Hi all,
I am currently struggling with the problem where I want to create a custom 2D mesh with nodes that are connected essentially in only one direction. The exception is a boundary at x=1 where the nodes are connected along that line.
I’ve created that mesh and I want to create a custom measure that acts at that boundary, only. The source code of my current attempt is the following:
import basix
import dolfinx as dfx
from mpi4py.MPI import COMM_WORLD as comm
n_rad = 16
n_part = 12
# Nodes
radial_grid = np.linspace(0, 1, n_rad)
particle_grid = np.linspace(0, 1, n_part)
rr, pp = np.meshgrid(radial_grid, particle_grid)
coords_grid = np.stack((rr, pp)).transpose((-1, 1, 0)).copy()
if comm.rank == 0:
coords_grid_flat = coords_grid.reshape(-1, 2).copy()
coords_grid_flat = np.empty((0, 2), dtype=np.float64)
# Elements
# All the radial connections
elements_radial = [
[[n_part * i + k, n_part * (i + 1) + k] for i in range(n_rad - 1)]
for k in range(n_part)
elements_radial = np.array(elements_radial).reshape(-1, 2)
# Connections between particles
elements_bc = (n_rad - 1) * n_part + np.array([[k, k + 1] for k in range(n_part - 1)])
# elements_bc = [] # With elements at the outer edge the integration fails.
if comm.rank == 0:
elements = np.array(list(elements_bc) + list(elements_radial))
elements = np.empty((0, 2), dtype=np.int64)
# %% The DOLFINx grid
gdim = 2
shape = "interval"
degree = 1
domain = ufl.Mesh(
basix.ufl.element("Lagrange",
shape,
degree,
shape=(coords_grid_flat.shape[1],)))
mesh = dfx.mesh.create_mesh(comm, elements[:, :2], coords_grid_flat, domain)
# %% Create integral measure on the particle surface
fdim = mesh.topology.dim - 1
facets = dfx.mesh.locate_entities(mesh, fdim, lambda x: np.isclose(x[0], 1.))
facet_markers = np.full_like(facets, 1)
facet_tag = dfx.mesh.meshtags(mesh, fdim, facets, facet_markers)
dA = ufl.Measure("ds", domain=mesh, subdomain_data=facet_tag)
dA_R = dA(1)
# %% Test the surface measure
V = dfx.fem.functionspace(mesh, ("CG", 1))
u = dfx.fem.Function(V)
u.interpolate(lambda x: x[0] + 0.1 * x[1])
boundary_integral_ufl = u * dA_R
boundary_integral_cpp = dfx.fem.form(boundary_integral_ufl)
boundary_integral_value = dfx.fem.assemble_scalar(boundary_integral_cpp)
print(boundary_integral_value)
When I run the code, I get 0.0 as a value for the boundary integral. I would expect 1.05. Certainly I am missing something. Maybe you can help me.
I am running with the follwing setup:
# packages in environment at /Users/doerffel/anaconda3/envs/fenicsx-env:
# Name Version Build Channel
aiohappyeyeballs 2.4.0 pyhd8ed1ab_0 conda-forge
aiohttp 3.10.5 py310ha6dd24b_0 conda-forge
