Static condensation within a Newton solver for non linear poisson equation
Dear Community,
I am currently experiencing difficulties implementing a nonlinear Poisson equation using an HDG scheme with static condensation. I am essentially trying to combine the HDG tutorial (HDG scheme for the Poisson equation — DOLFINx 0.9.0 documentation) with the static condensation tutorial (Static condensation of linear elasticity — DOLFINx 0.9.0 documentation), while also implementing a Newton solver. My ultimate goal is to apply this same scheme to a compressible Euler HDG formulation.
I suspect there might be an issue with how my numba kernels are defined for static condensation, as my local form J[0][0] includes several integral types. I tried passing the tutorial example to my Newton solver (not for solving but just in the init function) to see if I could properly assemble the condensed matrix. It appears that when there is only a single integration measure, it works fine. I then attempted to define a kernel for each integration measure and add them within the Numba function, but without success - the code crashes with an enigmatic PETSc error message. Would anyone have any advice on this matter? The code consists of three files:
  • demo_HDG.py: a test case similar to the tutorial
from dolfinx.cpp.mesh import cell_num_entities
from ufl import (dot, grad, inner, Measure, CellDiameter,
                 FacetNormal, SpatialCoordinate, exp, TestFunction)
from dolfinx.fem import (locate_dofs_topological, Constant,
                         Function, functionspace, dirichletbc)
from dolfinx.mesh import locate_entities_boundary
from dolfinx.mesh import CellType, GhostMode, create_unit_square, create_submesh
from block import extract_rows, derivative_block
import sys
# sys.path.append('../')
from new_newton import StaticCondensationNewtonSolver
def compute_cell_boundary_facets(msh):
    """Compute facets for cell boundary integration"""
    tdim = msh.topology.dim
    fdim = tdim - 1
    n_f = cell_num_entities(msh.topology.cell_type, fdim)
    n_c = msh.topology.index_map(tdim).size_local
    return np.vstack((np.repeat(np.arange(n_c), n_f),
                     np.tile(np.arange(n_f), n_c))).T.flatten()
def kappa(u):
    return 1 + u**2
def set_form(u, ubar, v, vbar, f, dx, dx_f, dS):
    Res = inner(kappa(u) * grad(u), grad(v)) * dx
    Res += inner(dot(kappa(u) * grad(u), n), vbar-v) * dS
    Res += gamma * inner(ubar-u, vbar-v) * dS
    Res += inner(f, v) * dx_c
    Res += inner(Constant(facet_mesh, PETSc.ScalarType(0.0)), vbar) * dx_f
    return Res
# Initialize MPI and create mesh
comm = MPI.COMM_WORLD
N = 2
# Create mesh (2D square)
msh = create_unit_square(comm, N, N, CellType.quadrilateral,
                         ghost_mode = GhostMode.none)
# Create facet submesh
fdim = tdim - 1
# Create all required topology connections,
msh.topology.create_entities(fdim)
facet_imap = msh.topology.index_map(fdim)
num_facets = facet_imap.size_local + facet_imap.num_ghosts
facets = np.arange(num_facets, dtype=np.int32)
facet_mesh, facet_mesh_to_mesh = create_submesh(msh, fdim, facets)[:2]
# Create connectivity for facet_mesh
facet_mesh.topology.create_connectivity(fdim, fdim)
# Define function spaces
k = 2  # Polynomial order
V = functionspace(msh, ("Discontinuous Lagrange", k))
Vbar = functionspace(facet_mesh, ("Discontinuous Lagrange", k))
u, ubar = Function(V), Function(Vbar)
v, vbar = TestFunction(V), TestFunction(Vbar)
