Hi
I am solving a Hyperelasticity problem with a strain energy function in this form:
The \mu and \lambda are Lame constants. The last integral is an additional term. The term p(\theta) is defined as:
where \alpha is a constant. The parameter \beta is defined as \beta=a_0 \cdot C \cdot a_0
C is the right Cauchy deformation tensor and a_0 is function of \theta:
The parameter \beta could be rewritten:
The \beta in integrand (last term in the first equation) includes the components of C tensor . If I ignore the \beta and keep only p(\theta) in the integrand and use quad from scipy.integrate, it works fine but I need to have \beta included! In this case scipy.integrate does NOT work anymore.
Is there any idea how this integration should be implemented based on the above explanation?
Here is my implementation:
from scipy.integrate import quad
n = 1
mesh = BoxMesh(Point(0, 0, 0), Point(1, 1, 1), n, n, n)
#define boundaries
class left(SubDomain):
return on_boundary and near(x[0], 0.0)
class right(SubDomain):
tol = 1E-14
return (on_boundary and (abs(x[0] - 1.0) < tol))
Left = left()
Right = right()
boundaries = MeshFunction('size_t', mesh, mesh.topology().dim()-1)
boundaries.set_all(0)
#Marking boundaries
Left.mark(boundaries, 1)
Right.mark(boundaries, 2)
domains = MeshFunction('size_t', mesh, mesh.topology().dim())
ds = Measure("ds", subdomain_data=boundaries)
dx = Measure('dx',subdomain_data=domains)
V = VectorFunctionSpace(mesh, 'CG', degree=1)
bc = DirichletBC(V, Constant((0., 0.,0.)),boundaries, 1)
du = TrialFunction(V) # Trial function
v = TestFunction(V) # Test function
u = Function(V) # Displacement field
d = u.geometric_dimension()
I = Identity(d) # Identity tensor
b = F * F.T # Left Cauchy-Green tensor
Ic = tr(C)
J = det(F)
E, nu = 1E6, 0.46
mu = 0.4e6
lmbda= Constant(E*nu/((1 + nu)*(1 - 2*nu)))
force = Constant((1.0, 0.0, 0.0))
alpha = 1.26
# DefinE BETA
a_0 = as_vector([[1, 0,0]])
BETA = inner(dot(a_0,C),a_0)
def integrand(Theta):
BETA = pow(np.cos(Theta),2)*C[0,0] + pow(np.sin(Theta),2)*C[1,1] + np.cos(Theta)*np.sin(Theta)*C[0,1] + np.cos(Theta)*np.sin(Theta)*C[1,0]
return ((1. / (np.pi * alpha)) * np.exp(np.cos(2. * (Theta))))*BETA # It works if BETA is removed
P_int = quad(integrand, - np.pi/2., np.pi/2.)
VAL = list(P_int)[0]
#print (VAL)
psi = ((lmbda / 2.)*pow(ln(J),2)+0.5*mu*(Ic-3) + VAL)*dx - dot(force, u)*ds(2)
F1 = derivative(psi, u, v)
# Compute Jacobian
Jac = derivative(F1, u, du)
problem = NonlinearVariationalProblem(F1, u, bc, Jac)
solver.solve()
