Hi all,
I’m working on a mixed finite element formulation using static condensation in DOLFINx (version 0.9.0) with tabulated element kernels. I’m trying to support position-dependent material coefficients (Functions on a DG0 space) like the Lame parameters and density lam, mu, and rho. The goal is to condense out stress degrees of freedom and obtain the correct global displacement matrix.
When I replace the coefficients with scalar float values (e.g., lam = 1.0), the condensed and full displacement matrices match, as expected. However, using Function coefficients results in a noticeable mismatch.
I’ve included below a full minimal reproducible example that should match A_cond and A, but fails with an AssertionError unless I replace the coefficients with scalars. This issue is closely related to the solution I was given in this post Static condensation gives incorrect results when coefficient is added to form. However, when several forms have different coefficients I’m unsure of the particular way the coefficient ordering or indexing is being handled across multiple forms.
Here is a slightly modified static condensation demo that illustrates the problem:
#Import
import cffi
import numba
import numba.core.typing.cffi_utils as cffi_support
from basix.ufl import element
from dolfinx import mesh, geometry
from dolfinx.fem import (
Form,
Function,
Constant,
IntegralType,
dirichletbc,
form,
form_cpp_class,
functionspace,
locate_dofs_topological,
from dolfinx.fem.petsc import apply_lifting, assemble_matrix, assemble_vector
from dolfinx.jit import ffcx_jit
from dolfinx.mesh import locate_entities_boundary, meshtags
from ffcx.codegeneration.utils import numba_ufcx_kernel_signature as ufcx_signature
#Create mesh
msh = mesh.create_unit_square(MPI.COMM_WORLD, 2, 2)
# Stress (Se) and displacement (Ue) elements
Se = element("DG", msh.basix_cell(), 1, shape=(2, 2), symmetry=True, dtype=PETSc.RealType) # type: ignore
Ue = element("Lagrange", msh.basix_cell(), 2, shape=(2,), dtype=PETSc.RealType) # type: ignore
S = functionspace(msh, Se)
U = functionspace(msh, Ue)
sigma, tau = ufl.TrialFunction(S), ufl.TestFunction(S)
u, v = ufl.TrialFunction(U), ufl.TestFunction(U)
# Locate all facets at the free end and assign them value 1. Sort the
# facet indices (requirement for constructing MeshTags)
free_end_facets = np.sort(locate_entities_boundary(msh, 1, lambda x: np.isclose(x[0], 1.)))
mt = meshtags(msh, 1, free_end_facets, 1)
ds = ufl.Measure("ds", subdomain_data=mt)
# Homogeneous boundary condition in displacement
u_bc = Function(U)
u_bc.x.array[:] = 0
# Displacement BC is applied to the left side
left_facets = locate_entities_boundary(msh, 1, lambda x: np.isclose(x[0], 0.0))
bdofs = locate_dofs_topological(U, 1, left_facets)
bc = dirichletbc(u_bc, bdofs)
# Elastic stiffness tensor and Poisson ratio
E, nu = 1.0, 1.0 / 3.0
lam_ = E*nu/((1+nu)*(1-2*nu)) #Lame's first parameter Pa
mu_ = E/(2*(1+nu)) #Shear modulus Pa
rho_ = 1.
