I’m compiling fenics 2019.2.0 on a cluster, and seeing some errors during compilation that I never saw before. When I run a script for the first time, and fenics has to compile all forms, it fails with this message:
------------------- Start compiler output ------------------------
/usr/bin/ld: symbol lookup error: /usr/lib64/power9/libpthread.so.0: undefined symbol: pthread_mutex_lock
collect2: error: ld returned 127 exit status
------------------- End compiler output ------------------------
raise DijitsoError("Dijitso JIT compilation failed, see '%s' for details"
dijitso.jit.DijitsoError: Dijitso JIT compilation failed, see '~/jitfailure-ffc_element_5a01f62d0f2c0fe5f4320b0433b4b3fb72e2b207' for details
if i run readelf -a /usr/lib64/power9/libpthread.so.0 I get the following output:
215: 000000000000c090 1120 FUNC WEAK DEFAULT 12 pthread_mutex_lock@@GLIBC_2.17 [<localentry>: 8]
244: 000000000000c090 1120 FUNC GLOBAL DEFAULT 12 __pthread_mutex_lock@@GLIBC_2.17 [<localentry>: 8]
724: 0000000000000000 0 FILE LOCAL DEFAULT ABS pthread_mutex_lock.c
736: 000000000000b860 2092 FUNC LOCAL DEFAULT 12 __pthread_mutex_lock_full [<localentry>: 8]
3321: 000000000000c090 1120 FUNC LOCAL DEFAULT 12 __GI___pthread_mutex_lock [<localentry>: 8]
3576: 000000000000c090 1120 FUNC WEAK DEFAULT 12 pthread_mutex_lock [<localentry>: 8]
3696: 000000000000c090 1120 FUNC GLOBAL DEFAULT 12 __pthread_mutex_lock [<localentry>: 8]
Applies to region from 0xb862 to 0xc4f0 (.annobin_pthread_mutex_lock.c)
Interestingly, if I run recompile.sh from the jitfailure folder, it just runs.
Anyway, looking for this error online, it seems that a solution should be to add the flag -pthread at the compilation stage.
However, this compilation step is hidden to me, since it’s done by ffc automatically if I’m not mistaken. It also seems that the -pthread flag should be added at the end of the compilation command, that is, the position where the flag is added counts.
So I guess ffc should run something like this example:
g++ -Wall -shared -fPIC -std=c++11 -O2 -I./lib/python3.8/site-packages/ffc/backends/ufc -I~/.cache/dijitso/include ffc_element_5a01f62d0f2c0fe5f4320b0433b4b3fb72e2b207.cpp
-L~/.cache/dijitso/lib -Wl,-rpath,~/.cache/dijitso/lib
-olibdijitso-ffc_element_5a01f62d0f2c0fe5f4320b0433b4b3fb72e2b207.so -pthread
where I abbreviated the paths. I also got this same error while building fenics itself from source, and solved it by adding -pthread to CXXFLAGS.
I know all this is very heuristic, but I’m not familiar with this compilation procedures and c++.
So, is there any way to modify ffc or dijitso in order to change the jit compilation phase, by adding a flag to the very end of the compilation input to the compiler (or do you know any other way to solve this)??
