Applying spatially varying material
i am now solving a problem of a plate with three different kinds of materials, it’s a unit square mesh with a inner circle warped by a ring area as shown in the picture.
i want to apply the inner circle with material 1 and outside the outer circle area with second material. and inside the ring area is a functionally graded material towards outside the ring, and so the material properties is dependent on the distance from the center of the inner circle.
When i tried to realize it through fenics using the UserExpression class as shown below. i met some problem during the solving.
class InnerCircle1(SubDomain):
        return sqrt(pow((x[0]-0.8),2)+pow((x[1]-0.5),2)) <= 0.05 + tol
class OuterCircle1(SubDomain):
        return (sqrt(pow((x[0]-0.8),2)+pow((x[1]-0.5),2)) >= 0.05 - tol and\
               sqrt(pow((x[0]-0.8),2)+pow((x[1]-0.5),2)) <= 0.1 + tol)
materials = MeshFunction('size_t', mesh, 2)
subdomain_1 = InnerCircle1()
subdomain_2 = OuterCircle1()
materials.set_all(0)
subdomain_1.mark(materials, 1)
subdomain_2.mark(materials, 2)
plot(materials)
File('materials.xml.gz') << materials
class K(UserExpression):
    def __init__(self, materials, mesh, k_0, k_1, **kwargs):
        super().__init__(**kwargs)
        self.materials = materials
        self.mesh = mesh
        self.x = SpatialCoordinate(self.mesh)
        self.k_0 = k_0
        self.k_1 = k_1
        if self.materials[cell.index] == 0:
            values[0] = self.k_0
        elif self.materials[cell.index] == 1:
            values[0] = self.k_1
            values[0] = (self.k_1 + (self.k_0-self.k_1)*\
                         ((sqrt(pow((self.x[0] - 0.8),2)+pow((self.x[1] - 0.5),2)) - 0.05) / 0.05))
E = K(materials, mesh, E1, E2, degree=0)
i encounterd the error shown as below:
ValueError: setting an array element with a sequence.
this error i believed is caused by the third kinds of material property assignments which is coordinate dependent. How can i solve this problem?
Thanks
I’ve attached a working code. I’ve removed your definition of SpatialCoordinate, as you send in the appropriate coordinates to eval_cell. In eval_cell only one coordinate is sent in at once, while spatial coordiante is an array.
mesh = UnitSquareMesh(100,100)
tol = 1e-6
E1, E2 = 0.5,0.3
plot(materials)
        self.mesh = mesh
        self.k_0 = k_0
        self.k_1 = k_1
                         ((sqrt(pow((x[0] - 0.8),2)+pow((x[1] - 0.5),2)) - 0.05) / 0.05))
    def value_shape(self):
        return ()
assemble(E*dx(domain=mesh))
Thanks! The problem is solved now!