# Define measures
dx_c = Measure("dx", domain=msh)
cbf = compute_cell_boundary_facets(msh) #cell_boundary_facets
cb = 1 #cell_boundaries
ds_c = Measure("ds", subdomain_data=[(cb, cbf)], domain=msh)
dx_f = Measure("dx", domain=facet_mesh)
# Mesh to facet mesh mapping
mesh_to_facet_mesh = np.full(num_facets, -1)
mesh_to_facet_mesh[facet_mesh_to_mesh] = np.arange(len(facet_mesh_to_mesh))
entity_maps = {facet_mesh: mesh_to_facet_mesh}
# Define forms
h = CellDiameter(msh)
n = FacetNormal(msh)
gamma = 16.0 * k**2 / h
# Source term
x = SpatialCoordinate(msh)
f = 10.0 * exp(-((x[0]-0.5) * (x[0]-0.5) + (x[1]-0.5) * (x[1]-0.5)) / 0.02)
Res = set_form(u, ubar, v, vbar, f, dx_c, dx_f, ds_c(cb))
Fr = extract_rows(Res, [v, vbar])
J = derivative_block(Fr, [u, ubar])
# Boundary conditions
def locate_boundary(x, y_value):
    return np.isclose(x[1], y_value)
top = locate_entities_boundary(msh, fdim,  lambda x: locate_boundary(x, 1.0))
bottom = locate_entities_boundary(msh, fdim, lambda x: locate_boundary(x, 0.0))
# Convert to facet mesh indices
facet_mesh_bdr_facets = mesh_to_facet_mesh[np.concatenate([top, bottom])]
dofs = locate_dofs_topological(Vbar, fdim, facet_mesh_bdr_facets)
# Apply sinusoidal boundary condition
def boundary_value(x):
    values = np.zeros(x.shape[1])
    values[:] = np.sin(5 * x[0])
    return values
# Create boundary condition
boundary_function = Function(Vbar)
boundary_function.interpolate(lambda x: np.sin(5 * x[0]))
bc = dirichletbc(boundary_function, dofs)
solver = StaticCondensationNewtonSolver(Fr, J, [bc], [], entity_maps, [V, Vbar], msh)
#This line makes dolfinx crash
solver.assembly_test()
# Let's show what we need
print("Type of J:", type(J))
print("Type of J[0][0]:", type(J[0][0]))
print("\nFunction spaces:")
print("V (local space):")
print("- type:", type(V))
print("- dimension:", V.element.space_dimension)
print("\nVbar (global space):")
print("- type:", type(Vbar))
print("- dimension:", Vbar.element.space_dimension)
# Debug HDG forms
print("Analysis of HDG forms:")
# Verification of Fr
print("\nAnalysis of Fr:")
for i, f in enumerate(Fr):
   print(f"\nFr[{i}] :")
   try:
       args = f.arguments()
       print(f"- number of arguments: {len(args)}")
       for j, arg in enumerate(args):
           space = arg.ufl_function_space()
           print(f"- argument {j} space: {space}")
           print(f"- argument {j} element: {space.ufl_element()}")
   except Exception as e:
       print(f"- detailed error: {str(e)}")
# Verification of J with more details
print("\nAnalysis of J:")
for i in range(2):
   for j in range(2):
       print(f"\nJ[{i}][{j}] :")
       try:
           form = J[i][j]
           # Let's show the form itself
           print(f"- form: {form}")
           # Show the integrals
           integrals = form.integrals()
           print(f"- number of integrals: {len(integrals)}")
           for k, integral in enumerate(integrals):
               print(f"- integral {k} type: {integral.integral_type()}")
# For spaces, let's use attributes directly
print("\nSpaces used:")
print(f"V (local) dimension: {V.element.space_dimension}")
print(f"Vbar (global) dimension: {Vbar.element.space_dimension}")
#%%Debug
# Imports for linear elasticity example
from basix.ufl import element
from dolfinx.mesh import locate_entities_boundary, meshtags
# Stress (Se) and displacement (Ue) elements
Se = element("DG", msh.basix_cell(), 1, shape=(2, 2), symmetry=True, dtype=PETSc.RealType)  # type: ignore
