Hello, i’m a new user of fenics.
I’d like to get the streamfunction psi of a given 2d thermal heat flux F=k.grad(T) so that the isolines of psi are parallel to F (or orthogonal to isolines of T).
- First i solve the thermal equation to get the vector flux using a P2 interpolation
- Then, streamfunction is a well-known problem in CFD and psi satisfies a vorticity equation defined here
Unfortunatly the streamlines are not parallel to F.
Did i miss something ?
thanks for helping.
