Dear FenicsX Community,
I am currently working on a simulation of a Vertical-Cavity Surface-Emitting Laser (VCSEL) using FenicsX, and I have encountered an issue that I hope the community can help me with. I’ve attached my Python code below. The code is designed to generate a 3D mesh for the VCSEL structure, tag different regions within the mesh, and assign material properties to each tagged region.
from dolfinx import fem, io, mesh
from dolfinx.mesh import locate_entities, meshtags, locate_entities_boundary
# Define the geometric parameters of the VCSEL
d = 4e-6 # Aperture diameter, 4 micrometers
# Introduce a new parameter D representing the lateral dimension of the entire VCSEL structure, assuming d is 2/3 of D
D = d * 3 / 2
lambda_0 = 850e-9 # Central wavelength, 850 nm
bottom_dbr_pairs = 29.5 # Number of bottom DBR pairs
top_dbr_pairs = 24 # Number of top DBR pairs
qw_thickness = 5e-9 # Quantum well thickness
oxide_gaas_thickness = 69.49e-9 # Thickness of the GaAs layer in the oxide window
oxide_algaas_top_thickness = 63.71e-9 # Thickness of the upper AlGaAs layer in the oxide window
oxide_complex_thickness = 15.93e-9 # Thickness of the composite layer in the oxide window
active_gaas_thickness = 136.49e-9 # Thickness of the GaAs layer in the active region
ni = 0.01 # Assumed ni value, can be modified according to the actual situation
# Refractive indices of materials
n_GaAs = 3.53
n_AlGaAs = 3.08
n_AlAs = 2.95
n_AlOx = 1.60
# Given thickness of each DBR layer in the original text
dbr_GaAs_thickness = 69.49e-9
dbr_AlGaAs_thickness = 79.63e-9
# Assume x is the 5 varying positions of the oxide aperture
x_positions = np.linspace(0, 63.71e-9, 5)
# Process each position in a loop
for i, x in enumerate(x_positions):
# Calculate the lengths of each part
top_dbr_length = top_dbr_pairs * (dbr_GaAs_thickness + dbr_AlGaAs_thickness)
oxide_window_length = oxide_gaas_thickness + (oxide_algaas_top_thickness - x) + oxide_complex_thickness + x
active_layer_length = 2 * active_gaas_thickness + qw_thickness
bottom_dbr_length = bottom_dbr_pairs * (dbr_GaAs_thickness + dbr_AlGaAs_thickness)
total_length = top_dbr_length + oxide_window_length + active_layer_length + bottom_dbr_length
# Generate a 3D mesh, increase the number of meshes in the longitudinal direction for better resolution of each layer
nx = 20
ny = 20
nz = 1000
domain = mesh.create_box(MPI.COMM_WORLD, [np.array([-D / 2, -D / 2, 0]), np.array([D / 2, D / 2, total_length])],
(nx, ny, nz), cell_type=mesh.CellType.hexahedron)
# Define the tagging functions for different regions
def region_func(z_start, z_end, r_cond=lambda r: True):
return lambda x_coords: np.logical_and(
np.logical_and(x_coords[2] >= z_start, x_coords[2] < z_end),
r_cond(np.sqrt(x_coords[0] ** 2 + x_coords[1] ** 2))
regions = {
'top_dbr': region_func(0, top_dbr_length),
'oxide_gaas': region_func(top_dbr_length, top_dbr_length + oxide_gaas_thickness),
'oxide_algaas_top': region_func(
top_dbr_length + oxide_gaas_thickness,
top_dbr_length + oxide_gaas_thickness + (oxide_algaas_top_thickness - x)
'oxide_complex_center': region_func(
top_dbr_length + oxide_gaas_thickness + (oxide_algaas_top_thickness - x),
top_dbr_length + oxide_gaas_thickness + (oxide_algaas_top_thickness - x) + oxide_complex_thickness,
lambda r: r < d / 2
'oxide_complex_outer': region_func(
lambda r: r >= d / 2
'oxide_algaas_bottom': region_func(
top_dbr_length + oxide_gaas_thickness + (oxide_algaas_top_thickness - x) + oxide_complex_thickness + x
'active_gaas_top': region_func(
top_dbr_length + oxide_window_length,
top_dbr_length + oxide_window_length + active_gaas_thickness
'quantum_well_center': region_func(
top_dbr_length + oxide_window_length + active_gaas_thickness,
top_dbr_length + oxide_window_length + active_gaas_thickness + qw_thickness,
lambda r: r < d / 2
'quantum_well_outer': region_func(
'active_gaas_bottom': region_func(
top_dbr_length + oxide_window_length + 2 * active_gaas_thickness + qw_thickness
'bottom_dbr': region_func(
top_dbr_length + oxide_window_length + active_layer_length,
'substrate': region_func(
top_dbr_length + oxide_window_length + active_layer_length + bottom_dbr_length,
