)), v)*dx + \
inner(epsilon(u), epsilon(v))*dx -\
p*div(v)*dx+\
div(u)*q*dx - \
dot(f, v)*dx
a1 = lhs(F_ns)
L1 = rhs(F_ns)
vtkfile_u = File('n_s_cylinder/velocity.pvd')
# Time-stepping
t = 0
for n in range(num_steps):
# Update current time
solve(a1 == L1, up_fem, bcup)
u_fem, p_fem = up_fem.split()
# Plot solution
if n%(num_steps/5) == 0:
print("go, on!")
plot(u_fem, title='Velocity')
plot(p_fem, title='Pressure')
if n == num_steps -1 :
print("finish")
vtkfile_u << (u_fem, t)
# Update previous solution
up_old.assign(up_fem)
Are there some examples to refer to?