aiosignal 1.3.1 pyhd8ed1ab_0 conda-forge
anyio 4.4.0 pyhd8ed1ab_0 conda-forge
aom 3.9.1 h7bae524_0 conda-forge
appnope 0.1.4 pyhd8ed1ab_0 conda-forge
argon2-cffi 23.1.0 pyhd8ed1ab_0 conda-forge
argon2-cffi-bindings 21.2.0 py310h493c2e1_5 conda-forge
arrow 1.3.0 pyhd8ed1ab_0 conda-forge
asttokens 2.4.1 pyhd8ed1ab_0 conda-forge
async-lru 2.0.4 pyhd8ed1ab_0 conda-forge
async-timeout 4.0.3 pyhd8ed1ab_0 conda-forge
attrs 24.2.0 pyh71513ae_0 conda-forge
babel 2.14.0 pyhd8ed1ab_0 conda-forge
beautifulsoup4 4.12.3 pyha770c72_0 conda-forge
bleach 6.1.0 pyhd8ed1ab_0 conda-forge
blosc 1.21.6 h5499902_0 conda-forge
brotli 1.1.0 hd74edd7_2 conda-forge
brotli-bin 1.1.0 hd74edd7_2 conda-forge
brotli-python 1.1.0 py310hb4ad77e_2 conda-forge
bzip2 1.0.8 h99b78c6_7 conda-forge
c-ares 1.33.1 hd74edd7_0 conda-forge
c-blosc2 2.15.1 h5063078_0 conda-forge
ca-certificates 2024.8.30 hf0a4a13_0 conda-forge
cached-property 1.5.2 hd8ed1ab_1 conda-forge
cached_property 1.5.2 pyha770c72_1 conda-forge
cairo 1.18.0 hb4a6bf7_3 conda-forge
cctools_osx-arm64 986 h4f2c9d0_4 conda-forge
certifi 2024.8.30 pyhd8ed1ab_0 conda-forge
cffi 1.17.1 py310h497396d_0 conda-forge
charset-normalizer 3.3.2 pyhd8ed1ab_0 conda-forge
clang 16.0.6 default_h675cc0c_13 conda-forge
clang-16 16.0.6 default_h5c12605_13 conda-forge
clang_impl_osx-arm64 16.0.6 hc421ffc_19 conda-forge
clang_osx-arm64 16.0.6 h54d7cd3_19 conda-forge
clangxx 16.0.6 default_h675cc0c_13 conda-forge
clangxx_impl_osx-arm64 16.0.6 hcd7bac0_19 conda-forge
clangxx_osx-arm64 16.0.6 h54d7cd3_19 conda-forge
colorcet 3.1.0 pyhd8ed1ab_0 conda-forge
comm 0.2.2 pyhd8ed1ab_0 conda-forge
compiler-rt 16.0.6 h3808999_2 conda-forge
compiler-rt_osx-arm64 16.0.6 h3808999_2 conda-forge
contourpy 1.3.0 py310h7306fd8_1 conda-forge
cycler 0.12.1 pyhd8ed1ab_0 conda-forge
dav1d 1.2.1 hb547adb_0 conda-forge
debugpy 1.8.5 py310hb4ad77e_1 conda-forge
decorator 5.1.1 pyhd8ed1ab_0 conda-forge
defusedxml 0.7.1 pyhd8ed1ab_0 conda-forge
double-conversion 3.3.0 h13dd4ca_0 conda-forge
eigen 3.4.0 h1995070_0 conda-forge
entrypoints 0.4 pyhd8ed1ab_0 conda-forge
exceptiongroup 1.2.2 pyhd8ed1ab_0 conda-forge
executing 2.1.0 pyhd8ed1ab_0 conda-forge
expat 2.6.3 hf9b8971_0 conda-forge
fenics-basix 0.8.0 py310h7306fd8_2 conda-forge
fenics-dolfinx 0.8.0 py310hb3fb8a6_105 conda-forge
fenics-ffcx 0.8.0 pyh4af843d_0 conda-forge
fenics-libbasix 0.8.0 h12e1e3e_2 conda-forge
fenics-libdolfinx 0.8.0 h1e37117_105 conda-forge
fenics-ufcx 0.8.0 h22f594c_0 conda-forge
fenics-ufl 2024.1.0 pyhd8ed1ab_0 conda-forge
ffmpeg 6.1.2 gpl_h3ef3969_102 conda-forge
fftw 3.3.10 mpi_openmpi_h260600c_10 conda-forge
fltk 1.3.9 h5164b75_1 conda-forge