Ue = element("Lagrange", msh.basix_cell(), 2, shape=(2,), dtype=PETSc.RealType)  # type: ignore
S = functionspace(msh, Se)
U = functionspace(msh, Ue)
sigma, tau = ufl.TrialFunction(S), ufl.TestFunction(S)
u, v = ufl.TrialFunction(U), ufl.TestFunction(U)
# Locate all facets at the free end and assign them value 1. Sort the
# facet indices (requirement for constructing MeshTags)
free_end_facets = np.sort(locate_entities_boundary(msh, 1, lambda x: np.isclose(x[0], 48.0)))
mt = meshtags(msh, 1, free_end_facets, 1)
ds = ufl.Measure("ds", subdomain_data=mt)
# Homogeneous boundary condition in displacement
u_bc = Function(U)
u_bc.x.array[:] = 0
# Displacement BC is applied to the left side
left_facets = locate_entities_boundary(msh, 1, lambda x: np.isclose(x[0], 0.0))
bdofs = locate_dofs_topological(U, 1, left_facets)
bc = dirichletbc(u_bc, bdofs)
# Elastic stiffness tensor and Poisson ratio
E, nu = 1.0, 1.0 / 3.0
def sigma_u(u):
   """Constitutive relation for stress-strain. Assuming plane-stress in XY"""
   eps = 0.5 * (ufl.grad(u) + ufl.grad(u).T)
   sigma = E / (1.0 - nu**2) * ((1.0 - nu) * eps + nu * ufl.Identity(2) * ufl.tr(eps))
   return sigma
a00 = ufl.inner(sigma, tau) * ufl.dx
a10 = -ufl.inner(sigma, ufl.grad(v)) * ufl.dx
a01 = -ufl.inner(sigma_u(u), tau) * ufl.dx
# dummy form
a11 = -ufl.inner(ufl.grad(u), ufl.grad(v)) * ufl.dx
solver = StaticCondensationNewtonSolver(Fr, [[a00, a01], [a10, a11]], [bc], [], entity_maps, [S, U], msh)
  • block.py: borrowed from the dolfin_dg module :
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
Created on Wed Jan  8 18:07:35 2025
@author: bouteillerp
import dolfinx.fem
class SeparateSpaceFormSplitter(ufl.corealg.multifunction.MultiFunction):
    def split(self, form, v, u=None):
        self.vu = tuple((v, u))
        return ufl.algorithms.map_integrands.map_integrand_dags(self, form)
    def argument(self, obj):
        if obj not in self.vu:
            return ufl.constantvalue.Zero(shape=obj.ufl_shape)
        return obj
    expr = ufl.corealg.multifunction.MultiFunction.reuse_if_untouched
def extract_rows(F, v, module = ufl):
    Parameters
    F : UFL residual formulation
    v : Ordered list of test functions
    Returns
    List of extracted block residuals ordered corresponding to each test
    function
    vn = len(v)
    L = [None for _ in range(vn)]
    fs = SeparateSpaceFormSplitter()
    for vi in range(vn):
        # Do the initial split replacing testfunctions with zero
        L[vi] = fs.split(F, v[vi])
        # Now remove the empty forms. Why don't FFC/UFL do this already?
        L_reconstruct = []
        for integral in L[vi].integrals():
            arguments = ufl.algorithms.analysis.extract_arguments(integral)
            if len(arguments) < 1:
                continue
            # Sanity checks: Should be only one test function, and it should
            # be the one we want to keep
            assert len(arguments) == 1
            assert arguments[0] is v[vi]
            L_reconstruct.append(integral)
        # Generate the new form with the removed zeroes
        L[vi] = ufl.Form(L_reconstruct)
    return L
def derivative_block(F, u, du=None, coefficient_derivatives=None):
    Parameters
    F : Block residual formulation
    u : Ordered solution functions
    du : Ordered trial functions
    coefficient_derivatives : Prescribed derivative map
    Returns
    Block matrix corresponding to the ordered components of the
    Gateaux/Frechet derivative.