total_length
# Initialize the tagging array (the same size as the number of mesh cells)
tdim = domain.topology.dim
index_map = domain.topology.index_map(tdim)
num_local_cells = index_map.size_local
cell_indices = np.arange(num_local_cells, dtype=np.int32)
global_cell_indices = index_map.local_to_global(cell_indices)
values = np.zeros(num_local_cells, dtype=np.int32)
# Define the tagging values
TAGS = {
'top_dbr_GaAs': 1, 'top_dbr_AlGaAs': 2,
'oxide_gaas': 3, 'oxide_algaas_top': 4, 'oxide_complex_center': 5, 'oxide_complex_outer': 6, 'oxide_algaas_bottom': 7,
'active_gaas_top': 8, 'quantum_well_center': 9, 'quantum_well_outer': 10, 'active_gaas_bottom': 11,
'bottom_dbr_GaAs': 12, 'bottom_dbr_AlGaAs': 13,
'substrate': 14
# Tag the top DBR layer
z = top_dbr_length
for j in range(int(top_dbr_pairs)):
z -= dbr_AlGaAs_thickness + dbr_GaAs_thickness
gaas_region = region_func(z, z + dbr_GaAs_thickness)
gaas_cells = locate_entities(domain, tdim, gaas_region)
local_gaas_cells = np.where(np.isin(global_cell_indices, gaas_cells))[0]
values[local_gaas_cells] = TAGS['top_dbr_GaAs']
z += dbr_GaAs_thickness
algaas_region = region_func(z, z + dbr_AlGaAs_thickness)
algaas_cells = locate_entities(domain, tdim, algaas_region)
local_algaas_cells = np.where(np.isin(global_cell_indices, algaas_cells))[0]
values[local_algaas_cells] = TAGS['top_dbr_AlGaAs']
z += dbr_AlGaAs_thickness
# Tag the oxide window layer
for region_name, func in [
('oxide_gaas', regions['oxide_gaas']),
('oxide_algaas_top', regions['oxide_algaas_top']),
('oxide_algaas_bottom', regions['oxide_algaas_bottom'])
cells = locate_entities(domain, tdim, func)
local_cells = np.where(np.isin(global_cell_indices, cells))[0]
values[local_cells] = TAGS[region_name]
# Tag the oxide composite layer, distinguish between inner and outer parts
cells = locate_entities(domain, tdim, regions['oxide_complex_center'])
values[local_cells] = TAGS['oxide_complex_center']
cells = locate_entities(domain, tdim, regions['oxide_complex_outer'])
values[local_cells] = TAGS['oxide_complex_outer']
# Tag the active region
('active_gaas_top', regions['active_gaas_top']),
('active_gaas_bottom', regions['active_gaas_bottom'])
# Tag the quantum well layer, distinguish between inner and outer parts
cells = locate_entities(domain, tdim, regions['quantum_well_center'])
values[local_cells] = TAGS['quantum_well_center']
cells = locate_entities(domain, tdim, regions['quantum_well_outer'])
values[local_cells] = TAGS['quantum_well_outer']
# Tag the bottom DBR layer
z = top_dbr_length + oxide_window_length + active_layer_length
for j in range(int(bottom_dbr_pairs)):
z += dbr_AlGaAs_thickness + dbr_GaAs_thickness
algaas_region = region_func(z - dbr_AlGaAs_thickness, z)
values[local_algaas_cells] = TAGS['bottom_dbr_AlGaAs']
gaas_region = region_func(z - dbr_GaAs_thickness, z)
values[local_gaas_cells] = TAGS['bottom_dbr_GaAs']
z -= dbr_GaAs_thickness
# Tag the substrate
substrate_cells = locate_entities(domain, tdim, regions['substrate'])
local_substrate_cells = np.where(np.isin(global_cell_indices, substrate_cells))[0]
values[local_substrate_cells] = TAGS['substrate']
# Correctly initialize MeshTags
marker = meshtags(domain, tdim, global_cell_indices, values)
# # Save the tagging information (optional)
# with open(f'vcsel_mesh_tags_x_{i}.txt', 'w') as f:
# f.write("Cell index, Tag\n")
# for cell_idx, tag in zip(global_cell_indices, values):
# f.write(f"{cell_idx}, {tag}\n")
# Define the material properties
materials = {
1: n_GaAs,
2: n_AlGaAs,
3: n_GaAs,
4: n_AlGaAs,
5: n_AlOx,
6: n_AlAs,
7: n_AlGaAs,
8: n_GaAs,
9: n_GaAs + 1j * ni,
10: n_GaAs,
11: n_GaAs,
12: n_GaAs,
13: n_AlGaAs,
14: n_GaAs
material_values = np.array([materials[tag] for tag in values], dtype=np.complex128)
material = fem.Function(domain, ufl.FunctionSpace(domain, ("DG", 0)))
material.x.array[:] = material_values
When I run this code, I receive the following error:
File "/home/xxx_77/program/xxx.py", line 223, in <module>
KeyError: 0
I’m noob at python,please help me! I would greatly appreciate any help, advice, or insights from the community.
Thank you in advance!
