Hi everyone
I’ve run into some quite peculiar behaviour of the LinearSolver with LU factorisation and otherwise default settings.
I’m trying to solve the Stokes problem
with boundary conditions
Depending on the mesh or the choice of elements, the LinearSolver often computes inf values, even though both the continuous and the discrete problems should be well-posed. If the code is run in parallel, or if "pc_factor_mat_solver_type" is set to "mumps" or "umfpack", the solution is correct. I cannot find any systematics behind this:
Unit square
"pc_factor_mat_solver_type" |
P2-P1 elements | P2-P0 elements |
| default | ||
"mumps" |
"umfpack" |
DFG 2-D benchmark
| default | ||
"mumps" |
"umfpack" |
MWE on unit square
from dolfinx import fem, mesh
from ufl import TrialFunctions, TestFunctions, div, grad, inner, dx
domain = mesh.create_unit_square(
comm=MPI.COMM_WORLD,
nx=10,
ny=10,
cell_type=mesh.CellType.triangle,
diagonal=mesh.DiagonalType.crossed
# Function spaces
V_el = element("P", domain.topology.cell_name(), 2, shape=(2, ))
Q_el = element("DG", domain.topology.cell_name(), 0)
# Q_el = element("P", domain.topology.cell_name(), 1)
VQ = fem.functionspace(domain, mixed_element([V_el, Q_el]))
V, _ = VQ.sub(0).collapse()
# Dirichlet BCs for left, top and bottom walls
uD = fem.Function(V)
uD.interpolate(lambda x: (x[1]*(1. - x[1]), 0.*x[0]))
dirichlet_facets = mesh.locate_entities_boundary(
msh=domain,
dim=1,
marker=lambda x: np.isclose(x[0], 0.) | np.isclose(x[1], 1.) | np.isclose(x[1], 0.)
dirichlet_dofs = fem.locate_dofs_topological((VQ.sub(0), V), 1, dirichlet_facets)
bc = fem.dirichletbc(uD, dirichlet_dofs, VQ.sub(0))
# Weak form
(u, p) = TrialFunctions(VQ)
(v, q) = TestFunctions(VQ)
a = inner(grad(u), grad(v)) * dx - p * div(v) * dx - q * div(u) * dx
L = inner(fem.Constant(domain, (0., 0.)), v) * dx
lu_solver = {"ksp_type": "preonly", "pc_type": "lu"} # gives inf
# lu_solver["pc_factor_mat_solver_type"] = "mumps" # works
# lu_solver["pc_factor_mat_solver_type"] = "umfpack" # works
problem = LinearProblem(a, L, bcs=[bc], petsc_options=lu_solver)
uph = problem.solve()
uh, ph = uph.sub(0).collapse(), uph.sub(1).collapse()
u_error2_form = fem.form(inner(uh - uD, uh - uD) * dx + inner(grad(uh - uD), grad(uh - uD)) * dx)
u_error2_subdomain = fem.assemble_scalar(u_error2_form)
u_error2 = MPI.COMM_WORLD.reduce(u_error2_subdomain, op=MPI.SUM)
u_min = MPI.COMM_WORLD.reduce(np.min(uh.x.array), op=MPI.MIN)
u_max = MPI.COMM_WORLD.reduce(np.max(uh.x.array), op=MPI.MAX)
if MPI.COMM_WORLD.rank == 0:
print("Velocity error:", np.sqrt(u_error2))
print("Velocity min:", u_min)
print("Velocity max:", u_max)
MWE on DFG 2-D benchmark domain
from dolfinx import fem, io, mesh
# Meshing
channel = gmsh.model.occ.addRectangle(x=0, y=0, z=0, dx=2.2, dy=.41)
obstacle = gmsh.model.occ.addDisk(xc=.2, yc=.2, zc=0, rx=.05, ry=.05)
gmsh.model.occ.cut([(2, channel)], [(2, obstacle)])
gmsh.model.occ.synchronize()
domain_entities = [entity[1] for entity in gmsh.model.getEntities(dim=2)]
gmsh.model.addPhysicalGroup(2, domain_entities, tag=1)
gmsh.option.setNumber("Mesh.CharacteristicLengthMin", .05)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax", .05)
gmsh.model.mesh.generate(dim=2)
domain, cell_tags, facet_tags = io.gmshio.model_to_mesh(
model=gmsh.model,
rank=0,
gdim=2
gmsh.finalize()
# Function spaces
# Dirichlet BCs for obstacle, left, top and bottom walls
uD.interpolate(lambda x: (x[1]*(.41 - x[1]), 0.*x[0]))
msh=domain,
dim=1,
marker=lambda x: ~np.isclose(x[0], 2.2) | np.isclose(x[1], 0.) | np.isclose(x[1], .41)
# Weak form
lu_solver = {"ksp_type": "preonly", "pc_type": "lu"} # gives inf with P2-P0 elements
Using conda with FEniCSx version 0.9.0 and PETSc version 3.22.3
Any ideas on what’s going on here?