    if isinstance(F, ufl.Form):
        return ufl.derivative(F, u, du, coefficient_derivatives)
    if not isinstance(F, (list, tuple)):
        raise TypeError("Expecting F to be a list of Forms. Found: %s"
                        % str(F))
    if not isinstance(u, (list, tuple)):
        raise TypeError("Expecting u to be a list of Coefficients. Found: %s"
                        % str(u))
    if du is not None:
        if not isinstance(du, (list, tuple)):
            raise TypeError("Expecting du to be a list of Arguments. Found: %s"
                            % str(u))
    import itertools
    from ufl.algorithms.apply_derivatives import apply_derivatives
    from ufl.algorithms.apply_algebra_lowering import apply_algebra_lowering
    m, n = len(u), len(F)
    if du is None:
        du = [None] * m
    J = [[None for _ in range(m)] for _ in range(n)]
    for (i, j) in itertools.product(range(n), range(m)):
        gateaux_derivative = ufl.derivative(F[i], u[j], du[j],
        gateaux_derivative = apply_derivatives(
            apply_algebra_lowering(gateaux_derivative))
        if gateaux_derivative.empty():
            gateaux_derivative = None
        J[i][j] = gateaux_derivative
    return J
  • new_newton.py: intended as a dolfinx version of the Newton solver from dolfin_dg, but which required leopart :
Created on Thu Jan  9 11:06:22 2025
import cffi
import numba
import numba.core.typing.cffi_utils as cffi_support
    Form,
    IntegralType,
    form,
    form_cpp_class,
                               create_matrix, create_vector, set_bc)
from dolfinx.jit import ffcx_jit
from ffcx.codegeneration.utils import numba_ufcx_kernel_signature as ufcx_signature
from dolfinx.fem import Function
class StaticCondensationNewtonSolver:
    def __init__(self, F, J, bcs, bcs_homog, entity_maps, V_list, msh, rtol=1e-12, atol=1e-10, maximum_iterations=20):
        F : [F_local, F_global] - Résidus par blocs
        J : [[J_ll, J_lg], [J_gl, J_gg]] - Jacobien par blocs
        # Compilation JIT des noyaux avec ffcx_jit
        ufcx_ll, _, _ = ffcx_jit(MPI.COMM_WORLD, J[0][0],
                                     form_compiler_options={"scalar_type": PETSc.ScalarType})
        ufcx_lg, _, _ = ffcx_jit(MPI.COMM_WORLD, J[0][1],
        ufcx_gl, _, _ = ffcx_jit(MPI.COMM_WORLD, J[1][0],
        ufcx_gg, _, _ = ffcx_jit(MPI.COMM_WORLD, J[1][1],
#%%####### Nice try but not working
        # kernels_ll = []
        # i = 0
        # while True:
        #     integral = ufcx_ll.form_integrals[i]
        #     if not integral:  # Arrêt quand on atteint NULL
        #         break
        #     kernel = getattr(integral, f"tabulate_tensor_{np.dtype(PETSc.ScalarType).name}")
        #     kernels_ll.append(kernel)
        #     i += 1
        #     kernels_lg = []
        # i = 0
        # while True:
        #     integral = ufcx_lg.form_integrals[i]
        #     if not integral:
        #         break
        #     kernels_lg.append(kernel)
        #     i += 1
        # kernels_gl = []
        # i = 0
        # while True:
        #     integral = ufcx_gl.form_integrals[i]
        #     if not integral:
        #         break
        #     kernels_gl.append(kernel)
        #     i += 1
        # kernels_gg = []
        # i = 0
        # while True:
        #     integral = ufcx_gg.form_integrals[i]
        #     if not integral:
        #         break
        #     kernels_gg.append(kernel)
        #     i += 1
        # print(f"Nombre d'intégrales trouvées :")
        # print(f"- J_ll : {len(kernels_ll)}")
        # print(f"- J_lg : {len(kernels_lg)}")
        # print(f"- J_gl : {len(kernels_gl)}")