font-ttf-dejavu-sans-mono 2.37 hab24e00_0 conda-forge
font-ttf-inconsolata 3.000 h77eed37_0 conda-forge
font-ttf-source-code-pro 2.038 h77eed37_0 conda-forge
font-ttf-ubuntu 0.83 h77eed37_2 conda-forge
fontconfig 2.14.2 h82840c6_0 conda-forge
fonts-conda-ecosystem 1 0 conda-forge
fonts-conda-forge 1 0 conda-forge
fonttools 4.53.1 py310h493c2e1_1 conda-forge
fqdn 1.5.1 pyhd8ed1ab_0 conda-forge
freeimage 3.18.0 hd0e3f39_20 conda-forge
freetype 2.12.1 hadb7bae_2 conda-forge
fribidi 1.0.10 h27ca646_0 conda-forge
frozenlist 1.4.1 py310h493c2e1_1 conda-forge
gettext 0.22.5 h8414b35_3 conda-forge
gettext-tools 0.22.5 h8414b35_3 conda-forge
gl2ps 1.4.2 hc97c1ff_1 conda-forge
glew 2.1.0 h9f76cd9_2 conda-forge
gmp 6.3.0 h7bae524_2 conda-forge
gmsh 4.12.2 hd427cfb_0 conda-forge
gnutls 3.8.7 h9df781c_0 conda-forge
graphite2 1.3.13 hebf3989_1003 conda-forge
h11 0.14.0 pyhd8ed1ab_0 conda-forge
h2 4.1.0 pyhd8ed1ab_0 conda-forge
h5py 3.11.0 mpi_openmpi_py310h8961b4a_2 conda-forge
harfbuzz 9.0.0 h997cde5_1 conda-forge
hdf4 4.2.15 h2ee6834_7 conda-forge
hdf5 1.14.3 mpi_openmpi_h7d685e0_5 conda-forge
hpack 4.0.0 pyh9f0ad1d_0 conda-forge
httpcore 1.0.5 pyhd8ed1ab_0 conda-forge
httpx 0.27.2 pyhd8ed1ab_0 conda-forge
hyperframe 6.0.1 pyhd8ed1ab_0 conda-forge
hypre 2.31.0 mpi_openmpi_hedb40dd_1 conda-forge
icu 75.1 hfee45f7_0 conda-forge
idna 3.8 pyhd8ed1ab_0 conda-forge
imath 3.1.11 h1059232_0 conda-forge
importlib-metadata 8.4.0 pyha770c72_0 conda-forge
importlib_metadata 8.4.0 hd8ed1ab_0 conda-forge
importlib_resources 6.4.4 pyhd8ed1ab_0 conda-forge
ipykernel 6.29.5 pyh57ce528_0 conda-forge
ipympl 0.9.4 pyhd8ed1ab_0 conda-forge
ipython 8.27.0 pyh707e725_0 conda-forge
ipython_genutils 0.2.0 pyhd8ed1ab_1 conda-forge
ipywidgets 8.1.5 pyhd8ed1ab_0 conda-forge
isoduration 20.11.0 pyhd8ed1ab_0 conda-forge
jedi 0.19.1 pyhd8ed1ab_0 conda-forge
jinja2 3.1.4 pyhd8ed1ab_0 conda-forge
json5 0.9.25 pyhd8ed1ab_0 conda-forge
jsoncpp 1.9.5 hc021e02_1 conda-forge
jsonpointer 3.0.0 py310hbe9552e_1 conda-forge
jsonschema 4.23.0 pyhd8ed1ab_0 conda-forge
jsonschema-specifications 2023.12.1 pyhd8ed1ab_0 conda-forge
jsonschema-with-format-nongpl 4.23.0 hd8ed1ab_0 conda-forge
jupyter 1.1.1 pyhd8ed1ab_0 conda-forge
jupyter-contrib-core 0.4.2 pypi_0 pypi
jupyter-contrib-nbextensions 0.7.0 pypi_0 pypi
jupyter-highlight-selected-word 0.2.0 pypi_0 pypi
jupyter-lsp 2.2.5 pyhd8ed1ab_0 conda-forge
jupyter-nbextensions-configurator 0.6.4 pypi_0 pypi
jupyter_client 8.6.2 pyhd8ed1ab_0 conda-forge
jupyter_console 6.6.3 pyhd8ed1ab_0 conda-forge
jupyter_core 5.7.2 py310hbe9552e_0 conda-forge
jupyter_events 0.10.0 pyhd8ed1ab_0 conda-forge
