Hello everyone,
I am trying to create a unit circular domain with subdomains of radius 0.6 and radius 0.8.
I have tried to create a circular mesh and I want to solve
\int_\Omega\kappa \nabla u \nabla v + \int_{\partial \Omega} \epsilon uv = \int_{\Omega_{0}} f v
\kappa = \left\{ \begin{array}{} 1, x \in \Omega_{0} \cup \Omega_{2} \\ 1/50, x \in \Omega_{1} \end{array} \right\}
My code is as follows:
import pyvista
from dolfinx.fem import (Constant, dirichletbc, Function, FunctionSpace, assemble_scalar,
form, locate_dofs_geometrical, locate_dofs_topological)
from dolfinx.mesh import create_unit_square, locate_entities, meshtags, compute_midpoints
from ufl import (SpatialCoordinate, TestFunction, TrialFunction,
dx, grad, inner)
from dolfinx import mesh
c2 = gmsh.model.occ.addDisk(0, 0, 0, 1,1)
gmsh.model.occ.synchronize()
gdim = 2
status2 = gmsh.model.addPhysicalGroup(gdim, [c2], 1)
gmsh.option.setNumber("Mesh.CharacteristicLengthMin",0.001)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax",0.1)
from dolfinx import io
if MPI.COMM_WORLD.rank == 0:
# Get mesh geometry
geometry_data = io.extract_gmsh_geometry(gmsh.model)
# Get mesh topology for each element
topology_data = io.extract_gmsh_topology_and_markers(gmsh.model)
# Extract the cell type and number of nodes per cell and broadcast
# it to the other processors
gmsh_cell_type = list(topology_data.keys())[0]
properties = gmsh.model.mesh.getElementProperties(gmsh_cell_type)
name, dim, order, num_nodes, local_coords, _ = properties
cells = topology_data[gmsh_cell_type]["topology"]
cell_id, num_nodes = MPI.COMM_WORLD.bcast([gmsh_cell_type, num_nodes], root=0)
cell_id, num_nodes = MPI.COMM_WORLD.bcast([None, None], root=0)
cells, geometry_data = np.empty([0, num_nodes]), np.empty([0, gdim])
from dolfinx import mesh, cpp
# Permute topology data from MSH-ordering to dolfinx-ordering
ufl_domain = io.ufl_mesh_from_gmsh(cell_id, gdim)
gmsh_cell_perm = io.cell_perm_gmsh(cpp.mesh.to_type(str(ufl_domain.ufl_cell())), num_nodes)
cells = cells[:, gmsh_cell_perm]
# Create distributed mesh
domain = mesh.create_mesh(MPI.COMM_WORLD, cells, geometry_data[:, :gdim], ufl_domain)
from dolfinx import fem
Q = fem.FunctionSpace(domain, ("DG", 0))
def Omega_0(x):
return (x[0]*x[0] + x[1]*x[1] <= 0.6*0.6)
def Omega_1(x):
return [x and y for (x,y) in zip(x[0]*x[0] + x[1]*x[1] >= 0.6*0.6, x[0]*x[0] + x[1]*x[1] <= 0.8*0.8)]
def Omega_2(x):
return (x[0]*x[0] + x[1]*x[1] >= 0.8*0.8)
kappa = Function(Q)
cells_0 = locate_entities(domain, domain.topology.dim, Omega_0)
cells_1 = locate_entities(domain, domain.topology.dim, Omega_1)
cells_2 = locate_entities(domain, domain.topology.dim, Omega_2)
kappa.x.array[:] = 1
kappa.x.array[cells_0] = np.full_like(cells_0, 1, dtype=ScalarType)
kappa.x.array[cells_1] = np.full_like(cells_1, 1/50, dtype=ScalarType)
kappa.x.array[cells_2] = np.full_like(cells_2, 1, dtype=ScalarType)
# cell tag
tdim = domain.topology.dim
fdim = tdim - 1
num_cells = domain.topology.index_map(tdim).size_local + \
domain.topology.index_map(tdim).num_ghosts
marker1 = lambda x: x[0]*x[0] + x[1]*x[1] <= 0.6*0.6