        # print(f"- J_gg : {len(kernels_gg)}")
        # Extraction des kernels
        kernel_ll = getattr(ufcx_ll.form_integrals[0],
        # #Aditional kernel for boundary integrals
        # kernel_ll_1 = getattr(ufcx_ll.form_integrals[1],
        #               f"tabulate_tensor_{np.dtype(PETSc.ScalarType).name}")
        # kernel_ll_2 = getattr(ufcx_ll.form_integrals[2],
        kernel_lg = getattr(ufcx_lg.form_integrals[0],
        kernel_gl = getattr(ufcx_gl.form_integrals[0],
        kernel_gg = getattr(ufcx_gg.form_integrals[0],
        print("\nAnalyse des intégrales de tous les blocs :")
        print("\nJ[0][0] (A_ll) :")
        i = 0
        while ufcx_ll.form_integrals[i]:
            print(f"- kernel {i} : {ufcx_ll.form_integrals[i]}")
            i += 1
        print("\nJ[0][1] (A_lg) :")
        i = 0
        while ufcx_lg.form_integrals[i]:
            print(f"- kernel {i} : {ufcx_lg.form_integrals[i]}")
            i += 1
        print("\nJ[1][0] (A_gl) :")
        i = 0
        while ufcx_gl.form_integrals[i]:
            print(f"- kernel {i} : {ufcx_gl.form_integrals[i]}")
            i += 1
        print("\nJ[1][1] (A_gg) :")
        i = 0
        while ufcx_gg.form_integrals[i]:
            print(f"- kernel {i} : {ufcx_gg.form_integrals[i]}")
            i += 1
        ffi = cffi.FFI()
        cffi_support.register_type(ffi.typeof("double _Complex"), numba.types.complex128)
        V, Vbar = V_list[0], V_list[1]
        local_size = V.element.space_dimension
        global_size = Vbar.element.space_dimension
        # Static condensation kernel
        @numba.cfunc(ufcx_signature(PETSc.ScalarType, PETSc.RealType), nopython=True)  # type: ignore
        def tabulate_condensed(A_, w_, c_, coords_, entity_local_index, permutation=ffi.NULL):
            # Préparation des matrices locales
            A = numba.carray(A_, (global_size, global_size), dtype=PETSc.ScalarType)
            # Tabulation des sous-blocs
            A_ll = np.zeros((local_size, local_size), dtype=PETSc.ScalarType)
            kernel_ll(ffi.from_buffer(A_ll), w_, c_, coords_, entity_local_index, permutation)
            # A_ll_surf = np.zeros((local_size, local_size), dtype=PETSc.ScalarType)
            # kernel_ll_1(ffi.from_buffer(A_ll_surf), w_, c_, coords_, entity_local_index, permutation)
            # A_ll += A_ll_surf  # Addition des contributions volumique et surfacique
            # A_ll_2 = np.zeros((local_size, local_size), dtype=PETSc.ScalarType)
            # kernel_ll_2(ffi.from_buffer(A_ll_2), w_, c_, coords_, entity_local_index, permutation)
            # A_ll += A_ll_2
            A_lg = np.zeros((local_size, global_size), dtype=PETSc.ScalarType)
            kernel_lg(ffi.from_buffer(A_lg), w_, c_, coords_, entity_local_index, permutation)
            A_gl = np.zeros((global_size, local_size), dtype=PETSc.ScalarType)
            kernel_gl(ffi.from_buffer(A_gl), w_, c_, coords_, entity_local_index, permutation)
            A_gg = np.zeros((global_size, global_size), dtype=PETSc.ScalarType)
            kernel_gg(ffi.from_buffer(A_gg), w_, c_, coords_, entity_local_index, permutation)
            # Condensation statique
            A[:, :] = A_gg - A_gl @ np.linalg.solve(A_ll, A_lg)
        # Création de la forme condensée
        formtype = form_cpp_class(PETSc.ScalarType)
        cells = np.arange(msh.topology.index_map(msh.topology.dim).size_local)
        integrals = {IntegralType.cell: [(-1, tabulate_condensed.address, cells,
                                         np.array([], dtype=np.int8))]}
        self.a_cond = Form(formtype([Vbar._cpp_object, Vbar._cpp_object],
                                    integrals, [], [], False, {}, None))