jupyter_server 2.14.2 pyhd8ed1ab_0 conda-forge
jupyter_server_terminals 0.5.3 pyhd8ed1ab_0 conda-forge
jupyterlab 4.2.5 pyhd8ed1ab_0 conda-forge
jupyterlab_pygments 0.3.0 pyhd8ed1ab_1 conda-forge
jupyterlab_server 2.27.3 pyhd8ed1ab_0 conda-forge
jupyterlab_widgets 3.0.13 pyhd8ed1ab_0 conda-forge
jxrlib 1.1 h93a5062_3 conda-forge
kahip 3.16 py310he7e4bf1_4 conda-forge
kahip-python 3.16 py310h34c99ce_4 conda-forge
kiwisolver 1.4.7 py310h7306fd8_0 conda-forge
krb5 1.21.3 h237132a_0 conda-forge
lame 3.100 h1a8c8d9_1003 conda-forge
lcms2 2.16 ha0e7c42_0 conda-forge
ld64_osx-arm64 711 h0605c9f_4 conda-forge
lerc 4.0.0 h9a09cb3_0 conda-forge
libabseil 20240116.2 cxx17_h00cdb27_1 conda-forge
libadios2 2.10.1 mpi_openmpi_hd482e01_3 conda-forge
libaec 1.1.3 hebf3989_0 conda-forge
libasprintf 0.22.5 h8414b35_3 conda-forge
libasprintf-devel 0.22.5 h8414b35_3 conda-forge
libass 0.17.3 hf20b609_0 conda-forge
libblas 3.9.0 23_osxarm64_openblas conda-forge
libboost 1.86.0 h29978a0_2 conda-forge
libboost-devel 1.86.0 hf450f58_2 conda-forge
libboost-headers 1.86.0 hce30654_2 conda-forge
libbrotlicommon 1.1.0 hd74edd7_2 conda-forge
libbrotlidec 1.1.0 hd74edd7_2 conda-forge
libbrotlienc 1.1.0 hd74edd7_2 conda-forge
libcblas 3.9.0 23_osxarm64_openblas conda-forge
libclang-cpp16 16.0.6 default_h5c12605_13 conda-forge
libclang13 18.1.8 default_hfc66aa2_4 conda-forge
libcurl 8.9.1 hfd8ffcc_0 conda-forge
libcxx 18.1.8 h3ed4263_7 conda-forge
libcxx-devel 16.0.6 h86353a2_2 conda-forge
libdeflate 1.21 h99b78c6_0 conda-forge
libedit 3.1.20191231 hc8eb9b7_2 conda-forge
libev 4.33 h93a5062_2 conda-forge
libevent 2.1.12 h2757513_1 conda-forge
libexpat 2.6.3 hf9b8971_0 conda-forge
libffi 3.4.2 h3422bc3_5 conda-forge
libgettextpo 0.22.5 h8414b35_3 conda-forge
libgettextpo-devel 0.22.5 h8414b35_3 conda-forge
libgfortran 5.0.0 13_2_0_hd922786_3 conda-forge
libgfortran5 13.2.0 hf226fd6_3 conda-forge
libglib 2.80.3 h59d46d9_2 conda-forge
libhwloc 2.11.1 default_h7685b71_1000 conda-forge
libiconv 1.17 h0d3ecfb_2 conda-forge
libidn2 2.3.7 h93a5062_0 conda-forge
libintl 0.22.5 h8414b35_3 conda-forge
libintl-devel 0.22.5 h8414b35_3 conda-forge
libjpeg-turbo 3.0.0 hb547adb_1 conda-forge
liblapack 3.9.0 23_osxarm64_openblas conda-forge
libllvm16 16.0.6 haab561b_3 conda-forge
libllvm18 18.1.8 h5090b49_2 conda-forge
libnetcdf 4.9.2 nompi_he469be0_114 conda-forge
libnghttp2 1.58.0 ha4dd798_1 conda-forge
libogg 1.3.5 h99b78c6_0 conda-forge
libopenblas 0.3.27 openmp_h517c56d_1 conda-forge
libopenvino 2024.3.0 h5c9529b_0 conda-forge
libopenvino-arm-cpu-plugin 2024.3.0 h5c9529b_0 conda-forge
libopenvino-auto-batch-plugin 2024.3.0 hcd65546_0 conda-forge
