I’m working on a problem using the Cahn-Hilliard equation and I want to keep track of the mass of each pure phase on each time step, that is to say the domains where c = 0.0 and c=1.0. Since my transition region is really small compared to the pure phase, my idea was to define a SubDomain where c < 0.5 and another where c > 0.5 .
My working example interpolates a circle of radius 0.25 and c = 1.0 as the solution u and creates a SubDomain wherever u > 0.0 by looping through all the cells. If there is a more efficient way to do this, I’d really appreciate it.
Cheers
import math
import time
tic = time.time()
class ExpessionTest(UserExpression):
def __init__(self, **kwargs):
super().__init__(**kwargs)
def eval_cell(self, value, x, ufc_cell):
if ( (x[0] - .5)**2 + (x[1] - .5)**2 ) < 0.25**2:
value[0] = 1.0
value[0] = 0.0
def value_shape(self):
return ()
N = 500
mesh = UnitSquareMesh(N, N)
u = interpolate(ExpessionTest(degree = 1), V)
File("Value.pvd") << u
sub_domains = MeshFunction("size_t", mesh, mesh.topology().dim())
sub_domains.set_all(0)
for c in cells(mesh):
md = c.midpoint()
val = u( md.x(), md.y() )
if val > 0.0:
sub_domains[c] = 1
File("Subdomains.pvd") << sub_domains
dv = Measure('dx', domain = mesh, subdomain_data = sub_domains)
Vol_n = assemble(u*dv(1))
Vol_a = math.pi * .25**2
error = abs(Vol_a - Vol_n) / Vol_a
toc = time.time()
print("Numerical volume: %.5e Analytical volume: %.5e Error: %.5e" % (Vol_n, Vol_a, error))
print("Simulation time in minutes: %.2f" % ((toc-tic)/60.0) )
Thanks! That is a lot faster than my method. For the sake of generality, if I where to use a higher order element, would another faster method exists?
EDIT: Assuming that the subdomain is a growing circle with center in the upper edge of a rectangle domain and that I wanted to output the radius of said circle, is there a way to do that without a CellIterator?