        # Solver configuration
        self.solver = PETSc.KSP().create(MPI.COMM_WORLD)
        self.solver.setOperators(create_matrix(self.a_cond))
        self.solver.setType(PETSc.KSP.Type.PREONLY)
        pc = self.solver.getPC()
        pc.setType(PETSc.PC.Type.LU)
        # Configuration du solveur linéaire pour la back-substitution
        self.local_solver = PETSc.KSP().create(MPI.COMM_WORLD)
        self.local_solver.setType(PETSc.KSP.Type.PREONLY)
        pc_local = self.local_solver.getPC()
        pc_local.setType(PETSc.PC.Type.LU)
        self.bcs = bcs
        self.bcs_homog = bcs_homog
        self.rtol = rtol
        self.atol = atol
        self.maximum_iterations = maximum_iterations
        # self._setup_forms(F, J, entity_maps)
    # def _setup_forms(self, F, J, entity_maps):
    #     """Configuration des formes variationnelles."""
    #     self.F_local = form(F[0])
    #     self.F_global = form(F[1], entity_maps = entity_maps)
    #     self.J_local = form(J[0][0])
    #     self.J_coupling = form(J[0][1], entity_maps = entity_maps)
    #     self.J_global = form(J[1][1], entity_maps = entity_maps)
    def assembly_test(self):
        A_cond = assemble_matrix(self.a_cond, bcs = self.bcs)
        print("Assembly")
    # def solve(self, u, ubar):
    #     Newton loop, probably buggued but it does not matter for now
    #     # Application des conditions aux limites
    #     du = Function(u.function_space)
    #     dubar = Function(ubar.function_space)
    #     for bc in self.bcs:
    #         # set_bc(u.x.petsc_vec, bc)
    #         set_bc(ubar.x.petsc_vec, bc)
    #     # Assemblage initial
    #     A_cond = assemble_matrix(self.a_cond, bcs=self.bcs)
    #     b = assemble_vector(self.F_global)
    #     apply_lifting(b, [self.a_cond], bcs=[self.bcs])
    #     for it in range(self.maximum_iterations):
    #         # Assemblage du système condensé
    #         A_cond.assemble()
    #         self.solver.setOperators(A_cond)
    #         # Assemblage du résidu
    #         b.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
    #         # Résolution du système condensé
    #         b.scale(-1.0)  # -F(u_n)
    #         self.solver.solve(b, dubar.x.petsc_vec)
    #         dubar.x.scatter_forward()
    #         for bc in self.bcs_homog:
    #             set_bc(dubar.x.petsc_vec, bc)
    #         # Back-substitution pour obtenir du
    #         du.x.array[:] = self._back_substitute(du, dubar)
    #         du.x.scatter_forward()
    #         # Mise à jour de la solution : u_(n+1) = u_n + du
    #         u.x.array[:] += du.x.array
    #         ubar.x.array[:] += dubar.x.array
    #         u.x.scatter_forward()
    #         ubar.x.scatter_forward()
    #     print(f"Failed to converge in {self.maximum_iterations} iterations")
    #     return self.maximum_iterations, False
    # def _back_substitute(self, u, ubar):
    #     """Back-substitution, probably buggued but it does not matter for now"""
    #     A_ll = assemble_matrix(self.J_local)
    #     A_ll.assemble()
    #     self.local_solver.setOperators(A_ll)
    #     A_lg = assemble_matrix(self.J_coupling)
    #     b_l = assemble_vector(self.F_local)
    #     # Calcul de -A_ll^{-1}(A_lg * ubar + b_l)
    #     temp_vec = create_vector(self.F_local)
    #     A_lg.mult(ubar.x.petsc_vec, temp_vec)
    #     temp_vec.axpy(1.0, b_l)
    #     temp_vec.scale(-1.0)
    #     # Résolution du système local
    #     u_local = create_vector(self.F_local)
    #     self.local_solver.solve(temp_vec, u_local)
    #     return u_local.array
Any guidance would be greatly appreciated.