#Want to work
DG0 = functionspace(msh, ('DG', 0))
lam, mu, rho = Function(DG0), Function(DG0), Function(DG0)
lam.interpolate(lambda x: np.full(x.shape[1], lam_))
lam.x.scatter_forward()
mu.interpolate(lambda x: np.full(x.shape[1], mu_))
mu.x.scatter_forward()
rho.interpolate(lambda x: np.full(x.shape[1], rho_))
rho.x.scatter_forward()
##Want to work
#lam = Constant(msh, lam_)
#mu = Constant(msh, mu_)
#rho = Constant(msh, rho_)
##Works
#lam = lam_
#mu = mu_
#rho = rho_
def sigma_u(u):
"""Constitutive relation for stress-strain. Assuming plane-stress in XY"""
eps = ufl.sym(ufl.grad(u))
sigma = 2 * mu * eps + lam * ufl.Identity(2) * ufl.tr(eps)
return sigma
a00 = ufl.inner(sigma, tau) * ufl.dx
a10 = -ufl.inner(sigma, ufl.grad(v)) * ufl.dx
a01 = -ufl.inner(sigma_u(u), tau) * ufl.dx
a11 = -rho * ufl.inner(u, v) * ufl.dx
f = ufl.as_vector([0.0, 1.0 / 16])
b1 = form(-ufl.inner(f, v) * ds(1), dtype=PETSc.ScalarType) # type: ignore
# JIT compile individual blocks tabulation kernels
ufcx00, _, _ = ffcx_jit(msh.comm, a00, form_compiler_options={"scalar_type": PETSc.ScalarType}) # type: ignore
kernel00 = getattr(ufcx00.form_integrals[0], f"tabulate_tensor_{np.dtype(PETSc.ScalarType).name}") # type: ignore
ufcx01, _, _ = ffcx_jit(msh.comm, a01, form_compiler_options={"scalar_type": PETSc.ScalarType}) # type: ignore
kernel01 = getattr(ufcx01.form_integrals[0], f"tabulate_tensor_{np.dtype(PETSc.ScalarType).name}") # type: ignore
ufcx10, _, _ = ffcx_jit(msh.comm, a10, form_compiler_options={"scalar_type": PETSc.ScalarType}) # type: ignore
kernel10 = getattr(ufcx10.form_integrals[0], f"tabulate_tensor_{np.dtype(PETSc.ScalarType).name}") # type: ignore
ufcx11, _, _ = ffcx_jit(msh.comm, a11, form_compiler_options={"scalar_type": PETSc.ScalarType}) # type: ignore
kernel11 = getattr(ufcx11.form_integrals[0], f"tabulate_tensor_{np.dtype(PETSc.ScalarType).name}") # type: ignore
ffi = cffi.FFI()
cffi_support.register_type(ffi.typeof("double _Complex"), numba.types.complex128)
# Get local dofmap sizes for later local tensor tabulations
Ssize = S.element.space_dimension
Usize = U.element.space_dimension
@numba.cfunc(ufcx_signature(PETSc.ScalarType, PETSc.RealType), nopython=True) # type: ignore
def tabulate_A(A_, w_, c_, coords_, entity_local_index, permutation=ffi.NULL):
"""Element kernel that applies static condensation."""
# Prepare target condensed local element tensor
A = numba.carray(A_, (Usize, Usize), dtype=PETSc.ScalarType)
# Tabulate all sub blocks locally
A00 = np.zeros((Ssize, Ssize), dtype=PETSc.ScalarType)
kernel00(ffi.from_buffer(A00), w_, c_, coords_, entity_local_index, permutation)
A01 = np.zeros((Ssize, Usize), dtype=PETSc.ScalarType)
kernel01(ffi.from_buffer(A01), w_, c_, coords_, entity_local_index, permutation)
A10 = np.zeros((Usize, Ssize), dtype=PETSc.ScalarType)
kernel10(ffi.from_buffer(A10), w_, c_, coords_, entity_local_index, permutation)
A11 = np.zeros((Usize, Usize), dtype=PETSc.ScalarType)
kernel11(ffi.from_buffer(A11), w_, c_, coords_, entity_local_index, permutation)
# A = A11 - A10 * A00^{-1} * A01
A[:, :] = A11 - A10 @ np.linalg.solve(A00, A01)
# Prepare a Form with a condensed tabulation kernel
formtype = form_cpp_class(PETSc.ScalarType)
cells = np.arange(msh.topology.index_map(msh.topology.dim).size_local)
#Give kernel information about coefficients and constants
forms = [a00, a01, a10, a11]
ufcx_forms = [ufcx00, ufcx01, ufcx10, ufcx11]
flat_consts = [c._cpp_object for form in forms for c in form.constants()]
original_coeffs = [c for form in forms for c in form.coefficients()]
flat_coeffs = [
original_coeffs[ufcx.original_coefficient_positions[i]]._cpp_object
for ufcx in ufcx_forms for i in range(ufcx.num_coefficients)
flat_enabled = np.arange(len(flat_coeffs), dtype=np.int32)
integrals = {IntegralType.cell: [(-1, tabulate_A.address, cells, flat_enabled)]}
a_cond = Form(formtype([U._cpp_object, U._cpp_object], integrals, flat_coeffs, flat_consts, False, {}, None))
A_cond = assemble_matrix(a_cond, bcs=[bc])
A_cond.assemble()
# Pure displacement based formulation
a = form(-rho*ufl.inner(u, v) * ufl.dx - ufl.inner(sigma_u(u), ufl.grad(v)) * ufl.dx)
A = assemble_matrix(a, bcs=[bc])
#Check that the result is what we expect
A_cond.convert('dense')
A_cond_np = A_cond.getDenseArray()
A.convert('dense')
A_np = A.getDenseArray()
assert np.allclose(A_cond_np, A_np, atol=1e-8), "Something incorrect with static condensation"
Any help is appreciated. Thanks.