libopenvino-auto-plugin 2024.3.0 hcd65546_0 conda-forge
libopenvino-hetero-plugin 2024.3.0 h88cb26a_0 conda-forge
libopenvino-ir-frontend 2024.3.0 h88cb26a_0 conda-forge
libopenvino-onnx-frontend 2024.3.0 h32b5460_0 conda-forge
libopenvino-paddle-frontend 2024.3.0 h32b5460_0 conda-forge
libopenvino-pytorch-frontend 2024.3.0 h00cdb27_0 conda-forge
libopenvino-tensorflow-frontend 2024.3.0 h2741c3b_0 conda-forge
libopenvino-tensorflow-lite-frontend 2024.3.0 h00cdb27_0 conda-forge
libopus 1.3.1 h27ca646_1 conda-forge
libpng 1.6.43 h091b4b1_0 conda-forge
libpq 16.4 h671472c_1 conda-forge
libprotobuf 4.25.3 hbfab5d5_0 conda-forge
libptscotch 7.0.4 h5f5ebf5_5 conda-forge
libraw 0.21.1 h2ee6834_2 conda-forge
libscotch 7.0.4 h7c38b86_5 conda-forge
libsodium 1.0.20 h99b78c6_0 conda-forge
libsqlite 3.46.1 hc14010f_0 conda-forge
libssh2 1.11.0 h7a5bd25_0 conda-forge
libtasn1 4.19.0 h1a8c8d9_0 conda-forge
libtheora 1.1.1 h99b78c6_1006 conda-forge
libtiff 4.6.0 hf8409c0_4 conda-forge
libunistring 0.9.10 h3422bc3_0 conda-forge
libvorbis 1.3.7 h9f76cd9_0 conda-forge
libvpx 1.14.1 h7bae524_0 conda-forge
libwebp-base 1.4.0 h93a5062_0 conda-forge
libxcb 1.16 hc9fafa5_1 conda-forge
libxml2 2.12.7 h01dff8b_4 conda-forge
libzip 1.10.1 ha0bc3c6_3 conda-forge
libzlib 1.3.1 hfb2fe0b_1 conda-forge
llvm-openmp 18.1.8 hde57baf_1 conda-forge
llvm-tools 16.0.6 haab561b_3 conda-forge
loguru 0.7.2 py310hbe9552e_2 conda-forge
lxml 5.3.0 pypi_0 pypi
lz4-c 1.9.4 hb7217d7_0 conda-forge
markupsafe 2.1.5 py310h493c2e1_1 conda-forge
matplotlib 3.9.2 py310hb6292c7_0 conda-forge
matplotlib-base 3.9.2 py310heb73f16_0 conda-forge
matplotlib-inline 0.1.7 pyhd8ed1ab_0 conda-forge
metis 5.1.0 h13dd4ca_1007 conda-forge
mistune 3.0.2 pyhd8ed1ab_0 conda-forge
mpfr 4.2.1 h1cfca0a_2 conda-forge
mpi 1.0 openmpi conda-forge
mpi4py 4.0.0 py310h97fed95_3 conda-forge
msgpack-python 1.0.8 py310h7306fd8_1 conda-forge
multidict 6.0.5 py310h72036c0_1 conda-forge
mumps-include 5.7.2 hce30654_0 conda-forge
mumps-mpi 5.7.2 hbe42cef_0 conda-forge
munkres 1.1.4 pyh9f0ad1d_0 conda-forge
mysql-common 9.0.1 h1687695_0 conda-forge
mysql-libs 9.0.1 h0e80b4a_0 conda-forge
nbclient 0.10.0 pyhd8ed1ab_0 conda-forge
nbconvert-core 7.16.4 pyhd8ed1ab_1 conda-forge
nbformat 5.10.4 pyhd8ed1ab_0 conda-forge
ncurses 6.5 h7bae524_1 conda-forge
nest-asyncio 1.6.0 pyhd8ed1ab_0 conda-forge
nettle 3.9.1 h40ed0f5_0 conda-forge
nlohmann_json 3.11.3 h00cdb27_1 conda-forge
notebook 7.2.2 pyhd8ed1ab_0 conda-forge
notebook-shim 0.2.4 pyhd8ed1ab_0 conda-forge
numpy 2.1.1 py310hcaf17df_0 conda-forge
occt 7.7.2 novtk_h5f4376a_101 conda-forge
openexr 3.2.2 h2c51e1d_1 conda-forge
openh264 2.4.1 hebf3989_0 conda-forge