Sincerely,
Paul
EDIT, I think the crash comes from calling with different measures simultaneously. I imagine that we would need to assemble the surface and volume contributions separately, then sum the contributions before local condensation. Unfortunately, I have the impression that it’s not possible to proceed this way, i.e., to have multiple kernels called simultaneously? Would there be a way to write something like:
integrals = {
IntegralType.cell:           [(-1, tabulate_cell.address,  cells,  np.array([], dtype=np.int8))],
IntegralType.interior_facet: [(-1, tabulate_facet.address, facets, np.array([], dtype=np.int8))]
Here is a (not working) exemple,
from ufl import (dot, grad, inner, extract_blocks, MixedFunctionSpace,
                 TrialFunctions, TestFunctions, Measure, CellDiameter,
                 FacetNormal, SpatialCoordinate, exp)
    fdim = tdim - 1
dtype = PETSc.ScalarType
N = 2
fdim = tdim - 1
# Create all required topology connections, les trois lignes ne sont probablements
# pas toutes utiles
fdim = tdim - 1
facet_cell = msh.topology.connectivity(fdim, tdim)
interior_facets = []
for f in range(msh.topology.index_map(fdim).size_local):
    if len(facet_cell.links(f)) == 2:  # Facette intérieure
        interior_facets.append(f)
interior_facets = np.array(interior_facets, dtype=np.int32)
k = 3  # Polynomial order
W = MixedFunctionSpace(V, Vbar)
u, ubar = TrialFunctions(W)
v, vbar = TestFunctions(W)
# Define measures
dx_f = Measure("dx", domain=facet_mesh) #Désigne en ralité une mesure surfacique !
# Define forms
# Source term
f = 10.0 * exp(-((x[0]-0.5)*(x[0]-0.5)+(x[1]-0.5)*(x[1]-0.5))/0.02)
a_vol = inner(grad(u), grad(v)) * dx_c
a_surf = inner(dot(grad(u), n), vbar-v) * ds_c(cb)
a_surf += inner(ubar - u, dot(grad(v), n)) * ds_c(cb)
a_surf += gamma * inner(ubar-u, vbar-v) * ds_c(cb)
L = inner(f, v) * dx_c
L += inner(Constant(facet_mesh, dtype(0.0)), vbar) * dx_f
a_blocked = extract_blocks(a_surf)
a00_surf = a_blocked[0][0]
a10_surf = a_blocked[1][0]
a01_surf = a_blocked[0][1]
a11_surf = a_blocked[1][1]
a_vol_blocked = extract_blocks(a_vol)
a00_vol = a_vol_blocked[0][0]
import cffi
import numba
from dolfinx.fem import (Form, IntegralType, form_cpp_class)
from dolfinx.fem.petsc import assemble_matrix
ffi = cffi.FFI()
# JIT compile individual blocks tabulation kernels
ufcx00surf, _, _ = ffcx_jit(msh.comm, a00_surf, form_compiler_options={"scalar_type": PETSc.ScalarType})
kernel00  = getattr(ufcx00surf.form_integrals[0], f"tabulate_tensor_{np.dtype(PETSc.ScalarType).name}")
ufcx01surf, _, _ = ffcx_jit(msh.comm, a01_surf, form_compiler_options={"scalar_type": PETSc.ScalarType})  # type: ignore
kernel01 = getattr(ufcx01surf.form_integrals[0], f"tabulate_tensor_{np.dtype(PETSc.ScalarType).name}")  # type: ignore
ufcx10surf, _, _ = ffcx_jit(msh.comm, a10_surf, form_compiler_options={"scalar_type": PETSc.ScalarType})  # type: ignore
