I am trying to install FEniCS from source on a HPC cluster. dijitso and dolfin version is 2019.1.0.
I was able to successfully compile dolfin and its subsequent python part. Running python3 -c "import fenics" does not throw an error. When I run the demo demo_poisson.py, the program throws the following error:
dijitso failed to load existing file:
/home/cteerara/.cache/dijitso/lib/libdijitso-dolfin_expression_be66c0c4db22d7873f49b8e70c22058f.so
error is:
/home/cteerara/.cache/dijitso/lib/libdijitso-dolfin_expression_be66c0c4db22d7873f49b8e70c22058f.so: undefined symbol: _ZNK6dolfin8Variable3strB5cxx11Eb
error is:
error is:
File "/oasis/projects/nsf/cob146/cteerara/FEniCS/lib/python3.6/site-packages/dolfin/jit/jit.py", line 168, in compile_class
submodule = dijitso.extract_factory_function(module, "create_" + module_name)()
File "/oasis/projects/nsf/cob146/cteerara/FEniCS/lib/python3.6/site-packages/dijitso/jit.py", line 47, in extract_factory_function
function = getattr(lib, name)
AttributeError: 'NoneType' object has no attribute 'create_dolfin_expression_be66c0c4db22d7873f49b8e70c22058f'
File "dolfin/python/demo/documented/poisson/demo_poisson.py", line 153, in <module>
f = Expression("10*exp(-(pow(x[0] - 0.5, 2) + pow(x[1] - 0.5, 2)) / 0.02)", degree=2)
File "/oasis/projects/nsf/cob146/cteerara/FEniCS/lib/python3.6/site-packages/dolfin/function/expression.py", line 400, in __init__
File "/oasis/projects/nsf/cob146/cteerara/FEniCS/lib/python3.6/site-packages/dolfin/function/jit.py", line 158, in compile_expression
File "/oasis/projects/nsf/cob146/cteerara/FEniCS/lib/python3.6/site-packages/dolfin/jit/jit.py", line 170, in compile_class
raise RuntimeError("Unable to compile C++ code with dijitso")
error is:
Running dijitso config give the followings:
Showing default flags for dijitso:
build:
cxx: c++
cxxflags: -Wall -shared -fPIC -std=c++11
cxxflags_debug: -g -O0
cxxflags_opt: -O3 -fno-math-errno -fno-trapping-math -ffinite-math-only
debug: False
include_dirs:
lib_dirs:
libs:
rpath_dirs:
cache:
cache_dir: /home/cteerara/.cache/dijitso
comm_dir: comm
enable_build_log: True
fail_dir_root: None
inc_dir: include
inc_postfix: .h
lib_basename: dijitso-
lib_dir: lib
lib_loader: ctypes
lib_postfix: .so
lib_prefix: lib
log_dir: log
log_postfix: .txt
src_dir: src
src_postfix: .cpp
src_storage: compress
temp_dir_root: None
I am wondering if anybody have any insights on why this is the case and how to resolve this?
Thank you very much,