openjpeg 2.5.2 h9f1df11_0 conda-forge
openmpi 5.0.5 hba4779a_100 conda-forge
openssl 3.3.2 h8359307_0 conda-forge
overrides 7.7.0 pyhd8ed1ab_0 conda-forge
p11-kit 0.24.1 h29577a5_0 conda-forge
packaging 24.1 pyhd8ed1ab_0 conda-forge
pandocfilters 1.5.0 pyhd8ed1ab_0 conda-forge
parmetis 4.0.3 h9fe34a9_1006 conda-forge
parso 0.8.4 pyhd8ed1ab_0 conda-forge
pcre2 10.44 h297a79d_2 conda-forge
petsc 3.21.5 real_h179f621_100 conda-forge
petsc4py 3.21.5 py310h6530aa0_0 conda-forge
pexpect 4.9.0 pyhd8ed1ab_0 conda-forge
pickleshare 0.7.5 py_1003 conda-forge
pillow 10.4.0 py310h01af8b1_0 conda-forge
pip 24.2 pyh8b19718_1 conda-forge
pixman 0.43.4 hebf3989_0 conda-forge
pkg-config 0.29.2 hde07d2e_1009 conda-forge
pkgutil-resolve-name 1.3.10 pyhd8ed1ab_1 conda-forge
platformdirs 4.2.2 pyhd8ed1ab_0 conda-forge
pooch 1.8.2 pyhd8ed1ab_0 conda-forge
proj 9.4.1 hfb94cee_1 conda-forge
prometheus_client 0.20.0 pyhd8ed1ab_0 conda-forge
prompt-toolkit 3.0.47 pyha770c72_0 conda-forge
prompt_toolkit 3.0.47 hd8ed1ab_0 conda-forge
psutil 6.0.0 py310ha6dd24b_0 conda-forge
pthread-stubs 0.4 h27ca646_1001 conda-forge
ptyprocess 0.7.0 pyhd3deb0d_0 conda-forge
pugixml 1.14 h13dd4ca_0 conda-forge
pure_eval 0.2.3 pyhd8ed1ab_0 conda-forge
pycparser 2.22 pyhd8ed1ab_0 conda-forge
pygments 2.18.0 pyhd8ed1ab_0 conda-forge
pymobimp 0.1 dev_0 <develop>
pyobjc-core 10.3.1 py310h4b7648a_0 conda-forge
pyobjc-framework-cocoa 10.3.1 py310h4b7648a_0 conda-forge
pyparsing 3.1.4 pyhd8ed1ab_0 conda-forge
pysocks 1.7.1 pyha2e5f31_6 conda-forge
python 3.10.14 h2469fbe_0_cpython conda-forge
python-dateutil 2.9.0 pyhd8ed1ab_0 conda-forge
python-fastjsonschema 2.20.0 pyhd8ed1ab_0 conda-forge
python-gmsh 4.12.2 h57928b3_0 conda-forge
python-json-logger 2.0.7 pyhd8ed1ab_0 conda-forge
python_abi 3.10 5_cp310 conda-forge
pytz 2024.1 pyhd8ed1ab_0 conda-forge
pyvista 0.44.1 pyhd8ed1ab_0 conda-forge
pyyaml 6.0.2 py310h493c2e1_1 conda-forge
pyzmq 26.2.0 py310hcab215c_2 conda-forge
qhull 2020.2 h420ef59_5 conda-forge
qt6-main 6.7.2 h4682d5d_5 conda-forge
rapidjson 1.1.0.post20240409 h00cdb27_1 conda-forge
readline 8.2 h92ec313_1 conda-forge
referencing 0.35.1 pyhd8ed1ab_0 conda-forge
requests 2.32.3 pyhd8ed1ab_0 conda-forge
rfc3339-validator 0.1.4 pyhd8ed1ab_0 conda-forge
rfc3986-validator 0.1.1 pyh9f0ad1d_0 conda-forge
rpds-py 0.20.0 py310h7a930dc_1 conda-forge
scalapack 2.2.0 h42f3407_2 conda-forge
scipy 1.14.1 py310h35b72dc_0 conda-forge
scooby 0.10.0 pyhd8ed1ab_0 conda-forge
send2trash 1.8.3 pyh31c8845_0 conda-forge
setuptools 73.0.1 pyhd8ed1ab_0 conda-forge
sigtool 0.1.3 h44b9a77_0 conda-forge
six 1.16.0 pyh6c4a22f_0 conda-forge