indices1 = mesh.locate_entities(domain, 2, marker1)
cell_marker = np.zeros(num_cells, dtype=np.int32)
cell_marker[indices1] = 1
cell_tag = dolfinx.mesh.meshtags(domain, dim=2, indices=np.arange(num_cells),values=cell_marker)
dx_sub = ufl.Measure('dx', subdomain_data=cell_tag, domain=domain)
Vs = dolfinx.fem.FunctionSpace(domain,("CG",1))
uDs = dolfinx.fem.Function(Vs)
uDs.interpolate(lambda x:x[0]**2 + x[1]**2)
us,vs = ufl.TrialFunction(Vs), ufl.TestFunction(Vs)
domain.topology.create_connectivity(tdim-1, tdim)
boundary_facets = np.flatnonzero(dolfinx.mesh.compute_boundary_facets(domain.topology)) # substitutive: facet_marker + np.where
boundary_dofs = dolfinx.fem.locate_dofs_topological(V, tdim-1, boundary_facets)
bcsd = dolfinx.fem.dirichletbc(uDs, boundary_dofs)
bcs = [bcsd]
import numpy
fdim = tdim - 1
boundary_facets = numpy.flatnonzero(mesh.compute_boundary_facets(domain.topology))
def on_boundary(x):
return np.isclose(np.sqrt(x[0]**2 + x[1]**2), 1)
boundary_dofs = fem.locate_dofs_geometrical(V, on_boundary)
bc = fem.dirichletbc(ScalarType(0), boundary_dofs, V)
u = ufl.TrialFunction(V)
#f = fem.Constant(domain, ScalarType(-6))
f = fem.Function(Vs)
f.interpolate(lambda x: x[0]**2-x[1]**2)
eps = 1e-3
ae = ufl.inner(kappa*ufl.grad(u), ufl.grad(v)) * ufl.dx + ufl.inner(eps*u, v) * ufl.ds
Le = ufl.inner(f, vs)* dx_sub
problem = fem.petsc.LinearProblem(ae, Le, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
ue = problem.solve()
!pip3 install pyvista pythreejs ipygany --upgrade
!jupyter nbextension enable --py --sys-prefix ipygany
from dolfinx import plot
import pyvista
topology, cell_types, geometry = plot.create_vtk_mesh(domain, tdim)
grid = pyvista.UnstructuredGrid(topology, cell_types, geometry)
pyvista.set_jupyter_backend("pythreejs")
p = pyvista.Plotter(window_size=[800, 800], shape=(1,2))
# Filter out ghosted cells
num_cells_local = domain.topology.index_map(domain.topology.dim).size_local
marker = np.zeros(num_cells_local, dtype=np.int32)
cells_0 = cells_0[cells_0<=num_cells_local]
cells_1 = cells_1[cells_1<=num_cells_local]
cells_2 = cells_2[cells_2<=num_cells_local]
marker[cells_0] = 1
marker[cells_1] = 2
marker[cells_2] = 3
topology, cell_types, x = create_vtk_mesh(domain, domain.topology.dim, np.arange(num_cells_local, dtype=np.int32))
grid = pyvista.UnstructuredGrid(topology, cell_types, x)
grid.cell_data["Marker"] = marker
grid.set_active_scalars("Marker")
p.subplot(0,0)
actor0 = p.add_mesh(grid, show_edges=True)
p.subplot(0,1)
grid_uh = pyvista.UnstructuredGrid(*create_vtk_mesh(V))
grid_uh.point_data["u"] = ue.x.array.real
grid_uh.set_active_scalars("u")
actor1 = p.add_mesh(grid_uh, show_edges=True)
if not pyvista.OFF_SCREEN:
p.show()
pyvista.start_xvfb()
figure = p.screenshot("subdomains_structured.png")
But I got the output as follows where I am getting a gap between the subdomains :
Kindly let me know why am I getting the gap and the mistake with this code.
I am new to dolfinx and I am learning it slowly, It would be great if anyone could help me with this. Thank you in advance!