kernel10 = getattr(ufcx10surf.form_integrals[0], f"tabulate_tensor_{np.dtype(PETSc.ScalarType).name}")  # type: ignore
ufcx11surf, _, _ = ffcx_jit(msh.comm, a11_surf, form_compiler_options={"scalar_type": PETSc.ScalarType})  # type: ignore
kernel11 = getattr(ufcx11surf.form_integrals[0], f"tabulate_tensor_{np.dtype(PETSc.ScalarType).name}")  # type: ignore
ufcx00vol, _, _ = ffcx_jit(msh.comm, a00_vol, form_compiler_options={"scalar_type": PETSc.ScalarType})  # type: ignore
kernel00vol = getattr(ufcx00vol.form_integrals[0], f"tabulate_tensor_{np.dtype(PETSc.ScalarType).name}")  # type: ignore
# Get local dofmap sizes for later local tensor tabulations
def tabulate_A_surf(A_, w_, c_, coords_, entity_local_index, permutation=ffi.NULL):
    A_00 = np.zeros((local_size, local_size), dtype=PETSc.ScalarType)
    kernel00(ffi.from_buffer(A_00), w_, c_, coords_, entity_local_index, permutation)
    A_01 = np.zeros((local_size, global_size), dtype=PETSc.ScalarType)
    kernel01(ffi.from_buffer(A_01), w_, c_, coords_, entity_local_index, permutation)
    A_10 = np.zeros((global_size, local_size), dtype=PETSc.ScalarType)
    kernel10(ffi.from_buffer(A_10), w_, c_, coords_, entity_local_index, permutation)
    A_11 = np.zeros((global_size, global_size), dtype=PETSc.ScalarType)
    kernel11(ffi.from_buffer(A_11), w_, c_, coords_, entity_local_index, permutation)
    # Static condensation can't work because A_00_surf is singular
    A[:, :] = A_11 - A_10 @ np.linalg.solve(A_00, A_01)
def tabulate_A_vol(A_, w_, c_, coords_, entity_local_index, permutation=ffi.NULL):
    # A00
    A00vol = np.zeros((local_size, local_size), dtype=PETSc.ScalarType)
    kernel00vol(ffi.from_buffer(A00vol), w_, c_, coords_, entity_local_index, permutation)
    # A[:, :] = A_11 - A_10 @ np.linalg.solve(A00, A_01)
# Prepare a Form with a condensed tabulation kernel
formtype = form_cpp_class(PETSc.ScalarType)  # type: ignore
integrals = {IntegralType.interior_facet: [(-1, tabulate_A_surf.address, interior_facets, np.array([], dtype=np.int8))]}
# integrals = {
#   IntegralType.cell:           [(-1, tabulate_A_vol.address,  cells,  np.array([], dtype=np.int8))],
#   IntegralType.exterior_facet: [(-1, tabulate_A_surf.address, facets, np.array([], dtype=np.int8))]
a_cond = Form(formtype([Vbar._cpp_object, Vbar._cpp_object], integrals, [], [], False, {}, None))
    return values
A_cond = assemble_matrix(a_cond, bcs=[bc])
A_cond.assemble()
Any help would be greatly appreciated, thanks a lot !
Paul
Dear community,
Have there been any updates regarding this difficulty I encountered? Is it possible that the pull request https://github.com/FEniCS/ffcx/pull/753
is somehow related to the issue, i.e., would it allow for static condensation with a mixture of surface and volume integrals?
Thank you in advance, Paul
Have you fingured it out?