slepc 3.21.1 real_h46f4cc2_302 conda-forge
slepc4py 3.21.1 py310hea9399d_104 conda-forge
snappy 1.2.1 hd02b534_0 conda-forge
sniffio 1.3.1 pyhd8ed1ab_0 conda-forge
soupsieve 2.5 pyhd8ed1ab_1 conda-forge
sqlite 3.46.1 h3b4c4e4_0 conda-forge
stack_data 0.6.2 pyhd8ed1ab_0 conda-forge
suitesparse 7.8.2 hec630bf_0 conda-forge
superlu 5.2.2 hc615359_0 conda-forge
superlu_dist 9.0.0 h72e2c5e_1 conda-forge
svt-av1 2.2.1 ha39b806_0 conda-forge
tapi 1300.6.5 h03f4b80_0 conda-forge
tbb 2021.13.0 h7b3277c_0 conda-forge
tbb-devel 2021.13.0 h8e01b61_0 conda-forge
terminado 0.18.1 pyh31c8845_0 conda-forge
tinycss2 1.3.0 pyhd8ed1ab_0 conda-forge
tk 8.6.13 h5083fa2_1 conda-forge
tomli 2.0.1 pyhd8ed1ab_0 conda-forge
tornado 6.4.1 py310h493c2e1_1 conda-forge
traitlets 5.14.3 pyhd8ed1ab_0 conda-forge
types-python-dateutil 2.9.0.20240906 pyhd8ed1ab_0 conda-forge
typing-extensions 4.12.2 hd8ed1ab_0 conda-forge
typing_extensions 4.12.2 pyha770c72_0 conda-forge
typing_utils 0.1.0 pyhd8ed1ab_0 conda-forge
tzdata 2024a h8827d51_1 conda-forge
unicodedata2 15.1.0 py310h2aa6e3c_0 conda-forge
uri-template 1.3.0 pyhd8ed1ab_0 conda-forge
urllib3 2.2.2 pyhd8ed1ab_1 conda-forge
utfcpp 4.0.5 hce30654_0 conda-forge
vtk 9.3.1 qt_py310h07c347a_205 conda-forge
vtk-base 9.3.1 qt_py310h19442d6_205 conda-forge
vtk-io-ffmpeg 9.3.1 qt_py310h64321a6_205 conda-forge
wcwidth 0.2.13 pyhd8ed1ab_0 conda-forge
webcolors 24.8.0 pyhd8ed1ab_0 conda-forge
webencodings 0.5.1 pyhd8ed1ab_2 conda-forge
websocket-client 1.8.0 pyhd8ed1ab_0 conda-forge
wheel 0.44.0 pyhd8ed1ab_0 conda-forge
widgetsnbextension 4.0.13 pyhd8ed1ab_0 conda-forge
wslink 2.1.2 pyhd8ed1ab_0 conda-forge
x264 1!164.3095 h57fd34a_2 conda-forge
x265 3.5 hbc6ce65_3 conda-forge
xorg-fixesproto 5.0 h3422bc3_1002 conda-forge
xorg-kbproto 1.0.7 h27ca646_1002 conda-forge
xorg-libice 1.1.1 hb547adb_0 conda-forge
xorg-libsm 1.2.4 hb547adb_0 conda-forge
xorg-libx11 1.8.9 he5f3e76_1 conda-forge
xorg-libxau 1.0.11 hb547adb_0 conda-forge
xorg-libxdmcp 1.1.3 h27ca646_0 conda-forge
xorg-libxext 1.3.4 h1a8c8d9_2 conda-forge
xorg-libxfixes 5.0.3 h3422bc3_1004 conda-forge
xorg-libxrender 0.9.11 hb547adb_0 conda-forge
xorg-renderproto 0.11.1 h27ca646_1002 conda-forge
xorg-xextproto 7.3.0 h1a8c8d9_1003 conda-forge
xorg-xproto 7.0.31 h27ca646_1007 conda-forge
xz 5.2.6 h57fd34a_0 conda-forge
yaml 0.2.5 h3422bc3_2 conda-forge
yarl 1.9.11 py310h493c2e1_0 conda-forge
zeromq 4.3.5 h64debc3_5 conda-forge
zfp 0.5.5 hcfdfaf5_8 conda-forge
zipp 3.20.1 pyhd8ed1ab_0 conda-forge
zlib-ng 2.2.1 h00cdb27_0 conda-forge
zstandard 0.23.0 py310h2665a74_1 conda-forge
zstd 1.5.6 hb46c0d2_0 conda-forge
Thanks and kind regards,
Tom
