In this example code, I am trying to solve two copies of the Poisson equation, but using the MixedFunctionSpace()
function of the mixed dimensional branch by @cdaversin. I set up a MixedFunctionSpace()
of two spaces, each of which will contain a solution to the Poisson equation, but with different boundary conditions.
boxlength = 1
# Define mesh and function spaces
mesh = RectangleMesh(Point(0, 0), Point(boxlength, boxlength),
32, 32)
W = MixedFunctionSpace(V, V)
# Create classes for boundaries
class Left(SubDomain):
return near(x[0], 0.0)
class Right(SubDomain):
return near(x[0], boxlength)
class Bottom(SubDomain):
return near(x[1], 0.0)
class Top(SubDomain):
return near(x[1], boxlength)
left = Left()
right = Right()
top = Top()
bottom = Bottom()
sLef = 1
left.mark(boundaries, sLef)
sRig = 2
right.mark(boundaries, sRig)
sTop = 3
top.mark(boundaries, sTop)
sBot = 4
bottom.mark(boundaries, sBot)
# Dirichlet boundary conditions
boundfunct = Expression('x[1]*x[1]', degree = 1)
bcsA = [DirichletBC(W.sub_space(0), 1.0, boundaries, sTop)]
bcsB = [DirichletBC(W.sub_space(1), boundfunct, boundaries, sBot)]
bcs = bcsA + bcsB
# Define model parameters
g_Lef = Expression('0', degree = 1)
g_Rig = Expression('0', degree = 1)
g_Top = Expression('0', degree = 1)
g_Bot = Expression('0', degree = 1)
# Define measures for boundary terms
# Define variational form
uA, uB = TrialFunctions(W)
vA, vB = TestFunctions(W)
aA = inner(grad(uA), grad(vA))*dx
LA = - g_Lef*vA*ds(sLef) - g_Rig*vA*ds(sRig) - g_Bot*vA*ds(sBot)
aB = inner(grad(uB), grad(vB))*dx
LB = - g_Lef*vB*ds(sLef) - g_Rig*vB*ds(sRig) - g_Top*vB*ds(sTop)
a = aA + aB
L = LA + LB
sol = Function(W)
solve(a == L, sol, bcs)
In this code, I attempt to apply a constant uA = 1
Dirichlet boundary condition to the uA
solution, and the boundfunct
boundary condition to the uB
function. However, this code applies the constant boundary condition to both uA
and uB
How do I apply a different boundary condition to each subspace of a MixedFunctionSpace
