I am following the following tutorial from @bleyerj Axisymmetric formulation for elastic structures of revolution — Numerical tours of continuum mechanics using FEniCS master documentation and I was wondering, if I wanted to find the principal stresses of the hemisphere when I am done, how can I do that?
I am trying to combine the examples of @bleyerj from indentation and axisymmetric calculations in order to get a matching condition of a sphere, like asked about in Why FEniCS values are so different than theoretical ones? - #11 by bleyerj.
from dolfinx import mesh, fem
from petsc4py.PETSc import Options as PETScOptions
N = 200
domain = mesh.create_unit_square(MPI.COMM_WORLD, N, N)
domain.geometry.x[:, 0] = domain.geometry.x[:, 0] ** 2
domain.geometry.x[:, 1] = 1 - domain.geometry.x[:, 1] ** 2
V = fem.functionspace(domain, ("CG", 1, ()))
V1 = fem.functionspace(domain, ("CG", 1, (domain.geometry.dim,)))
V2 = fem.functionspace(domain, ("CG", 1, (domain.geometry.dim + 1, domain.geometry.dim + 1)))
V0 = fem.functionspace(domain, ("DG", 0, ()))
def top(x):
return np.isclose(x[1], 1)
def bottom(x):
return np.isclose(x[1], 0)
def symmetry_x(x):
return np.isclose(x[0], 0)
bottom_edge = mesh.locate_entities_boundary(domain, 1, bottom)
top_edge = mesh.locate_entities_boundary(domain, 1, top)
sym_x = mesh.locate_entities_boundary(domain, 1, symmetry_x)
marked = np.hstack([bottom_edge, top_edge, sym_x])
mark_edges = np.hstack([np.full_like(bottom_edge, 1), np.full_like(top_edge, 2), np.full_like(sym_x, 3)])
sort_edges = np.argsort(marked)
edge_tags = mesh.meshtags( domain, 1, marked[sort_edges], mark_edges[sort_edges])
u_zero = np.array((0,) * domain.geometry.dim, dtype=ScalarType)
bc_bot = fem.dirichletbc( u_zero, fem.locate_dofs_topological(V1, 1, edge_tags.find(1)), V1)
sym_x = fem.locate_dofs_topological(V1.sub(0), 1, edge_tags.find(3))
bc_sym_x = fem.dirichletbc(ScalarType(0), sym_x, V1.sub(0))
bc = [bc_bot, bc_sym_x]
ds = ufl.Measure("ds", domain=domain, subdomain_data=edge_tags)
d = 0.02
R = 0.5
def obstacle(x):
return -d + (pow(x[0], 2)) / 2 / R
indent = fem.Function(V, name="indenter")
indent.interpolate(obstacle)
u = fem.Function(V1, name="u")
du = ufl.TrialFunction(V1)
u_ = ufl.TestFunction(V1)
p = fem.Function(V0, name="pressure")
E = fem.Constant(domain, 10.0)
nu = fem.Constant(domain, 0.3)
mu = E / 2 / (1 + nu)
lmbda = E * nu / (1 + nu) / (1 - 2 * nu)
r = ufl.SpatialCoordinate(domain)[0]
def eps(v):
return ufl.sym(ufl.as_tensor([[v[0].dx(0), 0, v[0].dx(1)], [0, v[0] / r, 0], [v[1].dx(0), 0, v[1].dx(1)]]))
def sigma(v):
return lmbda * ufl.tr(eps(v)) * ufl.Identity(3) + 2.0 * mu * eps(v)
def ppos(x):
return (x + abs(x)) / 2.0
pen = fem.Constant(domain, 1e4)
F = ufl.inner(sigma(u), eps(u_)) * r * ufl.dx + pen * ufl.dot( u_[1], ppos(u[1] - indent)) * r * ds(2)
J = ufl.derivative(F, u, du)
problem = NonlinearProblem(F, u, bc, J=J)
ksp = solver.krylov_solver
opts = PETScOptions()
opts[f"{option_prefix}ksp_type"] = "gmres"
opts[f"{option_prefix}pc_type"] = "hypre"
solver.solve(u)
stress = fem.Function(V2, name="stress")
stress.interpolate( fem.Expression(sigma(u), V2.element.interpolation_points()))
My code does not run with an error, and I do get the correct value of force, but what about the stresses? is this the correct way to calculate the cauchy stress? And also, how would I take these values and calculate the principal stresses?
Principal stresses are the eigenvalues of the stress tensor.
So, please refer to the following discussion:
Hi, thanks for the reply! I have implemented the stress calculations, but when I do so, I am getting NaN values at the symmetry axis (as seen in the tutorial Axisymmetric formulation for elastic structures of revolution — Numerical tours of continuum mechanics using FEniCS master documentation, there are 1/r terms in the strain, leading to 1/r terms in the stress calcs). How can I fix that?
how about using L’Hopital’s rule?
\lim_{r \to 0} \frac{u_r}{r} = \lim_{r \to 0} \frac{du_r}{dr}
I don’t understand how I would implement this in FEniCSx. I want a whole stress field, which I interpolate over the functionspace’s interpolation points, so how would I add in L’Hopital’s rule?
How about making use of the ufl.conditional when you define the strain tensor (eps)?
For instance,
# strain
condition = ufl.ge(x[0], 1e-10)
def eps(v):
gradu = [[v[0].dx(0), 0, v[0].dx(1)],
[0, v[0]/x[0], 0],
gradu_ = [row[:] for row in gradu] # copy gradu to gradu_
gradu_[1][1] = v[0].dx(0) # L'Hopital's rule
return ufl.conditional(condition,
ufl.sym(ufl.as_tensor(gradu)),
ufl.sym(ufl.as_tensor(gradu_)))
Thank you for this suggestion, it works great! One small difference I had to use was instead of the copy()
, I recreated the tensor, as the copy()
only copies the highest level list, so both gradu_
and gradu
were modified.
Thanks, I revised the code above.
